ODK Central v1.2 - no audit logging in encrypted projects?
XLSForms with row of type audit with parameters set to track-changes-reasons=on-form-edit track-changes=true
It seems there is no audit.csv available when forms belong to an ODK Central project that is encrypted before receiving any submission.
Similarly when submissions have been created before encryption, the audit.csv exists, but audit logging stops once encryption is enabled
Observed on ODK Central v1.2 (2 different servers)
client (v1.2.0) / client (v1.2.1)
server (v1.2.0) / server (v1.2.1)
Check audit parameters between forms used in encrypted / standard projects
Check the encrypted form doc, but I have not read any mention to this
Use the same form in two different projects (one standard / one encrypted).
N/A
This is a bug, thanks for reporting it! @Matthew_White has filed it at https://github.com/getodk/central-backend/issues/387 and we'll try to address it soon.
Thanks @LN, in the meantime I can still look at the individual audit.csv files (I was just curious to test the audit log analyzer developed by @hugh_sun on our data to visualise trends)
This has been fixed in v1.3. Thank you for reporting this issue!
