ODK Collect betas are an opportunity to get community feedback on upcoming releases. If you have an ongoing data collection campaign, we recommend quickly verifying your form on a test device. The release will be delayed until all reported issues are fixed.
Joining the beta program
Leaving the beta program
You can leave the beta program from the bottom of the Play Store at any time. Once you leave, you will get the next production update when it is released. If you need to go back to the previous production release, uninstall and reinstall the app. Your settings will be reset but your forms will remain (though backups are always recommended).
Just a thought, on how to improve more the button alignment. I think if the buttons were aligned center , will create more room space for each button, hence filling the space. In bigger screen devices this will really improve the experience.
Thanks. It is fine, something just we are living with. We mostly use tablets of 7 to 10.1 inch.
With bigger devices, there are some spaces that can be utilized.
@mathieubossaert is pointing out that perhaps the quotes are unnecessary. I'm glad someone is bringing this up. @seadowg and I thought it was valuable to separate user-defined text since we can't guarantee that the sentence will read well. Sometimes users have tried to compensate for the previously-confusing dialog text by adding more words to their repeat name. For example Add add a turtle? is really strange. Add "add a turtle"? at least suggests that the phrase is not default Collect text. I don't feel very strongly about this and am interested in what others think.
I would suggest (having used a re-built Collect with custom string resources for a while now) that the button choices be simplified to just "No" and "Yes". They are instantly recognizable, even for less than native speakers who are using the form and eliminate the "pause" while they parse the button text. I have also found it useful to keep the quotes around the repeat name
Thanks for that feedback and for sharing your experience, @lowly!
We are trying to follow design guidelines and specifically Material Design (see e.g. this article) as much as possible moving forward. In this case, the recommendation is that button names should be verbs. You're right that someone who already expects a repeat dialog and knows what the text says can easily use Yes and No buttons but they're harder to use when the dialog is new.
