ODK Central Interface Customization
Please is it possible to add a logo to the current ODK Central interface or probably change the colors of the interface?
For example: If I want to change the text
ODK Central
to another text or a logo, how do I achieve that?
Also, how do I change the colors of the interface if I want to change them.
Thanks.
Find attached a screenshot of what I am talking about.
odk central interface
Hi @Saviour_Dela, did you get a solution to this?
No, please. If you have any solution, I will be glad to have it.
Thanks.
Any update on this? response is highly appreciated
Currently if you would like to change the interface you will need to do this by changing the frontend code. For example, most colors are defined here. There is no way to customize the interface by configuration only.
