Chris,
No worries all your question were valid.
I was simply giving you a complete as answer as possible to let you
know your options.
Waylon
On Mon, Oct 22, 2012 at 3:29 PM, wrote:
> On Friday, October 19, 2012 11:03:32 PM UTC-7, co...@rand.org wrote:
>> I have a form that was working fine until the update w/ build #1018 was distributed. Now, the form fails on the third item: only one of two answer choices is presented and then ODK fails and closes. I have truncated the form to include only the top of the file where the failure occurs. This truncated version works ok w/ build 1015.
>> Is anyone else having a problem w/ #1018?
>> Thanks,
>> Chris
> Thank you for your reply. Pardon me if I seemed impatient, I am new to this environment and felt as though my report was incomplete. My expectations are certainly tempered by the limitations you describe.
> Best regards,
> Chris
