ODK Collect
Is there some possibility to create a CSV reader in ODK Collect and make it
generate a graphic???
There is possibility to do most things if some writes the custom code
required to implement the functionality you are looking for.
The ODK core team does not have the resources to take on such
requests. If you organization lacks the technical skills necessary to
make customizations, may I suggest hiring someone from the Help for
Hire page http://opendatakit.org/help/help-for-hire/.
Waylon
··· On Fri, Jul 27, 2012 at 1:07 PM, anderson cleyton wrote: > Is there some possibility to create a CSV reader in ODK Collect and make it > generate a graphic???
