Release Highlights
v2022.1.0 - January 26th, 2022
- New geopoint dialog to guide users towards saving higher-accuracy points
- Configurable unacceptable accuracy threshold for new geopoint dialog
- Internal audio recorder is now used by default (use parameter
quality=externalto use external app) - Detailed release notes: https://github.com/getodk/collect/releases/tag/v2022.1.0
v2022.1.1 - February 6th, 2022
- Speed up maps with markers by caching their images
- Ensure images resized with
max-pixelstake up less space than the source images - Return instance URI for Form
EDITaction - Detailed release notes: https://github.com/getodk/collect/releases/tag/v2022.1.1
v2022.1.2 - February 28th, 2022
- Fix problem with saving attributes after scaling down image
- Handle invalid
accuracyThresholdandunacceptableAccuracyThreshold
Download release
- https://play.google.com/store/apps/details?id=org.odk.collect.android (recommended)
- ODK-Collect-v2022.1.2.apk
Report issues
