Hi All,
Is there any simple way (outside of changing the ODK Collect code) to
change the repeat display "FieldName Record 1, 2, 3, etc" to incorporate
one of the fields in your form? So if your repeat group was named "PD" and
the actual values on the form were 1001, 1002, etc, it would display as "PD
Record 1001, 1002, etc."
Shaun
Shaun,
I don't think so. Best you can do is to maybe add maybe a note
question inside the repeating group that uses outputs to display the
values. Then wrap that note and the other prompts in another group so
they appear on the same page.
Need ODK services? http://nafundi.com provides form design,
professional support, custom reporting, and software development for
ODK.
On Thu, Oct 24, 2013 at 11:15 AM, phill214@gmail.com wrote:
Hi All,
Is there any simple way (outside of changing the ODK Collect code) to change
the repeat display "FieldName Record 1, 2, 3, etc" to incorporate one of the
fields in your form? So if your repeat group was named "PD" and the actual
values on the form were 1001, 1002, etc, it would display as "PD Record
1001, 1002, etc."
Shaun
