ODK Central build error in restricted scenario
I'm trying to set up an ODK Central server using Docker, behind a corporate proxy, with a private IP for the moment. Is this configuration feasible? I'm unsure if the issue is related to the proxy settings or if it's a verification issue caused by the restricted environment.
Corporate policies prevent me from publishing the service until it has been tested by the IT department. The service will eventually be accessed through a reverse proxy with the necessary certificates installed upstream.
2. What have you tried to fix the issue?
I've set the HTTP and HTTPS proxy environment variables to allow Docker Compose to download the required images, and I added the server's hostname to the /etc/hosts file.
3. Upload any forms or screenshots you can share publicly below.
> => [service] exporting to image        0.0s
>  => => exporting layers        0.0s
>  => => writing image sha256:0100754b33998d47f60e19c9a20cb7bf3c04e213ae82d65f8fea0f85450f3699                                  0.0s
>  => => naming to docker.io/library/central-service        0.0s
>  => [nginx internal] load build definition from nginx.dockerfile                                                              0.0s
>  => => transferring dockerfile: 1.08kB        0.0s
>  => [nginx internal] load metadata for docker.io/jonasal/nginx-certbot:5.4.0                                                  1.5s
>  => [nginx internal] load .dockerignore        0.0s
>  => => transferring context: 67B        0.0s
>  => CACHED [nginx stage-1 1/9] FROM docker.io/jonasal/nginx-certbot:5.4.0@sha256:ff6c9031d4d933772deffa6081dede7f0588b4c0b5c  0.0s
>  => [nginx internal] load build context        0.1s
>  => => transferring context: 91.97kB        0.0s
>  => ERROR [nginx stage-1 2/9] RUN apt-get update && apt-get install -y netcat-openbsd                                        38.4s
>  => ERROR [nginx intermediate 2/5] RUN apt-get update     && apt-get install -y --no-install-recommends         git          38.4s
>  > [nginx stage-1 2/9] RUN apt-get update && apt-get install -y netcat-openbsd:
> 31.32 Ign:1 http://deb.debian.org/debian bookworm InRelease
> 31.32 Ign:2 http://deb.debian.org/debian bookworm-updates InRelease
> 31.32 Ign:3 http://deb.debian.org/debian-security bookworm-security InRelease
> 32.32 Ign:1 http://deb.debian.org/debian bookworm InRelease
> 32.32 Ign:2 http://deb.debian.org/debian bookworm-updates InRelease
> 32.32 Ign:3 http://deb.debian.org/debian-security bookworm-security InRelease
> 34.32 Ign:1 http://deb.debian.org/debian bookworm InRelease
> 34.32 Ign:2 http://deb.debian.org/debian bookworm-updates InRelease
> 34.32 Ign:3 http://deb.debian.org/debian-security bookworm-security InRelease
> 38.32 Err:1 http://deb.debian.org/debian bookworm InRelease
> 38.32   Could not connect to deb.debian.org:80 (151.101.2.132), connection timed out Could not connect to deb.debian.org:80 (151.101.66.132), connection timed out Could not connect to deb.debian.org:80 (151.101.130.132), connection timed out Could not connect to deb.debian.org:80 (151.101.194.132), connection timed out
> 38.32 Err:2 http://deb.debian.org/debian bookworm-updates InRelease
> 38.32   Unable to connect to deb.debian.org:80:
> 38.32 Err:3 http://deb.debian.org/debian-security bookworm-security InRelease
> 38.33 Reading package lists...
> 38.34 W: Failed to fetch http://deb.debian.org/debian/dists/bookworm/InRelease  Could not connect to deb.debian.org:80 (151.101.2.132), connection timed out Could not connect to deb.debian.org:80 (151.101.66.132), connection timed out Could not connect to deb.debian.org:80 (151.101.130.132), connection timed out Could not connect to deb.debian.org:80 (151.101.194.132), connection timed out
> 38.34 W: Failed to fetch http://deb.debian.org/debian/dists/bookworm-updates/InRelease  Unable to connect to deb.debian.org:80:
> 38.34 W: Failed to fetch http://deb.debian.org/debian-security/dists/bookworm-security/InRelease  Unable to connect to deb.debian.org:80:
> 38.34 W: Some index files failed to download. They have been ignored, or old ones used instead.
> 38.36 Reading package lists...
> 38.37 Building dependency tree...
> 38.37 Reading state information...
> 38.37 E: Unable to locate package netcat-openbsd
I finally got direct internet access on the project built successfully.
would you able to share how you did it?
Did you face any issue with dns when your vm is on private ip?
I am trying similar setup up (application gateway + vm on private ip) in Azure VM, but without success.
I think this is more of a docker config thing (or whatever container engine you are using), rather than being ODK specific.
Docker has some good docs on working behind corporate proxies
