i have a question which ask which region the interviewee is hailing from, and based on the region, i have a select (selected(${region},"greater_accra")) for example, to list the districts under that region.
but the issue is that when i upload the the form into ODK Aggregate, and in ODK collect on my android huawei T1-A21L tablet, i upload and test the form, when i select the region, the districts doesnt populate rather if i swipe forward and backwards again, thats when the districts for that particular region shows up. but when i preview it in enketo, everything works perfectly.
i used an excel worksheet to design the form. need help.
i'll also be grateful how i can group multiple questions in one screen using the excel worksheet.
