I'm trying to use App Engine to set up my ODK forms, but every time I log
in and click "Create a New Application" I get an error message that too
many redirects have created a feedback loop and the page won't load. I've
tried clearing cookies for the site and logging out of any other google
accounts I'm using, but nothing seems to work. Any suggestions?
(1) be sure you have updated to the latest version of your browser and all
software updates for your operating system. A while back, some hackers
stole some Google site certificates, and you might end up with problems if
you have an older browser.
(2) if that doesn't fix it, try downloading and using a different browser.
E.g., Chrome or Firefox or Safari, if those aren't your normal browser.
(3) try it after a day or two. It might just be a Google infrastructure
glitch.
On Fri, Jan 25, 2013 at 5:07 AM, wrote:
Yes, and I've tried to go through all of the recommended steps to fix the
problem, but nothing is working. Not sure what else I should try.
log in and click "Create a New Application" I get an error message that too
