Hi @sjvanek, thanks for filing this issue! We are seeing these crashes, but we can't reproduce them. We think that the Formhub-derived servers may not be sending the information we expect?
We just shipped an update to Collect a few minute ago (v1.12.2) that might help, so upgrade to that and report back. Also, I'm curious are any of the blank forms you are trying to list have media attachments?
Thanks for reporting this, @sjvanek, as @yanokwa said it does seem related to mysterious crashes we've been seeing. I just tried a form with jpg attachments served from Ona on 1.12.0 and form listing worked without problems.
@sjvanek Please share any info you can about your form. How was it created? Was that form ever on your device? Did you make changes to the form and re-upload it? What is the form ID?
I'm a colleague of @sjvanek, exploring the same issue. I've just updated to ODK Collect v1.12.2, and am happy to report that appears to have fixed the crash - at least on my side.
For info: I'd discovered that the crash only seemed to occur when I already had one or more blank forms downloaded to the phone. If I had no blank forms, Get Blank Form worked as expected, but if I had any blank forms already downloaded, Get Blank Form would cause a crash. It didn't seem to matter whether the downloaded form had media attachments or not.
Thanks both, and hopefully what-ever you did for the new version has fully resolved the issue.
Thanks for that update, @degami! I'm glad to know it's looking like it's fixed. Please update us if you see any other issues.
What you're describing makes sense -- the crash was in code to identify new versions of forms.
I am now able to reproduce in 1.12.0 by downloading a form from Ona and then getting blank forms. Previously I had an update to an existing form but that one had been downloaded from Aggregate. I'll look further into what the root cause is.
Hi, yes, the 1.12.2 update resolve it. Even if I already have other forms dowloaded. Thanks. this was on a motorola nexus 6 running android 7.0, if that helps.
