Release highlights
- v1.28.4 - November 5, 2020
- Fix crash when double clicking on minimal select button
- Detailed release notes: https://github.com/getodk/collect/releases/tag/v1.28.4
- v1.28.3 - October 26, 2020
- Fix some calculations not immediately getting re-evaluated
- Detailed release notes: https://github.com/getodk/collect/releases/tag/v1.28.3
- v1.28.2 - October 8, 2020
- Fix loading downloaded media files in Android 10
- Fix crashes when a user changes Blank form update mode if one of related options is disabled in Admin settings
- Detailed release notes: https://github.com/getodk/collect/releases/tag/v1.28.2
- v1.28.1 - September 25, 2020
- Fix crash when exiting form that failed to fully load
- Fix crash when point from Google Maps is invalid
- Detailed release notes: https://github.com/getodk/collect/releases/tag/v1.28.1
- v1.28.0 - September 23, 2020
- New settings to automatically match the blank forms on the server
- Allow minimal appearance to combine with other select appearances
- Calculation re-computation when repeat instances are added or removed is faster and more complete in some cases
- Questions of type geopoint use all available sensors to determine location
- Vertical scrolling is less likely to accidentally swipe to next question
- Detailed release notes: https://github.com/getodk/collect/releases/tag/v1.28.0
Download release
- https://play.google.com/store/apps/details?id=org.odk.collect.android (recommended)
- ODK-Collect-v1.28.4.apk
Report issues
