Hii,
I have compile my own Odk Collect apk and using it without any problem .
But recently,. i have changed ODK xls form (include appearance attribute to maps).
And if i use that form and go to Record Location ,..ODK collect throws error
"Unfortunately ODK Collect has stopped" .
Also,. without using the appearance attribute to maps ,..it works fine.
Please suggest me solutions on this matter asap
Thanks in Advance
Rahul
Do you have Google Play Services installed on your device?
Do you have an account set up on your device? (Settings / Accounts / + Add
Account )
The Maps requires play services to vend the map tiles, and Google Maps
requires an account before it will return any tiles.
On Tue, Jul 1, 2014 at 2:08 AM, wrote:
Hii,
to maps).
error
Thanks in Advance
Rahul
"ODK Developers" group.
Do you have an account set up on your device? (Settings / Accounts / + Add Account )
The Maps requires play services to vend the map tiles, and Google Maps requires an account before it will return any tiles.
Hii,
Thanks in Advance
Rahul
You received this message because you are subscribed to the Google Groups "ODK Developers" group.
To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit-developers+unsubscribe@googlegroups.com.
mitche...@gmail.com
Thanks for you reply,
Actually, after compiling my odk collect ,..am testing this app on my TAB on which everything is already installed (Google Play Services)and also account is setup already.
For your info,.. on that same tab ,..ODK collect.apk running properly downloaded from google play store but custom ODK Collect.apk throwing error " Unfortunately ODK Collect has stopped " when clicking on record location (using appearance attribute is maps in xls form)
Thanks in advance
Rahul
Still sounds like a Play Services Issue. Can you look at the logs to
see what exception is being thrown?
https://code.google.com/p/opendatakit/wiki/CollectTroubleshooting has
hints on how to get the log.
On Tue, Jul 1, 2014 at 2:08 AM, rahulgu...@gmail.com wrote:
Hii,
Thanks in Advance
Rahul
mitche...@gmail.com
Thanks in advance
Rahul
You really just need to debug it and step through it.
Add Account )
Hii,
attribute to maps).
error
Thanks in Advance
Rahul
mitche...@gmail.com
Thanks in advance
Rahul
Thanks sir for your reply,
I am attaching below the LogCat Result when i click on Record location
button on ODK COLLECT .
Pl. check it.
Rahul
Exception Result.txt (2.91 KB)
Add Account )
Hii,
attribute to maps).
error
Thanks in Advance
Rahul
mitche...@gmail.com
Thanks in advance
Rahul
https://groups.google.com/d/topic/opendatakit-developers/POASq8U960U/unsubscribe
As per your instruction ,..i have copy Google play services lib from sdk>extras>google> and reference that libraries in the build path of ODK collect in ADT (also add google play services lib jar).
Also , i have build the android project using Google API (4.4) but the same problem persist i.e "ODK COLLECT HAS UNFORTUNATELY STOPPED" (when i click RECORD LOCATION button on ODK COLLECT).
i have attached the LogCat Exception below.
pl. guide me how i proceed next.
Rahul
LogCat Exception.txt (3.29 KB)
On Friday, 4 July 2014 14:33:13 UTC+5:30, Andre Mommert wrote:
> These issues occur:
> E/AndroidRuntime(1179): java.lang.RuntimeException: Unable to instantiate activity ComponentInfo{org.odk.collect.android/org.odk.collect.android.activities.GeoPointMapActivitySdk7}W/GooglePlayServicesUtil(1218): Google Play Store is missing.
> The following hint from the wiki is important:
> Beginning with ODK Collect 1.4 (i.e., to support the new Maps 2.0 API), you will also need the playservices project:http://code.google.com/p/opendatakit/source/checkout?repo=playservices
> You have to include this playservices and not the official one.
No. Use http://code.google.com/p/opendatakit/source/browse?repo=playservices
These issues occur:
Rahul
These issues occur:
Rahul
mitche...@gmail.com
Dear sir,
Thanks for you help,..Finally i am able to display GPS location widget with MAP in ODK Collect,..but still stuck with empty map i.e only grey grids are displaying with GPS marker.
Also, i have register the debug key with Google Map API V2 to get the google V2 API access and use it in manifeast file but still facing problem of displaying proper google map .
Pl.give me any suggestion on this matter,..where i am doing wrong .
Rahul
Rahul,
The community can't provide this level of help.
If you aren't seeing tiles, then the issue is the Google Maps API. See
https://developers.google.com/maps/documentation/android/start.
Get it working in a sample app first.
These issues occur:
Rahul
mitche...@gmail.com
Dear sir,
Rahul
Rahul,
These issues occur:
Rahul
mitche...@gmail.com
Dear sir,
Rahul
Hii,
Finally i am able to customize and compile odk collect source code according to my organization needs.
Once again thanks to all for a needful help .
Regards
Rahul
I have the same problem, what are your fix please?
> > Rahul,
> > Yaw
> > >> > These issues occur:
> > >> Thanks
> > >> Rahul
> > >> For more options, visit https://groups.google.com/d/optout.
> > >> Mitch Sundt
> > >> Software Engineer
> > >> mitche...@gmail.com
> > > Dear sir,
> > > Thanks
> > > Rahul
> Hii,
> Regards
> Rahul
If you have the same problem, which of the solutions in this thread
have you tried? What happened when you tried them?
Rahul,
These issues occur:
Rahul
mitche...@gmail.com
Dear sir,
Rahul
Hii,
Regards
Rahul
