ODK Collect Failing Submission after SSL Installation
I recently installed SSL Certificate on my server. I tested access via the web and its working fine. However the tablets are failing to Sync showing the error below:
I have tested my SSL via the link https://www.sslshopper.com/ssl-checker.html and getting all green ticks on everything
Running ODK Aggregate 2.02
Removed the SSL Certificate and it worked so I am certain its the SSL Certificate. All the necessary ports have been allowed through Firewall.
Please note that Aggregate is no longer being supported. Central is now the ODK server. The post below has for more details about the end-of-life for Aggregate.
Someone on the forum may still be able to help you. Is this a local installation? Or on a cloud-services provider?
Local installation. Would appreciate any support.
Look at your Tomcat logs for hints as to what is happening.
