Hello,
When i import the ODK Collect source into Eclipse I get and Error through
out my activities every time the code import org.odk.collect.android.R; Im
not sure why i am using the right Google API and the SDK has all
the necessary packages installed.
Also when i import the project the name of the project
is SplashScreenActivity
On Tuesday, December 18, 2012 3:32:45 PM UTC-5, Jon Nordling wrote:
> Hello,
> Jon
The first error is due to the way Android projects work. They construct an
R file for all resource ids. This usually clears if you do an F5 (refresh)
and then a rebuild-all.
The second, I have no idea; there is an Eclipse Android project checked
into the source tree, so you should be importing an existing project, not
importing from source.
Hello,
I have figured it out. The problem was that i was importing from
Android->Existing Android Code Into Workspace, For for some reason it did
not like that. It worked when i imported from General->Existing Project
into Workspace. Then i ran as a Android Application and it worked.
Jon
On Tuesday, December 18, 2012 3:40:51 PM UTC-5, Mitch wrote:
> If this is your first time working on Android, I recommend the Android
> tutorial: http://developer.android.com/training/basics/firstapp/index.html
> Mitch
>>> Hello,
>>> through out my activities every time the code import
>>> org.odk.collect.android.R; Im not sure why i am using the right Google API
>>> and the SDK has all the necessary packages installed.
>>> Jon
> Mitch Sundt
> Software Engineer
> University of Washington
> mitche...@gmail.com
I have figured it out. The problem was that i was importing from Android->Existing Android Code Into Workspace, For for some reason it did not like that. It worked when i imported from General->Existing Project into Workspace. Then i ran as a Android Application and it worked.
The first error is due to the way Android projects work. They construct an R file for all resource ids. This usually clears if you do an F5 (refresh) and then a rebuild-all.
The second, I have no idea; there is an Eclipse Android project checked into the source tree, so you should be importing an existing project, not importing from source.
Also when i import the project the name of the project is SplashScreenActivity
Hello,
When i import the ODK Collect source into Eclipse I get and Error through out my activities every time the code import org.odk.collect.android.R; Im not sure why i am using the right Google API and the SDK has all the necessary packages installed.
Jon
Hi guys, i my projects generates always some error when i debug it in eclipse.help me please
This is not an ODK tool question and is inappropriate for this list.
Ok thanks,
Hello,
Jon
