Thanks Yaw - I think I did something wrong with the image upload, when I
removed that it worked, will play with it some more.
On Tue, Dec 20, 2011 at 5:22 PM, wrote:Today's Topic Summary
Group: http://groups.google.com/group/opendatakit/topics
- error adding form in aggregate? <#1345e36adea32b3c_group_thread_0>[2 Updates]
- ODK Local Instance Error 404 <#1345e36adea32b3c_group_thread_1> [1
Update]- Uploading data from a computer rather that through a device<#1345e36adea32b3c_group_thread_2>[1 Update]
error adding form in aggregate?http://groups.google.com/group/opendatakit/t/c95c6019534e143
SabrinaD sldrill80@gmail.com Dec 20 02:45PM -0800
Hi, I'm getting this error trying to add a form in aggregate.
Error: Problem with JavaRosa Parsing Form:
java.lang.NullPointerExceptionI am totally new to this and not a programmer! I installed aggregate
today so it should be the latest version. I tried re-installing Java.
Trying to bring in a really simple form I just built in Build.Thanks for any help.
Yaw Anokwa yanokwa@gmail.com Dec 20 03:43PM -0800
sabrina,
try running the form through odk validate
(http://code.google.com/p/opendatakit/downloads/list). my guess is
that you have a select one that has some blank values...yaw
ODK Local Instance Error 404http://groups.google.com/group/opendatakit/t/6f8dd5becb7d5866
Yaw Anokwa yanokwa@gmail.com Dec 20 02:02PM -0800
sanjeev,
i'm forwarding this to the mailing list. we don't provide support
outside of the list. please subscribe for a response.yaw
On Tue, Dec 20, 2011 at 04:47, Sanjeev Rao Basineni
Uploading data from a computer rather that through a devicehttp://groups.google.com/group/opendatakit/t/89d9f5caec9a4b8
Gaetano Borriello gaetano@cs.washington.edu Dec 20 01:45AM -0800
Also, Briefcase can take submissions downloaded from your phone on to
your computer and generate a .csv file locally without having to use
anything in the cloud.Gaetano
You received this message because you are subscribed to the Google Group
opendatakit.
You can post via email opendatakit@googlegroups.com.
To unsubscribe from this group, sendopendatakit+unsubscribe@googlegroups.coman empty message.
For more options, visithttp://groups.google.com/group/opendatakit/topicsthis group.--
