I am reaching out after more than a week of search for a solution for what
seems like a basic step in ODK utilization.
I have been trying to upload a test application on ODK Build, although I
have tried the following steps:
Setting up the form on the ODK Aggregate, it is currently preventing me
from logging in via my gmail account (two errors occurred: Account not
recognized, Consumer error)
I couldn't mount ODK Collect folder on the SD card of my Galaxy Tab2.
The ODK VM showed errors in my xml file >> which I should modify when I
get a hang of it.
I would appreciate it if you share the most straightforward way to upload
forms on my tablet.
Until you are comfortable building forms with ODK Build, you should
download the form as XML to your computer and run ODK Validate on the form
to identify errors or omissions in the form definition.
On Wed, Oct 16, 2013 at 1:34 PM, Hawra Al-Rabaan wrote:
Dears,
get a hang of it.
forms on my tablet.
