GMRK
January 16, 2024, 1:13pm
1
I am trying to install ODK Central on Digital Ocean, and I am getting this error/message at the end:
failed to solve: process "/bin/sh -c OIDC_ENABLED="$OIDC_ENABLED" files/prebuild/build-frontend.sh" did not complete successfully: exit code: 134
Kindly assist in resolving the problem.
Gilbert
Not sure.
Run the build instructions again
I see an "out of memory" notice in the log, what is the type and size of your server instance on Digital Ocean?
GMRK
January 17, 2024, 8:17am
3
Good day,
I am using a free trial account for a Droplet of 1GB/ 1 vCPU.
yanokwa
January 17, 2024, 12:58pm
4
You need more RAM to complete the build. Upgrade to a 2 GB machine.
I'll update the docs to make sure others don't run into this issue.
That must be my issue. I have yet been able to complete the installation of ODK on Digital Ocean. I gave up after a dozen tries. I will try again with the 2 GB
It might not be your issue. Look at your logs to see what the likely issue is.
GMRK
January 18, 2024, 8:22am
7
Thanks so much. It worked after upgrading to 2GB.
