ODK Collect betas are an opportunity to get community feedback on upcoming releases. If you have an ongoing data collection campaign, we recommend quickly verifying your form on a test device. The release will be delayed until all reported issues are fixed.
Joining the beta program
Leaving the beta program
You can leave the beta program from the bottom of the Play Store at any time. Once you leave, you will get the next production update when it is released. If you need to go back to the previous production release, uninstall and reinstall the app. Your settings will be reset but your forms will remain (though backups are always recommended).
What to check in this release
- New geopoint dialog. More discussion on the new behavior at Collect: Improve geopoint dialog so it better highlights acceptable accuracy
- Audio recording now defaults to using the internal recorder. First announced in "Use external app for audio recording" will default to false in Collect v2022.1
Additional testing
You can find a full list of changes in the release notes:
Thanks to all testers for your help!
