We have an exciting release coming for you! We currently believe it will be out mid-July. Check back for updated betas as we get closer to release.
Why we do betas
ODK Collect betas are an opportunity to get community feedback on upcoming releases. If you have an ongoing data collection campaign, we recommend quickly verifying your form on a test device. We will keep sharing new betas as we respond to your feedback and will let you know when the beta is a release candidate.
Joining the beta program
Leaving the beta program
You can leave the beta program from the bottom of the Play Store listing at any time. Once you leave, you will get the next production update when it is released. If you need to go back to the previous production release, uninstall and reinstall the app. Please make sure to back up or submit any important data.
What to check in this release
Reference geometry for geotrace or geoshape. Try it with ref_geo_demo.xml (3.3 KB) which demonstrates using an Entity List or a repeat as sources for reference geometry. XLSForm support is coming soon. Learn more.
Image and video previews in table of contents. When you navigate to the table of contents during form entry or by tapping on a draft or sent form, you will see small previews of images or videos inline. Tap to open them in the system viewer.
osmdroidlibrary removed. If you use OpenStreetMap, Carto or USGS basemaps, we recommend trying this beta. Learn more.
Less keyboard movement. While filling out a form, the keyboard now stays on screen when navigating between questions that need the keyboard.
Android 8+ now required. This will allow us to take advantage of more modern operating system features. Older devices will continue to have access to Collect v2026.2 in the Play Store. Learn more.
Blue dot indicator for current location. More bold than the prior crosshair and in line with modern map interfaces.
Additional testing
You can find a full list of changes in the release notes:
Thanks to all testers for your help!
