Hi, thanks a lot for providing ODK. I have started working on it recently for a custom project and it is really a great framework.
I have cloned the latest version of ODK Central (commit #1a97f79) on my Mac that already have docker installed.
More specifically these are the commands that executed as given in the doc:
git clone https:// github.com/getodk/central
docker-compose build
docker-compose up --no-start
until here everything is fine but when I run:
docker-compose up -d
It gives error in starting 2f6c14504b63_central_service_1
central_pyxform_1 is up-to-date
Starting central_secrets_1 ...
4c2b73591117_central_mail_1 is up-to-date
f4091d627f1f_central_enketo_redis_main_1 is up-to-date
central_postgres_1 is up-to-date
Starting central_secrets_1 ... done
central_enketo_1 is up-to-date
Starting 2f6c14504b63_central_service_1 ... errorERROR: for 2f6c14504b63_central_service_1 Cannot start service service: Mounts denied:
The path /data/transfer is not shared from the host and is not known to Docker.
You can configure shared paths from Docker -> Preferences... -> Resources -> File Sharing.
See https://docs.docker.com/docker-for-mac for more info.ERROR: for service Cannot start service service: Mounts denied:
ERROR: Encountered errors while bringing up the project.
Mac OS Bug Sur 11.0.1
Docker Engine 20.10.2
Docker Compose 1.27.4
I first tried to follow the instructions given in the error that is to add /data/transfer to my shared folders in Preference. but the issue is that such directory does not exist on Mac OS. And since it is on the root path I can't create any directory there even with sudo access.
I wonder if there is any option that allows me to specify a custom path to replace the used /data/transfer when running the docker command?
Run the steps above on Mac OS 11.
/data/transfer/ is not a valid path on Mac therefore this default path need to be changed as far I understand.
