[ODK Community] Track odk users submissions
If you want to know the user that collected the data, you need to capture
that in your form.
Some application properties can be inserted into the form automatically.
The 'username' property will capture the username of the user configured to
submit the data up to the server.
However, maintaining different usernames for each tablet can be
overwhelming. Many sites consider this a configuration nightmare and
instead simply add a question at the start of each form that asks the data
collector to scan a barcode to capture their identity.
https://opendatakit.org/help/form-design/examples/#Property_values
Using XLSForm, some or all of these are available for insertion as
'metadata' (see the section about 'metadata' on the xlsform.org site).
··· On Wed, Oct 28, 2015 at 11:01 AM, lamyaa salhi wrote:
Hi all,
please, I wanna know if there is a possibility to filter one form
submissions by the odkcollect users. and also have on the pop up infos on
the map the name of the user who collected the data.
And once you collect that name, you can export to KML and those popups
are configurable.
··· -- Need ODK consultants? https://nafundi.com provides form design, server setup, in-field training, and software development for ODK.
that in your form.
Some application properties can be inserted into the form automatically. The
overwhelming. Many sites consider this a configuration nightmare and instead
simply add a question at the start of each form that asks the data collector
On Wed, Oct 28, 2015 at 11:01 AM, lamyaa salhi lamyaa.salhi@gmail.com wrote:
Hi all,
