ODK Central v2026.2: Entities filtering and Web Forms as default
This release introduces Entity filtering, allowing you to control which Entities are downloaded by users. It also marks an important milestone for Web Forms, which is now the default web form experience for new forms.
:bullseye: Use Entity filtering to control which Entities users can download
You can now filter Entities for App Users and Public Access Links.
Project managers can define custom user properties (such as region, district, or team), set values for individual App Users or Public Access Links, and create filter rules that determine which Entities are downloaded by each user. Learn more.
Why filter Entities?
Protect privacy
With Entity filtering, users only download the Entities that are relevant to them. For example, a health worker in one district can be limited to records from that district.
Improve performance
Large Entity Lists can take time to download and process. Filtering reduces the amount of data downloaded to devices and browsers, helping forms load faster and synchronization complete more quickly.
Simple assignment
By filtering Entities based on properties such as district, region, team, or case worker, users automatically download only the records relevant to their work. If you also need to control which records users can act on, combine Entity filtering with in-form choice_filters.
:globe_with_meridians: Web Forms is now the default web form experience
Over the last several releases, we've been expanding Web Forms to support more ODK workflows and bringing the experience closer to Collect. With Web Forms now the default, new forms created in Central will open in Web Forms unless another web form engine is explicitly configured. Learn more.
For forms currently using Enketo, nothing changes immediately. Existing workflows will continue to work as expected.
:artist_palette: ... and more!
Simpler form draft page We've simplified the draft page and let you drag new form documents directly without opening a modal.
Form version notes When you publish a form draft, you can now add notes to keep track of the changes introduced by each update.
Stricter Content Security Policy We're protecting against more malicious injection into Central pages. Some browser plugins may no longer work. If you see unexpected loading failures, let us know.
Faster upgrades Central no longer builds the full frontend on every upgrade.
How to get these improvements?
If you are using Central on ODK Cloud, we'll be rolling out these updates in the coming days. If you are self-hosting Central, follow the upgrade instructions.
:blush: Thank you to everyone in the ODK community who provided feedback, tested new functionality, reported issues, and helped shape these improvements. We look forward to hearing how you're using Entity filtering and Web Forms in your projects!
ODK Central v2026.2.1 is now available. It includes the following changes:
  • Downgrade Enketo to 7.6.1 to resolve an issue with Google Maps
  • Fix Central failing to start in non-docker-compose environments when DB_SSL is not explicitly set to null. Thanks to @Tino for the report!
  • Update ODK Web Forms:
    • Show an error indicator when a submission attachment cannot be loaded
    • Stop deleting repeat instances when jr:count decreases
    • Use the current form version when editing a submission
    • Trim whitespace from attachment filenames when editing submissions
    • Fix setvalue firing in an unexpected order on second and later updates
    • Escape > symbols in markdown
    • Fix styling for media upload questions inside repeats
    • Stop Sentry from attaching trace headers to attachment requests, which was preventing images stored in S3 from loading. Thanks to @ahblake for the report.
For more details, read the release notes in the repository.
ODK Central v2026.2.2 is now available. It includes the following changes:
  • Fixed a bug where Entities can be bulk deleted even if name of the dataset in the endpoint is wrong.
  • Fixed performance issues when rendering a select with options from a large entity list. Thanks @Anthop for the report!
ODK Central v2026.2.3 is now available. It includes the following changes:
  • Fixed a bug where the wrong version of the frontend was included.
ODK Central v2026.2.4 is now available. It includes the following changes:
  • Fixed setvalue actions failing to set a value on readonly fields. Thanks @ahblake for the report!
  • Fixed a bug where setting invalid dates to string values throws an error.
  • Fixed a bug where the XPath sum() function returned NaN instead of 0 when no nodes matched the expression.
