i'm trying to implement NFC to write direct to an EditText but i have a
problem that i'm trying to solve without success..
The purpose is the following:
if i'm in a Text Box scan an NFC tag and the text that tag contains will be
write down to Text Box.
I have implement everything regarding NFC in FormEntryActivity (and in
message box i can view the string that tag contains) but when I set
programmatically the Text of EditText with the value of the tag the program
presents me instantly the new value in Text Box but returns me to the old
value (null if i didn't write anything before)...
Any Ideas why the programms clearing the New Value... ??
I suspect you are encountering issues with saving and restoring values in a
view.
You might first get this working using the "String from 3rd party
application" widget, where you have a stand-alone app that does the NFC
interaction, and returns the value into the string widget.
Once you have that working, then there is the question of how to stitch the
NFC interactions into the main application and get the result to plumb
through to the proper StringWidget.
If you understand the return flow from the 3rd party app back into the
widget, it will be easier to figure out what you need to do.
On Fri, Sep 5, 2014 at 6:11 AM, Panos Papadatos wrote:
Hi everybody,
be write down to Text Box.
I have made the implementation without an external app. I wrote the code directly to Form EntryActivity, and i get the focusable edittextbox to write with a setText command....
All above done well but afte setText i get always the previous value. Instantly i saw the tag value but after that text will be return to previous value...
In case of simple string type in which case the value will be cleared.. Is it possible to send you the code of FormEntryActivity to get a look?
Don't write the code directly to the FormEntryActivity. It's a big and
complex class and it's not easy to review. Write an external app or
clone a working widget and start there.
Do you have any example for external app implementation?
έγραψε:
Στις 7 Σεπ 2014 12:19 π.μ., ο χρήστης "Yaw Anokwa"
Panos,
previous value...
Στις 7 Σεπ 2014 12:19 π.μ., ο χρήστης "Yaw Anokwa" yanokwa@nafundi.com
έγραψε:
Panos,
value...
I have made the form with xlsform and i'm trying to find out what to write
in excel
Do you have such an example ??
Panos
On Sunday, September 7, 2014 12:50:22 AM UTC+3, Yaw Anokwa wrote:
> BreathCounter:
> https://code.google.com/p/opendatakit/source/browse/?repo=androidextras
> Yaw
> On Sat, Sep 6, 2014 at 5:22 PM, Panos Papadatos <ppapad...@gmail.com > wrote:
> > Στις 7 Σεπ 2014 12:19 π.μ., ο χρήστης "Yaw Anokwa" >
> > έγραψε:
> >> Panos,
> >> Yaw
> >> On Fri, Sep 5, 2014 at 3:31 PM, Panos Papadatos <ppapad...@gmail.com > wrote:
> >> > Hi Mitchd,
> code
> to write
> previous
> >> > value...
> cleared..
> look?
> >> > Thanks
> >> > Panos
> >> > You received this message because you are subscribed to the Google
> >> > Groups "ODK Developers" group.
> >> > To unsubscribe from this group and stop receiving emails from it,
> send
> >> > an email to opendatakit-developers+unsubscribe@googlegroups.com
> >> > For more options, visit https://groups.google.com/d/optout.
> >> You received this message because you are subscribed to a topic in the
> >> Google Groups "ODK Developers" group.
> >> To unsubscribe from this topic, visit
> https://groups.google.com/d/topic/opendatakit-developers/W-Jt9Gd7ags/unsubscribe.
> >> To unsubscribe from this group and all its topics, send an email to
> >> opendatakit-developers+unsubscribe@googlegroups.com .
> Groups
> an
Στις 7 Σεπ 2014 12:19 π.μ., ο χρήστης "Yaw Anokwa" yan...@nafundi.com
έγραψε:
Panos,
code
to write
previous
value...
cleared..
look?
So the only way is to write a form ins xls convert it to xml and edit the
generated xml using the instructions you send me???
On Tuesday, September 9, 2014 7:08:40 PM UTC+3, Yaw Anokwa wrote:
> Panos,
> I don't have any XLS example. Your best bet is to use XML for now.
> http://opendatakit.org/help/form-design/external-apps/
> https://code.google.com/p/opendatakit/source/browse/BreathCounter/breathTest.xml?repo=androidextras
> Yaw
> On Sun, Sep 7, 2014 at 3:03 PM, Panos Papadatos <ppapad...@gmail.com > wrote:
> > Hi Yaw,
> > does it works with xlsform ???
> write
> > in excel
> > Panos
> >> BreathCounter:
> >> Yaw
> >> > Στις 7 Σεπ 2014 12:19 π.μ., ο χρήστης "Yaw Anokwa" <
> yan...@nafundi.com>
> >> > έγραψε:
> >> >> Panos,
> and
> >> >> Yaw
> >> >> On Fri, Sep 5, 2014 at 3:31 PM, Panos Papadatos wrote:
> >> >> > Hi Mitchd,
> the
> >> >> > code
> edittextbox
> >> >> > to write
> value.
> to
> >> >> > previous
> >> >> > value...
> >> >> > cleared..
> >> >> > look?
> >> >> > Thanks
> >> >> > Panos
> >> >> > send
> the
> >> > Groups
> send
> >> > an
> Groups
> an
έγραψε:
Panos,
and
the
code
edittextbox
to write
value.
to
previous
value...
cleared..
look?
