Has anyone noticed any problems with ODK apps on the latest version of
Android? We use Nexus 7's to run Collect and the preliminary version of
Scan. The updates to Android 4.4 are starting to roll out to our devices
now. So far, I haven't installed any of the updates because I'm concerned
about compatibility (right now scan only works on a samsung tablet running
an older version of android). I want to make sure everything will work
before updating our devices.
I have been running CommCare ODK successfully on a Nexus 5 with Android 4.4 (KitKat). However, we have received a report of errors in CommCare ODK when updating from a previous version to KitKat (on a Nexus 4).
We are looking into this and we will update this thread when we can give a certain answer.
Will
On Friday, November 22, 2013 5:53:21 AM UTC-5, Jon Prettyman wrote:
> HI All,
> Has anyone noticed any problems with ODK apps on the latest version of Android? We use Nexus 7's to run Collect and the preliminary version of Scan. The updates to Android 4.4 are starting to roll out to our devices now. So far, I haven't installed any of the updates because I'm concerned about compatibility (right now scan only works on a samsung tablet running an older version of android). I want to make sure everything will work before updating our devices.
> Thanks for the help,
> Jon
We are also concerned with updating to the new KitKat. Has anyone experienced errors running ODK Collect with KitKat on Samsung Galaxy Note 2 devices?
Scott
> HI All,
> Jon
It would be great if the community could test ODK Collect running on 4.4
and report any issues before the end of April. If you find anything that is
broken, the sooner we know of it, the more likely it will be in the 1.4.3
release.
The one issue that has been reported is that the Choose-image, Choose-video
and Choose-audio functionality is broken in KitKat. For some reason, the
capture-* functionality still works (though it is using exactly the same
logic).
The upcoming ODK Collect 1.4.3 (ETA is end of April) will have a fix -- but
the fix is not in the recently announced release candidate -- we just added
it yesterday -- this issue also affects the ODK Survey beta-2.
Other than that, we are not aware of any problems with 4.4
HI All,
Jon
ODK Community,
devices?
Hi Jon,
We tested 1.4 (1038) on KitKat 4.4 and 4.4.1 with in several large
deployments since November and had no errors in that regard. Didn't use any
of the choose media features Mitch mentioned, though.
Tino
release.
Choose-video and Choose-audio functionality is broken in KitKat. For some
reason, the capture-* functionality still works (though it is using exactly
the same logic).
but the fix is not in the recently announced release candidate -- we just
added it yesterday -- this issue also affects the ODK Survey beta-2.
HI All,
Jon
ODK Community,
devices?
Thanks Mitch for the early confirmation. Our team has just intended to work
on a fix. We will divert resources to other stuff.
Trung.
> release.
> the same logic).
> Mitch
>> > HI All,
>> > Jon
>> ODK Community,
>> devices?
>> Thanks,
>> Scott
>> "ODK Community" group.
> Mitch Sundt
> Software Engineer
> University of Washington
> mitche...@gmail.com
We've done two deployments running on 4.4 and haven't encountered any
issues other than the choose image problem addressed above.
Jon Prettyman
skype: jonrprettyman
phone: 996 555 77 28 98
work on a fix. We will divert resources to other stuff.
Trung.
release.
the same logic).
HI All,
Jon
ODK Community,
devices?
Groups "ODK Community" group.
