we are trying to make ODK Data Collect run on HP Palm WebOS 2.0 by using Google Webtool kit to convert the Java to Javascript to run on HP Palm. Kristian, who is working on this has some source files missing - can you point where to get complete source.
please send support questions to the mailing list (cc'ed).
we have instructions for installing collect at http://opendatakit.org/use/collect/. on step two, you'll see a link
for properly configuring the emulator. i'm guessing you didn't attach
an sd card to your avd.
try following those instructions and if it
still doesn't work, post back to the list.
installed ODK Collect latest version 1.1.5 onto emulator using adb install, every thing fine - comes back with Success.
but when I run it it comes back with
Sorry the application ODK Collect (process org.odk.collect.android) has stopped unexpectedly. Please try again. Force close.
your YouTube shows it running clean on Android emulator
Any idea what the problem maybe ?
On Thu, Jan 20, 2011 at 12:48, Peter Digovich wrote:
Yaw,
an sd card to your avd. try following those instructions and if it
