I am trying to connect OpenMRS and ODK collect, there is server settings on the ODK Collect client but what will be values for 'FormListPath' and 'submission path'. Really appreciate your answers. Both are powerful tool but without the knowledge of URLs they are useless. I have gone through several mailing list but answer is not given anywhere. Any help in this regard is appreciated.
Nidhi
On Tuesday, May 27, 2014 10:43:01 PM UTC+5:30, Talha Ahmad Siddiqui wrote:
> Yeah I have done that..figured it out..thanks anyways
> On 27 May 2014 22:07, "Yaw Anokwa" wrote:
> Your best bet is to send this question to the OpenMRS developers list.
> Yaw
> Need ODK services? http://nafundi.com provides form design, server
> setup, professional support, and software development for ODK.
> On Tue, May 27, 2014 at 3:39 AM, tas wrote:
> > Hi
> > I have been trying to edit the Xforms in my OpenMRS (via Manage Xforms Properties). But whenever I make a change in it, it is not saved. Instead sometimes it shows me "Privileges Required" error.
> > I want to change the xforms.saveFormat property from prucforms to javarosa.
> > Any help will be really appreciated.
> > Thanks
> > On Tuesday, February 7, 2012 10:38:08 PM UTC+5:30, wmonterrey wrote:
> >> Ok, thanks for help Yaw, Daniel and Sarah
> >> I really apprecciate it
> >> William
> >> From: "Yaw Anokwa"
> >> Sent: Tuesday, February 07, 2012 10:43 AM
> >> To:
> >> Subject: Re: [ODK Community] Re: ODK Connected to OpenMRS
> >> > Yes. v1 and v2 are entirely different.
> >> > On Tue, Feb 7, 2012 at 08:41, William Aviles Monterrey wrote:
> >> >> Hi Yaw, Daniel
> >> >> I have tested the ODK Clinic in the repo with the same configuration and
> >> >> server and it's not working. I think I am going over the problem but I
> >> >> just
> >> >> wanted to make sure that it's worthy taking into consideration the
> >> >> development of ODKClinic 2.
> >> >> Is the code en Clinic 2 completely different from Clinic 1?
> >> >> Best
> >> >> William
> >> >> From: "Yaw Anokwa"
> >> >> Sent: Saturday, February 04, 2012 11:57 AM
> >> >> To:
> >> >>> William,
> >> >>> ODK Clinic v1 is the repo you pointed to. It works, but there are
> >> >>> issues that make it hard to use as it is. I've documented them at
> >> >>> http://code.google.com/p/opendatakit/issues/list?q=label%3AClinic. I'm
> >> >>> in dissertation writing mode, so it's going to be some time before I
> >> >>> can get to those issues -- that's why it's in community support mode.
> >> >>> The code base is simple enough for someone else to fix them though.
> >> >>> ODK Clinic v2 has been running well at AMPATH for the past few months.
> >> >>> Glad to give you access to that code, but it's very far from turnkey
> >> >>> to get it up and running at a non-AMPATH site. Again, I'll try to
> >> >>> address these issues when I have more time, but it's going to take a
> >> >>> month or two.
> >> >>> Yaw
> >> >>> On Sat, Feb 4, 2012 at 09:45, Daniel Kayiwa wrote:
> >> >>>> Hi William,
> >> >>>> It has been some time since i built that apk.
> >> >>>> So the code at that location has gone through quite some number of
> >> >>>> changes
> >> >>>> since then.
> >> >>>> On Sat, Feb 4, 2012 at 12:16 AM, William Aviles Monterrey wrote:
> >> >>>>> Hi Daniel, Yaw and Sarah
> >> >>>>> About this thread I have a few questions for you, I am trying to
> >> >>>>> connect
> >> >>>>> OpenMRS to ODK, but I think I would have to modify a bit the code.
> >> >>>>> Yaw: Any news about odk-clinic's new version?
> >> >>>>> Daniel: The apk that you attached in the email is working with OpenMRS
> >> >>>>> 1.6
> >> >>>>> + xForms 4.9. Do you happen to know if this apk was built with the
> >> >>>>> repository here:
> >> >>>>> http://code.google.com/p/opendatakit/source/checkout?repo=clinic ?
> >> >>>>> Sarah: Any word from releasing the code of the custom module in the
> >> >>>>> Peru
> >> >>>>> project?
> >> >>>>> Thanks in advance
> >> >>>>> Best,
> >> >>>>> William
> >> >>>>> From: "Yaw Anokwa"
> >> >>>>> Sent: Tuesday, November 22, 2011 11:12 AM
> >> >>>>> To:
> >> >>>>>> daniel, james and sarah,
> >> >>>>>> please be careful about sending out attachments on the list.
> >> >>>>>> if you can use dropbox for files or pastie/dpaste for forms and send
> >> >>>>>> out a link, i think our users with low bandwidth would really
> >> >>>>>> appreciate it.
> >> >>>>>> On Tue, Nov 22, 2011 at 08:02, Daniel Kayiwa wrote:
> >> >>>>>>> Hi James, am trying to investigate what could be the problem.
> >> >>>>>>> Do you mind trying to install the attached apk and tell me how it
> >> >>>>>>> goes?
> >> >>>>>>> On Tue, Nov 22, 2011 at 5:28 PM, James Arbaugh wrote:
> >> >>>>>>>> Thanks everyone for your suggestions and information.
> >> >>>>>>>> The URL setting in the mobile app is http://10.1.1.5:8081/openmrs
> >> >>>>>>>> For the record, the url works when I use the emulator's web
> >> >>>>>>>> browser.
> >> >>>>>>>> I wasn't seeing any errors in the tomcat log when I tried to
> >> >>>>>>>> connect
> >> >>>>>>>> with ODK Clinic/Connect. I decided to uninstall xforms, remove the
> >> >>>>>>>> global properties and xforms tables from the database to have a
> >> >>>>>>>> clean
> >> >>>>>>>> start. The tables weren't created for me automatically when I
> >> >>>>>>>> tried
> >> >>>>>>>> to load 4.0.8, and xforms failed to start. (Is this a known bug?)
> >> >>>>>>>> I
> >> >>>>>>>> rolled back to 3.8.8, and then upgraded to xforms module version
> >> >>>>>>>> 4.0.8. I then created a simple xform;
> >> >>>>>>>> http://pastebin.com/download.php?i=3scc2viH.
> >> >>>>>>>> I also created a cohort with just one patient, in case the other
> >> >>>>>>>> cohorts were too large. I also chose the weight concept as the
> >> >>>>>>>> "medical history field".
> >> >>>>>>>> When I try to download the cohort with just one patient (in ODK
> >> >>>>>>>> Clinic) it downloads (after showing the error). When I click to
> >> >>>>>>>> select the patient, ODK Clinic crashed with the error "Sorry! The
> >> >>>>>>>> application ODK Clinic (process org.odk.clinic android) has stopped
> >> >>>>>>>> unexpetedly. Please try again. Force Close" I tried restarting the
> >> >>>>>>>> phone emulator, with the same results. I tried to set the xforms
> >> >>>>>>>> property from purc forms to javarosa, it still didn't work.
> >> >>>>>>>> The version of ODK Collect is 1.1 per the app. In the Application
> >> >>>>>>>> Info, it's ODK Collect version 3. The version of Clinic is v0.0.1
> >> >>>>>>>> per
> >> >>>>>>>> the app. Per the Application Info it's ODK Clinic version 1.
> >> >>>>>>>> In all of this I have never seen anything unusual in the OpenMRS
> >> >>>>>>>> catalina.out log file.
> >> >>>>>>>> At this point, the ability to fill out forms into OpenMRS is the
> >> >>>>>>>> most
> >> >>>>>>>> important; which makes Collect more important than Clinic.
> >> >>>>>>>> Any other thoughts?
> >> >>>>>>>> Thanks,
> >> >>>>>>>> James
> >> >>>>>>>> On Nov 22, 4:01 am, Daniel Kayiwa wrote:
> >> >>>>>>>> > Hi James,
> >> >>>>>>>> > What value do you have in the url setting on the mobile app?
> >> >>>>>>>> > Can you also put your tomcat log contents on pastebin.com and
> >> >>>>>>>> > send
> >> >>>>>>>> > > me
> >> >>>>>>>> > the
> >> >>>>>>>> > url?
> >> >>>>>>>> > On Mon, Nov 21, 2011 at 11:47 PM, James Arbaugh wrote:
> >> >>>>>>>> > > We are looking to use ODK to collect data for patients, it
> >> >>>>>>>> > > would
> >> >>>>>>>> > > > then
> >> >>>>>>>> > > be stored in OpenMRS.
> >> >>>>>>>> > > I'm having trouble getting things to play nicely together.
> >> >>>>>>>> > > I've
> >> >>>>>>>> > > > tried
> >> >>>>>>>> > > various versions of ODK Collect/Clinic using the Android > >
> >> >>>>>>>> > > emulator,
> >> >>>>>>>> > > with our implementation of OpenMRS. I have also tried various
> >> >>>>>>>> > > versions of the XForms module. What I see on screen casts
> >> >>>>>>>> > > looks
> >> >>>>>>>> > > different from what I see on what I have downloaded in Clinic
> >> >>>>>>>> > > and
> >> >>>>>>>> > > Collect. Can someone point me to the right version of ODK to >
> >> >>>>>>>> > > talk
> >> >>>>>>>> > > > > to
> >> >>>>>>>> > > OpenMRS.
> >> >>>>>>>> > > We have OpenMRS Version: 1.8.2 Build 21762 in production.
> >> >>>>>>>> > > Currently installed are Reporting Compatibility 1.5.4.1, and >
> >> >>>>>>>> > > XForms
> >> >>>>>>>> > > 4.0.8.
> >> >>>>>>>> > > The emulator is using Android 2.1 (the same version of the
> >> >>>>>>>> > > phone
> >> >>>>>>>> > > > that
> >> >>>>>>>> > > we want to try).
> >> >>>>>>>> > > When I try ODK Clinic, I see the list of Cohorts, but none of >
> >> >>>>>>>> > > them
> >> >>>>>>>> > > download when selected. "Error: inflating: unknown compression
> >> >>>>>>>> > > method." The XForms global property "xforms.xformSerializer"
> >> >>>>>>>> > > is
> >> >>>>>>>> > > set
> >> >>>>>>>> > > to "org.fcitmuk.epihandy.EpihandyXformSerializer" I have
> >> >>>>>>>> > > chosen
> >> >>>>>>>> > > medical history for download, the hospital ward and discharge >
> >> >>>>>>>> > > date.
> >> >>>>>>>> > > When I try ODK Collect, with the Server Type set to "OpenMRS
> >> >>>>>>>> > > XForm",
> >> >>>>>>>> > > when I try to download forms it says, "Sorry, unable to load >
> >> >>>>>>>> > > remote
> >> >>>>>>>> > > form list!" I do have a simple XForm on the OpenMRS server.
> >> >>>>>>>> > > Can someone please tell me where to get started and which ODK >
> >> >>>>>>>> > > version
> >> >>>>>>>> > > I should be using, and where I can get it.
> >> >>>>>>>> > > Thanks,
> >> >>>>>>>> > > James
> >> >>>>>>>> Post: opend...@googlegroups.com
> >> >>>>>>>> Unsubscribe: opendatakit...@googlegroups.com
> >> >>>>>>>> Options: http://groups.google.com/group/opendatakit?hl=en
> >> >>>>>>> If we keep uppermost in our minds the unkind and unjust acts of
> >> >>>>>>> others,
> >> >>>>>>> we
> >> >>>>>>> shall find it impossible to love them as Christ has loved us; but if
> >> >>>>>>> our
> >> >>>>>>> thoughts dwell upon the wondrous love and pity of Christ for us, the
> >> >>>>>>> same
> >> >>>>>>> spirit will flow out to others.
> >> >>>> If we keep uppermost in our minds the unkind and unjust acts of others,
> >> >>>> we
> >> >>>> our
> >> >>>> same
> > You received this message because you are subscribed to the Google Groups "ODK Community" group.
> > To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit...@googlegroups.com.
> You received this message because you are subscribed to a topic in the Google Groups "ODK Community" group.
> To unsubscribe from this topic, visit https://groups.google.com/d/topic/opendatakit/NS_wxePHyaM/unsubscribe.
> To unsubscribe from this group and all its topics, send an email to opendatakit...@googlegroups.com.
Nidhi,
OpenMRS has to implement the Collect-Aggregate API outlined at
http://opendatakit.org/use/aggregate/data-transfer/#APIs.
Traditionally, this has been done through the XForms module at
https://wiki.openmrs.org/display/docs/XForms+Module. What URLs it uses
is a question for the OpenMRS community. If you are looking for a
name, Daniel Kayiwa is the guy to talk to.
Nidhi
On Tue, May 27, 2014 at 3:39 AM, tas Talhaah...@iiitd.ac.in wrote:
Hi
William
To: opend...@googlegroups.com
On Tue, Feb 7, 2012 at 08:41, William Aviles Monterrey wra...@gmail.com wrote:
Hi Yaw, Daniel
just
Best
William
William,
month or two.
On Sat, Feb 4, 2012 at 09:45, Daniel Kayiwa kayiwa...@gmail.com wrote:
Hi William,
changes
since then.
On Sat, Feb 4, 2012 at 12:16 AM, William Aviles Monterrey wra...@gmail.com wrote:
connect
1.6
- xForms 4.9. Do you happen to know if this apk was built with the
repository here:
Peru
project?
Thanks in advance
William
appreciate it.
goes?
browser.
connect
clean
tried
I
per
most
Any other thoughts?
James
On Nov 22, 4:01 am, Daniel Kayiwa kayiwadan...@gmail.com wrote:
Hi James,
send
me
the
url?
would
then
I've
tried
emulator,
looks
and
talk
to
OpenMRS.
XForms
4.0.8.
phone
that
we want to try).
them
is
set
chosen
date.
XForm",
remote
version
James
others,
we
our
same
we
our
same
