Hello,
I'm having trouble sending data from ODK to Google Sheet server.
Photos in the field are rotated on Google Sheet.
I have tried many ways, on mobile device the photo does not rotate
Please help me!
Hi @Bac_Nguyen_Van
We're glad you're here. When you get a chance, please introduce yourself on this forum thread. I'd also encourage you to add a real picture as your avatar because it helps build community!
Please answer the questions below what should help to track down the issue:
- What device are you using?
- Are the same pictures displayed correctly in ODK Collect?
- Is this an issue in ODK v1.29.2 as you pointed out in the topic or you just haven't tried other versions?
- Could you attach a sample picture that is rotated?
3. Is this an issue in ODK v1.29.2 as you pointed out in the topic or you just haven't tried other versions?
The image is not rotated in other versions
Is it a picture you attached (after downloading for example) or you captured it using camera?
This is an image viewed using GoogleDriver.
Mobile pictures are not rotated
Ok thanks, I'll try to reproduce the issue.
I tested on 4 other devices, the results are no longer rotated.
Looks like my SamSungA51 has a problem.
Thanks for answering!
Ok good to know that is related to that particular device. Is it only about that device(no matter what ODK Collect version you use) or maybe it takes place only on your SamsungA51 and only when v1.29.2 is used?
