Hello,
What is the difference between ODK Collect and ODK Survey? Is there any
document that I can see the details of these 2.
Chan Choth
Hello,
Chan Choth
Survey is the next generation Collect.
Release note: http://code.google.com/p/opendatakit/wiki/SurveyReleaseNotes
Hello,
document that I can see the details of these 2.Thanks,
Chan Choth--
Post: opendatakit@googlegroups.com <javascript:_e({}, 'cvml',
'opendatakit@googlegroups.com');>
Unsubscribe: opendatakit+unsubscribe@googlegroups.com <javascript:_e({},
'cvml', 'opendatakit%2Bunsubscribe@googlegroups.com');>
Is there a summary anywhere that lists the improvements in Survey over Collect?
Thanks!
Hi All
We are Nonofist NGo. we want to do survey using ODK. We have around 1200 respondents. Do you think we need to pay for that or how the process ?
best
MOhammed
The ODK team does not have any immediate plans to support iPhone. ODK
Survey will make it easier to make a tool version on the iPhone as
being javascript it is more platform independent besides the hooks
needed into the OS. However this is not high on the ODK core team's
priority list so you will not see any iphone support anytime soon. We
support the idea but we don't have the resources to do it in the short
run.
As always code contributions are welcome if somebody wants to do the
port. The ODK core team has a long list of requests we try to get to,
but we can't get to them all. ODK Survey's use of javascript and html
makes it much easier to support an iphone version as we are already
supporting a version of ODK Survey that runs in chrome.
Waylon
Do you still support the idea of doing also a iOS compatible version?
Al 25/01/2013 7:34, En/na ??????? ha escrit:
Hi Waylon,
Thanks for your answer. What development tool are you using for develop
Survey? Eclipse? Phonegap?
Regards
Al 25/01/2013 15:52, En/na W. Brunette ha escrit:
See the following.
https://groups.google.com/forum/#!msg/opendatakit/ZZmXwOCzXkk/FsrKye4_fIgJ
On Fri, Jan 10, 2014 at 11:02 AM, paulhamlin@global.t-bird.edu wrote:
On Thursday, January 24, 2013 10:57:00 PM UTC-6, Chan Choth wrote:
Hello,
What is the difference between ODK Collect and ODK Survey? Is there any document that I can see the details of these 2.
Chan ChothIs there a summary anywhere that lists the improvements in Survey over Collect?
Thanks!
All applications (ODK Collect, ODK Aggregate, ODK Briefcase) are free. The
big issue is where or how you are going to aggregate the data -- whether
you use ODK Briefcase only or whether you set up an ODK Aggregate server to
which all data is published.
If you decide to set up a server, the Deployment Planning guide
http://opendatakit.org/use/aggregate/deployment-planning/ is useful.
Also, there are other servers available beside ODK Aggregate, some of which
are hosted and managed for you (e.g., SurveyCTO, FormHub). See
The best thing to do is get started early with an end-to-end demonstration
project with just a few surveyors and a minimal version of your form, be
sure you understand how to aggregate the data and export it into useful
formats, figure out what makes the most sense for your situation. Then grow
both the form and the survey group as you gain familiarity.
Hi All
respondents. Do you think we need to pay for that or how the process ?best
MOhammed--
ODK Survey, the Java code, is not based upon Phonegap / Cordova. The code
is in an Eclipse project (search the opendatakit-developers@ group archive
for the links to the source repos)
At the time we started development, the Cordova software did not embed well
within a larger application -- it really wanted to be the main screen, and
had a lot of plumbing to connect everything together. Also, since we are
focused on rapidly prototyping and deploying solutions out into the world,
we did not want to debate and deliberate how best to agnostically expose
new device interfaces through Phonegap extension layers. It is better to
just admit that the core team is working on Android phones, and give direct
access to the intent, service, and content provider mechanisms as we need
them.
ODK Survey, the Javascript code, is largely developed using Chrome on a PC,
then tested on the phone. It runs fine in Chrome, but lacks the
functionality to publish the collected data up to the server, and does not
have any support for capturing images, etc..
Hi Waylon,
Survey? Eclipse? Phonegap?Regards
run.As always code contributions are welcome if somebody wants to do the
supporting a version of ODK Survey that runs in chrome.Waylon
Al 25/01/2013 7:34, En/na ゴー・ニコライ ha escrit:
Release note: http://code.google.com/p/**opendatakit/wiki/**
SurveyReleaseNoteshttp://code.google.com/p/opendatakit/wiki/SurveyReleaseNotesOn Friday, January 25, 2013, Chan Choth wrote:
Hello,
Chan Choth--
Unsubscribe: opendatakit+unsubscribe@**googlegroups.comopendatakit%2Bunsubscribe@googlegroups.com
Options: http://groups.google.com/**group/opendatakit?hl=enhttp://groups.google.com/group/opendatakit?hl=en--
Options: http://groups.google.com/**group/opendatakit?hl=enhttp://groups.google.com/group/opendatakit?hl=en--- You received this message because you are subscribed to the Google
email to opendatakit+unsubscribe@**googlegroups.comopendatakit%2Bunsubscribe@googlegroups.com
For more options, visit https://groups.google.com/**groups/opt_outhttps://groups.google.com/groups/opt_out
I have to prove it in iOS, but I do not find the time window ![]()
Thanks for your clear response.
Al 06/02/2013 21:17, En/na Mitch S ha escrit:
