The ODK Central landing page is not loading. Firefox gives me an "Unable to connect" message. It has been over 24h now since I created the subdomain on FreeDNS.
- ODK Central (latest version I guess since the installation was done on Tuesday)
- DigitalOcean (Ubuntu 20.04.2).
- Subdomain via FreeDNS
- I have double checked that the subdomain is correct in the ODK Central settings using the
nano .env
command in the DigitalOcean console (XXX.mooo.com). - I used the
ping
command in the Windows console to check the URL. The URL is correctly resolved and points to the correct IP address for the Droplet (128.199.44.104). - I ran the
docker-compose ps
command again to check the server status. nginx isup (healthy)
as it should be.
Since this is a business installation, I could only send the server URL via private message.
