We are looking to use ODK to collect data for patients, it would then
be stored in OpenMRS.
I'm having trouble getting things to play nicely together. I've tried
various versions of ODK Collect/Clinic using the Android emulator,
with our implementation of OpenMRS. I have also tried various
versions of the XForms module. What I see on screen casts looks
different from what I see on what I have downloaded in Clinic and
Collect. Can someone point me to the right version of ODK to talk to
OpenMRS.
We have OpenMRS Version: 1.8.2 Build 21762 in production.
Currently installed are Reporting Compatibility 1.5.4.1, and XForms
4.0.8.
The emulator is using Android 2.1 (the same version of the phone that
we want to try).
When I try ODK Clinic, I see the list of Cohorts, but none of them
download when selected. "Error: inflating: unknown compression
method." The XForms global property "xforms.xformSerializer" is set
to "org.fcitmuk.epihandy.EpihandyXformSerializer" I have chosen
medical history for download, the hospital ward and discharge date.
When I try ODK Collect, with the Server Type set to "OpenMRS XForm",
when I try to download forms it says, "Sorry, unable to load remote
form list!" I do have a simple XForm on the OpenMRS server.
Can someone please tell me where to get started and which ODK version
I should be using, and where I can get it.
James
P.S. the XForm on the server has the following definition...
<?xml version="1.0" encoding="UTF-8"?><xf:xforms xmlns:xf="http://www.w3.org/2002/xforms" xmlns:xsd="http://
www.w3.org/2001/XMLSchema" xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:jr="http://
openrosa.org/javarosa">
<xf:model id="openmrs_model">
<xf:instance id="openmrs_model_instance">
<date_entered/>
<patient.birthdate_estimated openmrs_table="patient"
openmrs_attribute="birthdate_estimated"/>
<patient.family_name openmrs_table="patient_name"
openmrs_attribute="family_name"/>
<patient.given_name openmrs_table="patient_name"
openmrs_attribute="given_name"/>
<patient.middle_name openmrs_table="patient_name"
openmrs_attribute="middle_name"/>
<patient.patient_id openmrs_table="patient"
openmrs_attribute="patient_id"/>
<patient.sex openmrs_table="patient"
openmrs_attribute="gender"/>
<patient.birthdate openmrs_table="patient"
openmrs_attribute="birthdate"/>
<patient.tribe openmrs_table="patient"
openmrs_attribute="tribe"/>
<patient_address.address1 openmrs_table="patient_address"
openmrs_attribute="address1"/>
<patient.medical_record_number
openmrs_table="patient_identifier" openmrs_attribute="identifier"/>
<patient_address.address2 openmrs_table="patient_address"
openmrs_attribute="address2"/>
<encounter.encounter_datetime openmrs_table="encounter"
openmrs_attribute="encounter_datetime">'today()'</
encounter.encounter_datetime>
<encounter.location_id openmrs_table="encounter"
openmrs_attribute="location_id">15</encounter.location_id>
<encounter.provider_id openmrs_table="encounter"
openmrs_attribute="provider_id"/>
<money_paid openmrs_concept="1719^MONEY PAID^99DCT"
openmrs_datatype="NM">
</money_paid>
<temperature_c openmrs_concept="5088^TEMPERATURE (C)^99DCT"
</temperature_c>
<systolic_blood_pressure openmrs_concept="5085^SYSTOLIC
BLOOD PRESSURE^99DCT" openmrs_datatype="NM">
</systolic_blood_pressure>
<diastolic_blood_pressure openmrs_concept="5086^DIASTOLIC
</diastolic_blood_pressure>
<dispensary_medication openmrs_concept="3094^DISPENSARY
MEDICATION^99DCT" openmrs_datatype="ST">
<patient_stage openmrs_concept="3092^PATIENT STAGE^99DCT"
openmrs_datatype="CWE" multiple="0">
</patient_stage>
<medication_code openmrs_concept="3093^MEDICATION
CODE^99DCT" openmrs_datatype="CWE" multiple="0">
</medication_code>
</dispensary_medication>
<weight_kg openmrs_concept="5089^WEIGHT (KG)^99DCT"
</weight_kg>
<encounter_type openmrs_concept="3100^ENCOUNTER
TYPE^99DCT" openmrs_datatype="CWE" multiple="0">
</encounter_type>
<diagnosis_type openmrs_concept="3104^DIAGNOSIS
</diagnosis_type>
<diagnosis_id openmrs_concept="2879^DIAGNOSIS SET^99DCT"
</diagnosis_id>
<return_visit_date openmrs_concept="5096^RETURN VISIT
DATE^99DCT" openmrs_datatype="DT">
</return_visit_date>
<has_referral_date openmrs_concept="3097^HAS REFERRAL DATE
</has_referral_date>
<unit_out openmrs_concept="3096^UNIT OUT^99DCT"
openmrs_datatype="BIT">
</unit_out>
<unit_in openmrs_concept="3095^UNIT IN^99DCT"
</unit_in>
</xf:instance>
<xf:bind id="patient.birthdate_estimated" nodeset="/form/patient/
patient.birthdate_estimated" type="xsd:boolean" locked="true()"/>
<xf:bind id="patient.family_name" nodeset="/form/patient/
patient.family_name" type="xsd:string" locked="true()"
jr:preload="patient" jr:preloadParams="familyName"/>
<xf:bind id="patient.given_name" nodeset="/form/patient/
patient.given_name" type="xsd:string" locked="true()"
jr:preload="patient" jr:preloadParams="givenName"/>
<xf:bind id="patient.middle_name" nodeset="/form/patient/
patient.middle_name" type="xsd:string" locked="true()"
jr:preload="patient" jr:preloadParams="middleName"/>
<xf:bind id="patient.patient_id" nodeset="/form/patient/
patient.patient_id" type="xsd:int" required="true()" visible="false()"
jr:preload="patient" jr:preloadParams="patientId"/>
<xf:bind id="patient.sex" nodeset="/form/patient/patient.sex"
type="xsd:string" locked="true()" jr:preload="patient"
jr:preloadParams="sex"/>
<xf:bind id="patient.birthdate" nodeset="/form/patient/
patient.birthdate" type="xsd:date" locked="true()"
jr:preload="patient" jr:preloadParams="birthDate"/>
<xf:bind id="patient.tribe" nodeset="/form/patient/patient.tribe"
type="xsd:string" locked="true()"/>
<xf:bind id="patient_address.address1" nodeset="/form/patient/
patient_address.address1" type="xsd:string" locked="true()"/>
<xf:bind id="patient.medical_record_number" nodeset="/form/patient/
patient.medical_record_number" type="xsd:string" locked="true()"
jr:preload="patient" jr:preloadParams="patientIdentifier"/>
<xf:bind id="patient_address.address2" nodeset="/form/patient/
patient_address.address2" type="xsd:string" locked="true()"/>
<xf:bind id="encounter.encounter_datetime" nodeset="/form/
encounter/encounter.encounter_datetime" type="xsd:date" constraint=".
<= today()" message="Encounter date cannot be after today"
required="true()"/>
<xf:bind id="encounter.location_id" nodeset="/form/encounter/
encounter.location_id" type="xsd:string" required="true()"/>
<xf:bind id="encounter.provider_id" nodeset="/form/encounter/
encounter.provider_id" type="xsd:string" required="true()"/>
<xf:bind id="money_paid" nodeset="/form/obs/money_paid/value"
constraint=". >= 0.0 and . <= 100.0" message="value should be
between 0.0 and 100.0 inclusive" type="xsd:decimal"/>
<xf:bind id="temperature_c" nodeset="/form/obs/temperature_c/
value" constraint=". >= 25.0 and . <= 43.0" message="value
should be between 25.0 and 43.0 inclusive" type="xsd:decimal"/>
<xf:bind id="systolic_blood_pressure" nodeset="/form/obs/
systolic_blood_pressure/value" constraint=". >= 0 and . <= 150"
message="value should be between 0 and 150 inclusive"
<xf:bind id="diastolic_blood_pressure" nodeset="/form/obs/
diastolic_blood_pressure/value" constraint=". >= 0 and . <= 150"
<xf:bind id="dispensary_medication" nodeset="/form/obs/
dispensary_medication" type="xsd:string"/>
<xf:bind id="patient_stage" nodeset="/form/obs/
dispensary_medication/patient_stage/value" type="xsd:string"/>
<xf:bind id="medication_code" nodeset="/form/obs/
dispensary_medication/medication_code/value" type="xsd:string"/>
<xf:bind id="weight_kg" nodeset="/form/obs/weight_kg/value"
constraint=". >= 0.0 and . <= 250.0" message="value should be
between 0.0 and 250.0 inclusive" type="xsd:decimal"/>
<xf:bind id="diagnosis" nodeset="/form/obs/diagnosis"
type="xsd:string"/>
<xf:bind id="encounter_type" nodeset="/form/obs/diagnosis/
encounter_type/value" type="xsd:string"/>
<xf:bind id="diagnosis_type" nodeset="/form/obs/diagnosis/
diagnosis_type/value" type="xsd:string"/>
<xf:bind id="diagnosis_id" nodeset="/form/obs/diagnosis/
diagnosis_id/value" type="xsd:string"/>
<xf:bind id="return_visit_date" nodeset="/form/obs/
return_visit_date/value" type="xsd:date"/>
<xf:bind id="has_referral_date" nodeset="/form/obs/
has_referral_date/value" type="xsd:date"/>
<xf:bind id="unit_out" nodeset="/form/obs/unit_out/value"
type="xsd:boolean"/>
<xf:bind id="unit_in" nodeset="/form/obs/unit_in/value"
</xf:model>
<xf:group id="1">
xf:labelPage1</xf:label>
<xf:input bind="patient.birthdate_estimated">
xf:labelBIRTHDATE ESTIMATED</xf:label>
</xf:input>
<xf:input bind="patient.family_name">
xf:labelFAMILY NAME</xf:label>
</xf:input>
<xf:input bind="patient.given_name">
xf:labelGIVEN NAME</xf:label>
</xf:input>
<xf:input bind="patient.middle_name">
xf:labelMIDDLE NAME</xf:label>
</xf:input>
<xf:input bind="patient.patient_id">
xf:labelPATIENT ID</xf:label>
</xf:input>
<xf:input bind="patient.sex">
xf:labelSEX</xf:label>
</xf:input>
<xf:input bind="patient.birthdate">
xf:labelBIRTHDATE</xf:label>
</xf:input>
<xf:input bind="patient.tribe">
xf:labelTRIBE</xf:label>
</xf:input>
<xf:input bind="patient_address.address1">
xf:labelADDRESS1</xf:label>
</xf:input>
<xf:input bind="patient.medical_record_number">
xf:labelMEDICAL RECORD NUMBER</xf:label>
</xf:input>
<xf:input bind="patient_address.address2">
xf:labelADDRESS2</xf:label>
</xf:input>
<xf:input bind="encounter.encounter_datetime">
xf:labelENCOUNTER DATETIME</xf:label>
</xf:input>
<xf:select1 bind="encounter.location_id">
xf:labelLOCATION ID</xf:label>
<xf:item id="10">
xf:labelUF10 - LACHAPELLE [10]</xf:label>
xf:value10</xf:value>
</xf:item>
<xf:item id="11">
xf:labelUF11 - MEDOR [11]</xf:label>
xf:value11</xf:value>
</xf:item>
<xf:item id="12">
xf:labelUF12 - PERODIN [12]</xf:label>
xf:value12</xf:value>
</xf:item>
<xf:item id="13">
xf:labelUF13 - JEAN DENIS [13]</xf:label>
xf:value13</xf:value>
</xf:item>
<xf:item id="14">
xf:labelUF14 - JEAN DENIS [14]</xf:label>
xf:value14</xf:value>
</xf:item>
<xf:item id="3">
xf:labelUF3 - DESARMES [3]</xf:label>
xf:value3</xf:value>
</xf:item>
<xf:item id="6">
xf:labelUF6 - TERNETTE [6]</xf:label>
xf:value6</xf:value>
</xf:item>
<xf:item id="7">
xf:labelUF7 - PETITE RIVIERE ARTIBONITE [7]</xf:label>
xf:value7</xf:value>
</xf:item>
<xf:item id="16">
xf:label11001 - TETE SOUS [16]</xf:label>
xf:value16</xf:value>
</xf:item>
<xf:item id="17">
xf:label11002 - MAHOUE [17]</xf:label>
xf:value17</xf:value>
</xf:item>
<xf:item id="18">
xf:label11003 - BASSE COUR [18]</xf:label>
xf:value18</xf:value>
</xf:item>
<xf:item id="19">
xf:label11004 - BOIS NEUF [19]</xf:label>
xf:value19</xf:value>
</xf:item>
<xf:item id="20">
xf:label11005 - L'ALLEE JOSEE [20]</xf:label>
xf:value20</xf:value>
</xf:item>
<xf:item id="21">
xf:label11006 - MARSEILLE [21]</xf:label>
xf:value21</xf:value>
</xf:item>
<xf:item id="22">
xf:label11007 - ACHIN [22]</xf:label>
xf:value22</xf:value>
</xf:item>
<xf:item id="23">
xf:label11008 - HAUT DIGUE [23]</xf:label>
xf:value23</xf:value>
</xf:item>
<xf:item id="24">
xf:label11010 - ESTRAL [24]</xf:label>
xf:value24</xf:value>
</xf:item>
<xf:item id="25">
xf:label11011 - PAYEN I [25]</xf:label>
xf:value25</xf:value>
</xf:item>
<xf:item id="26">
xf:label11012 - HAUT CANNE [26]</xf:label>
xf:value26</xf:value>
</xf:item>
<xf:item id="27">
xf:label11013 - VILETTE [27]</xf:label>
xf:value27</xf:value>
</xf:item>
<xf:item id="28">
xf:label11014 - PAYEN II [28]</xf:label>
xf:value28</xf:value>
</xf:item>
<xf:item id="29">
xf:label11015 - PAYEN III [29]</xf:label>
xf:value29</xf:value>
</xf:item>
<xf:item id="30">
xf:label11019 - FOND CASTRA II [30]</xf:label>
xf:value30</xf:value>
</xf:item>
<xf:item id="31">
xf:label11020 - CASTRA I [31]</xf:label>
xf:value31</xf:value>
</xf:item>
<xf:item id="32">
xf:label11021 - CASTRA II [32]</xf:label>
xf:value32</xf:value>
</xf:item>
<xf:item id="33">
xf:label11022 - DEZELLE CASTRA [33]</xf:label>
xf:value33</xf:value>
</xf:item>
<xf:item id="34">
xf:label11023 - FOND CASTRA I [34]</xf:label>
xf:value34</xf:value>
</xf:item>
<xf:item id="35">
xf:label11024 - BOIS CASTRA I [35]</xf:label>
xf:value35</xf:value>
</xf:item>
<xf:item id="36">
xf:label11025 - BOIS CASTRA II [36]</xf:label>
xf:value36</xf:value>
</xf:item>
<xf:item id="37">
xf:label11026 - LIANCOURT I [37]</xf:label>
xf:value37</xf:value>
</xf:item>
<xf:item id="38">
xf:label11027 - LIANCOURT II [38]</xf:label>
xf:value38</xf:value>
</xf:item>
<xf:item id="39">
xf:label11028 - LIANCOURT III [39]</xf:label>
xf:value39</xf:value>
</xf:item>
<xf:item id="40">
xf:label11029 - LIANCOURT IV [40]</xf:label>
xf:value40</xf:value>
</xf:item>
<xf:item id="41">
xf:label11030 - LIANCOURT V [41]</xf:label>
xf:value41</xf:value>
</xf:item>
<xf:item id="42">
xf:label11031 - LIANCOURT VI [42]</xf:label>
xf:value42</xf:value>
</xf:item>
<xf:item id="43">
xf:label11032 - LIANCOURT VII [43]</xf:label>
xf:value43</xf:value>
</xf:item>
<xf:item id="44">
xf:label11033 - COMON [44]</xf:label>
xf:value44</xf:value>
</xf:item>
<xf:item id="45">
xf:label11034 - DO COMON [45]</xf:label>
xf:value45</xf:value>
</xf:item>
<xf:item id="46">
xf:label11040 - MASSICOT II [46]</xf:label>
xf:value46</xf:value>
</xf:item>
<xf:item id="47">
xf:label11041 - MASSICOT I [47]</xf:label>
xf:value47</xf:value>
</xf:item>
<xf:item id="48">
xf:label11043 - MAROTTE [48]</xf:label>
xf:value48</xf:value>
</xf:item>
<xf:item id="49">
xf:label11060 - MOREAU LIANCOURT I [49]</xf:label>
xf:value49</xf:value>
</xf:item>
<xf:item id="50">
xf:label11070 - DROUETTE I [50]</xf:label>
xf:value50</xf:value>
</xf:item>
<xf:item id="51">
xf:label11071 - DROUETTE II [51]</xf:label>
xf:value51</xf:value>
</xf:item>
<xf:item id="52">
xf:label11072 - BOIS CHANDELE [52]</xf:label>
xf:value52</xf:value>
</xf:item>
<xf:item id="53">
xf:label11073 - DROUETTE III [53]</xf:label>
xf:value53</xf:value>
</xf:item>
<xf:item id="54">
xf:label11074 - MOREAU LIANCOURT II [54]</xf:label>
xf:value54</xf:value>
</xf:item>
<xf:item id="55">
xf:label11080 - HATTE POTERY [55]</xf:label>
xf:value55</xf:value>
</xf:item>
<xf:item id="56">
xf:label11090 - POTERY [56]</xf:label>
xf:value56</xf:value>
</xf:item>
<xf:item id="57">
xf:label11101 - PONT SONDE [57]</xf:label>
xf:value57</xf:value>
</xf:item>
<xf:item id="58">
xf:label12007 - SOURCE PINOTTE [58]</xf:label>
xf:value58</xf:value>
</xf:item>
<xf:item id="59">
xf:label12008 - NAN DIENDA [59]</xf:label>
xf:value59</xf:value>
</xf:item>
<xf:item id="60">
xf:label12009 - DESCHAPELLES CORRIDOR II [60]</xf:label>
xf:value60</xf:value>
</xf:item>
<xf:item id="61">
xf:label12010 - DESCHAPELLES CITE [61]</xf:label>
xf:value61</xf:value>
</xf:item>
<xf:item id="62">
xf:label12011 - DESCHAPELLES VV [62]</xf:label>
xf:value62</xf:value>
</xf:item>
<xf:item id="63">
xf:label12012 - DESCHAPELLES CORRIDOR I [63]</xf:label>
xf:value63</xf:value>
</xf:item>
<xf:item id="64">
xf:label12013 - DESCHAPELLES VB [64]</xf:label>
xf:value64</xf:value>
</xf:item>
<xf:item id="65">
xf:label12014 - DESCHAPELLES VE [65]</xf:label>
xf:value65</xf:value>
</xf:item>
<xf:item id="66">
xf:label12015 - DESCHAPELLES DM [66]</xf:label>
xf:value66</xf:value>
</xf:item>
<xf:item id="67">
xf:label12016 - A COTE DESCHAPELLES [67]</xf:label>
xf:value67</xf:value>
</xf:item>
<xf:item id="68">
xf:label12017 - DER DESCHAPELLES [68]</xf:label>
xf:value68</xf:value>
</xf:item>
<xf:item id="69">
xf:label12018 - SOURCE MARGUERITE [69]</xf:label>
xf:value69</xf:value>
</xf:item>
<xf:item id="70">
xf:label12019 - LES FORGES [70]</xf:label>
xf:value70</xf:value>
</xf:item>
<xf:item id="71">
xf:label12020 - DODARD VV [71]</xf:label>
xf:value71</xf:value>
</xf:item>
<xf:item id="72">
xf:label12021 - DODARD VB [72]</xf:label>
xf:value72</xf:value>
</xf:item>
<xf:item id="73">
xf:label12022 - JUMELLE [73]</xf:label>
xf:value73</xf:value>
</xf:item>
<xf:item id="74">
xf:label12028 - MORNE CANOT [74]</xf:label>
xf:value74</xf:value>
</xf:item>
<xf:item id="75">
xf:label12029 - HATTE BELANGER [75]</xf:label>
xf:value75</xf:value>
</xf:item>
<xf:item id="76">
xf:label12030 - HATTE BELANGER II [76]</xf:label>
xf:value76</xf:value>
</xf:item>
<xf:item id="77">
xf:label12031 - LA COUR VALMEY [77]</xf:label>
xf:value77</xf:value>
</xf:item>
<xf:item id="78">
xf:label12032 - BOIS D'HOMME TAMPE [78]</xf:label>
xf:value78</xf:value>
</xf:item>
<xf:item id="79">
xf:label12033 - FOND BELANGER [79]</xf:label>
xf:value79</xf:value>
</xf:item>
<xf:item id="80">
xf:label12040 - DESJARDINS [80]</xf:label>
xf:value80</xf:value>
</xf:item>
<xf:item id="81">
xf:label12041 - PONT PAREMONT [81]</xf:label>
xf:value81</xf:value>
</xf:item>
<xf:item id="82">
xf:label12042 - FERE [82]</xf:label>
xf:value82</xf:value>
</xf:item>
<xf:item id="83">
xf:label12050 - MOREAU DES ILES [83]</xf:label>
xf:value83</xf:value>
</xf:item>
<xf:item id="84">
xf:label12051 - BOIS BLANC [84]</xf:label>
xf:value84</xf:value>
</xf:item>
<xf:item id="85">
xf:label12060 - MORNE CHARLES [85]</xf:label>
xf:value85</xf:value>
</xf:item>
<xf:item id="86">
xf:label12061 - CA CHARLES [86]</xf:label>
xf:value86</xf:value>
</xf:item>
<xf:item id="87">
xf:label12070 - MARECAGE [87]</xf:label>
xf:value87</xf:value>
</xf:item>
<xf:item id="88">
xf:label12071 - DER. MARECAGE [88]</xf:label>
xf:value88</xf:value>
</xf:item>
<xf:item id="89">
xf:label12078 - CA VERRETTES [89]</xf:label>
xf:value89</xf:value>
</xf:item>
<xf:item id="90">
xf:label12080 - ANGER I [90]</xf:label>
xf:value90</xf:value>
</xf:item>
<xf:item id="91">
xf:label12081 - ANGER II [91]</xf:label>
xf:value91</xf:value>
</xf:item>
<xf:item id="92">
xf:label12090 - HATTE BOREL [92]</xf:label>
xf:value92</xf:value>
</xf:item>
<xf:item id="93">
xf:label12091 - VERRETTES [93]</xf:label>
xf:value93</xf:value>
</xf:item>
<xf:item id="94">
xf:label12092 - VERRETTES [94]</xf:label>
xf:value94</xf:value>
</xf:item>
<xf:item id="95">
xf:label12093 - HAUT VERRETTES [95]</xf:label>
xf:value95</xf:value>
</xf:item>
<xf:item id="96">
xf:label12095 - REPLOU [96]</xf:label>
xf:value96</xf:value>
</xf:item>
<xf:item id="97">
xf:label12096 - MASSEAU [97]</xf:label>
xf:value97</xf:value>
</xf:item>
<xf:item id="98">
xf:label12110 - BOREL [98]</xf:label>
xf:value98</xf:value>
</xf:item>
<xf:item id="99">
xf:label12111 - BOREL [99]</xf:label>
xf:value99</xf:value>
</xf:item>
<xf:item id="100">
xf:label12118 - COUPON I [100]</xf:label>
xf:value100</xf:value>
</xf:item>
<xf:item id="101">
xf:label12119 - COUPON II [101]</xf:label>
xf:value101</xf:value>
</xf:item>
<xf:item id="102">
xf:label12120 - COUPON III [102]</xf:label>
xf:value102</xf:value>
</xf:item>
<xf:item id="103">
xf:label12121 - BOIS CORNE [103]</xf:label>
xf:value103</xf:value>
</xf:item>
<xf:item id="104">
xf:label12130 - BELANGER [104]</xf:label>
xf:value104</xf:value>
</xf:item>
<xf:item id="105">
xf:label12140 - CHANEL [105]</xf:label>
xf:value105</xf:value>
</xf:item>
<xf:item id="106">
xf:label12141 - MIRAULT [106]</xf:label>
xf:value106</xf:value>
</xf:item>
<xf:item id="107">
xf:label12142 - CHANDELLE [107]</xf:label>
xf:value107</xf:value>
</xf:item>
<xf:item id="108">
xf:label12143 - TI CHANDELLE [108]</xf:label>
xf:value108</xf:value>
</xf:item>
<xf:item id="109">
xf:label12150 - SAVARY [109]</xf:label>
xf:value109</xf:value>
</xf:item>
<xf:item id="110">
xf:label12151 - TI ROCHER [110]</xf:label>
xf:value110</xf:value>
</xf:item>
<xf:item id="111">
xf:label12160 - ROSALIE [111]</xf:label>
xf:value111</xf:value>
</xf:item>
<xf:item id="112">
xf:label12161 - COQUILLOT II [112]</xf:label>
xf:value112</xf:value>
</xf:item>
<xf:item id="113">
xf:label12162 - TITON [113]</xf:label>
xf:value113</xf:value>
</xf:item>
<xf:item id="114">
xf:label12163 - RAYMONETTE [114]</xf:label>
xf:value114</xf:value>
</xf:item>
<xf:item id="115">
xf:label12164 - RONDO [115]</xf:label>
xf:value115</xf:value>
</xf:item>
<xf:item id="116">
xf:label12165 - COQUILLOT I [116]</xf:label>
xf:value116</xf:value>
</xf:item>
<xf:item id="117">
xf:label12170 - CHANCLOTTE [117]</xf:label>
xf:value117</xf:value>
</xf:item>
<xf:item id="118">
xf:label12171 - NAN CASE [118]</xf:label>
xf:value118</xf:value>
</xf:item>
<xf:item id="119">
xf:label12180 - JEANTON [119]</xf:label>
xf:value119</xf:value>
</xf:item>
<xf:item id="120">
xf:label14013 - CA BOIS [120]</xf:label>
xf:value120</xf:value>
</xf:item>
<xf:item id="121">
xf:label14014 - SAINTONGE [121]</xf:label>
xf:value121</xf:value>
</xf:item>
<xf:item id="122">
xf:label14015 - LEVEQUE [122]</xf:label>
xf:value122</xf:value>
</xf:item>
<xf:item id="123">
xf:label14020 - DOUBLETTE [123]</xf:label>
xf:value123</xf:value>
</xf:item>
<xf:item id="124">
xf:label14031 - BIDEAU [124]</xf:label>
xf:value124</xf:value>
</xf:item>
<xf:item id="125">
xf:label14032 - GAUDIN [125]</xf:label>
xf:value125</xf:value>
</xf:item>
<xf:item id="126">
xf:label14041 - TIENNE [126]</xf:label>
xf:value126</xf:value>
</xf:item>
<xf:item id="127">
xf:label14051 - DRICE [127]</xf:label>
xf:value127</xf:value>
</xf:item>
<xf:item id="128">
xf:label14061 - TERRE ROUGE [128]</xf:label>
xf:value128</xf:value>
</xf:item>
<xf:item id="129">
xf:label14064 - TUF GODFOI [129]</xf:label>
xf:value129</xf:value>
</xf:item>
<xf:item id="130">
xf:label14072 - BERNARD [130]</xf:label>
xf:value130</xf:value>
</xf:item>
<xf:item id="131">
xf:label14075 - BOIS BERNARD [131]</xf:label>
xf:value131</xf:value>
</xf:item>
<xf:item id="132">
xf:label14076 - SALEAU [132]</xf:label>
xf:value132</xf:value>
</xf:item>
<xf:item id="133">
xf:label14077 - VIEUX CAILLE [133]</xf:label>
xf:value133</xf:value>
</xf:item>
<xf:item id="134">
xf:label14078 - VERRETTES [134]</xf:label>
xf:value134</xf:value>
</xf:item>
<xf:item id="135">
xf:label14121 - ANTOINE [135]</xf:label>
xf:value135</xf:value>
</xf:item>
<xf:item id="136">
xf:label14122 - FOND ROUE [136]</xf:label>
xf:value136</xf:value>
</xf:item>
<xf:item id="137">
xf:label14130 - CA HUIT I [137]</xf:label>
xf:value137</xf:value>
</xf:item>
<xf:item id="138">
xf:label14131 - CA JULES [138]</xf:label>
xf:value138</xf:value>
</xf:item>
<xf:item id="139">
xf:label14132 - DUCOIN [139]</xf:label>
xf:value139</xf:value>
</xf:item>
<xf:item id="140">
xf:label14133 - NAN TETARD [140]</xf:label>
xf:value140</xf:value>
</xf:item>
<xf:item id="141">
xf:label14135 - CA HUIT II [141]</xf:label>
xf:value141</xf:value>
</xf:item>
<xf:item id="142">
xf:label14136 - DEZILE [142]</xf:label>
xf:value142</xf:value>
</xf:item>
<xf:item id="143">
xf:label14140 - CAZEAU [143]</xf:label>
xf:value143</xf:value>
</xf:item>
<xf:item id="144">
xf:label14141 - CADUC [144]</xf:label>
xf:value144</xf:value>
</xf:item>
<xf:item id="145">
xf:label14142 - LACROIX [145]</xf:label>
xf:value145</xf:value>
</xf:item>
<xf:item id="146">
xf:label14143 - PIECE YOUNE [146]</xf:label>
xf:value146</xf:value>
</xf:item>
<xf:item id="147">
xf:label14150 - GABRIEL PALMISTE [147]</xf:label>
xf:value147</xf:value>
</xf:item>
<xf:item id="148">
xf:label14151 - SOUS BELAIRE [148]</xf:label>
xf:value148</xf:value>
</xf:item>
<xf:item id="149">
xf:label14152 - L'ESPERANCE [149]</xf:label>
xf:value149</xf:value>
</xf:item>
<xf:item id="150">
xf:label14153 - NAN BOIS D'HOMME [150]</xf:label>
xf:value150</xf:value>
</xf:item>
<xf:item id="151">
xf:label14160 - L'EPINARD I [151]</xf:label>
xf:value151</xf:value>
</xf:item>
<xf:item id="152">
xf:label14161 - L'EPINARD II [152]</xf:label>
xf:value152</xf:value>
</xf:item>
<xf:item id="153">
xf:label14162 - ROPISSA [153]</xf:label>
xf:value153</xf:value>
</xf:item>
<xf:item id="154">
xf:label14164 - HERVE [154]</xf:label>
xf:value154</xf:value>
</xf:item>
<xf:item id="155">
xf:label14180 - CHAMPION [155]</xf:label>
xf:value155</xf:value>
</xf:item>
<xf:item id="156">
xf:label14182 - YOBE II [156]</xf:label>
xf:value156</xf:value>
</xf:item>
<xf:item id="157">
xf:label14183 - DEGAGE [157]</xf:label>
xf:value157</xf:value>
</xf:item>
<xf:item id="158">
xf:label14184 - VERRIER [158]</xf:label>
xf:value158</xf:value>
</xf:item>
<xf:item id="159">
xf:label14185 - YOBE I [159]</xf:label>
xf:value159</xf:value>
</xf:item>
<xf:item id="160">
xf:label14190 - MANCEAU [160]</xf:label>
xf:value160</xf:value>
</xf:item>
<xf:item id="161">
xf:label14191 - DUBOURG [161]</xf:label>
xf:value161</xf:value>
</xf:item>
<xf:item id="162">
xf:label14192 - JASMIN [162]</xf:label>
xf:value162</xf:value>
</xf:item>
<xf:item id="163">
xf:label14200 - DESJARDINS [163]</xf:label>
xf:value163</xf:value>
</xf:item>
<xf:item id="164">
xf:label14201 - MOREL [164]</xf:label>
xf:value164</xf:value>
</xf:item>
<xf:item id="165">
xf:label14202 - DIDIER [165]</xf:label>
xf:value165</xf:value>
</xf:item>
<xf:item id="166">
xf:label15008 - ACHIN II [166]</xf:label>
xf:value166</xf:value>
</xf:item>
<xf:item id="167">
xf:label15009 - MICHEL VIELLOT II [167]</xf:label>
xf:value167</xf:value>
</xf:item>
<xf:item id="168">
xf:label15010 - ACHIN I [168]</xf:label>
xf:value168</xf:value>
</xf:item>
<xf:item id="169">
xf:label15011 - SAVANE BOURG [169]</xf:label>
xf:value169</xf:value>
</xf:item>
<xf:item id="170">
xf:label15015 - TRANQUILITE [170]</xf:label>
xf:value170</xf:value>
</xf:item>
<xf:item id="171">
xf:label15016 - ROCHE A PIERRE [171]</xf:label>
xf:value171</xf:value>
</xf:item>
<xf:item id="172">
xf:label15017 - DUMOND [172]</xf:label>
xf:value172</xf:value>
</xf:item>
<xf:item id="173">
xf:label15018 - VIELLOT GESSE II [173]</xf:label>
xf:value173</xf:value>
</xf:item>
<xf:item id="174">
xf:label15019 - VIELLOT GESSE III [174]</xf:label>
xf:value174</xf:value>
</xf:item>
<xf:item id="175">
xf:label15020 - VIELLOT [175]</xf:label>
xf:value175</xf:value>
</xf:item>
<xf:item id="176">
xf:label15021 - VIELLOT GESSE I [176]</xf:label>
xf:value176</xf:value>
</xf:item>
<xf:item id="177">
xf:label15022 - MICHEL VIELLOT I [177]</xf:label>
xf:value177</xf:value>
</xf:item>
<xf:item id="178">
xf:label15023 - LA COUR BADIO [178]</xf:label>
xf:value178</xf:value>
</xf:item>
<xf:item id="179">
xf:label15024 - DESORMEAUX [179]</xf:label>
xf:value179</xf:value>
</xf:item>
<xf:item id="180">
xf:label15025 - COUDOLE [180]</xf:label>
xf:value180</xf:value>
</xf:item>
<xf:item id="181">
xf:label15027 - LABORNE I [181]</xf:label>
xf:value181</xf:value>
</xf:item>
<xf:item id="182">
xf:label15028 - CA LAGUERRE [182]</xf:label>
xf:value182</xf:value>
</xf:item>
<xf:item id="183">
xf:label15029 - MORIN [183]</xf:label>
xf:value183</xf:value>
</xf:item>
<xf:item id="184">
xf:label15030 - DOMINGUE [184]</xf:label>
xf:value184</xf:value>
</xf:item>
<xf:item id="185">
xf:label15031 - DUCASSE [185]</xf:label>
xf:value185</xf:value>
</xf:item>
<xf:item id="186">
xf:label15032 - COLMINY I [186]</xf:label>
xf:value186</xf:value>
</xf:item>
<xf:item id="187">
xf:label15033 - COLMINY II [187]</xf:label>
xf:value187</xf:value>
</xf:item>
<xf:item id="188">
xf:label15034 - COLMINY III [188]</xf:label>
xf:value188</xf:value>
</xf:item>
<xf:item id="189">
xf:label15040 - GODIN GESSE [189]</xf:label>
xf:value189</xf:value>
</xf:item>
<xf:item id="190">
xf:label15050 - DEMENE [190]</xf:label>
xf:value190</xf:value>
</xf:item>
<xf:item id="191">
xf:label15051 - VIELLOT DOLMAN [191]</xf:label>
xf:value191</xf:value>
</xf:item>
<xf:item id="192">
xf:label15061 - GODEFOI [192]</xf:label>
xf:value192</xf:value>
</xf:item>
<xf:item id="193">
xf:label15065 - ROSIER [193]</xf:label>
xf:value193</xf:value>
</xf:item>
<xf:item id="194">
xf:label15070 - SAPOTY [194]</xf:label>
xf:value194</xf:value>
</xf:item>
<xf:item id="195">
xf:label15071 - SAINTANGE [195]</xf:label>
xf:value195</xf:value>
</xf:item>
<xf:item id="196">
xf:label15076 - BIDEAU [196]</xf:label>
xf:value196</xf:value>
</xf:item>
<xf:item id="197">
xf:label15080 - BASTIEN [197]</xf:label>
xf:value197</xf:value>
</xf:item>
<xf:item id="198">
xf:label15081 - ETAN COICOU [198]</xf:label>
xf:value198</xf:value>
</xf:item>
<xf:item id="199">
xf:label15082 - DECOUVERTE [199]</xf:label>
xf:value199</xf:value>
</xf:item>
<xf:item id="200">
xf:label15083 - MODELE [200]</xf:label>
xf:value200</xf:value>
</xf:item>
<xf:item id="201">
xf:label15084 - PENYEN [201]</xf:label>
xf:value201</xf:value>
</xf:item>
<xf:item id="202">
xf:label15092 - MAYAMBE [202]</xf:label>
xf:value202</xf:value>
</xf:item>
<xf:item id="203">
xf:label15093 - CA CHARLES/MORNE CHARLES [203]</xf:label>
xf:value203</xf:value>
</xf:item>
<xf:item id="204">
xf:label15101 - MORTE [204]</xf:label>
xf:value204</xf:value>
</xf:item>
<xf:item id="205">
xf:label15102 - NAN BOIS PIN [205]</xf:label>
xf:value205</xf:value>
</xf:item>
<xf:item id="206">
xf:label15103 - BOIS PIN [206]</xf:label>
xf:value206</xf:value>
</xf:item>
<xf:item id="207">
xf:label15104 - DIJON [207]</xf:label>
xf:value207</xf:value>
</xf:item>
<xf:item id="208">
xf:label15111 - GRAND BOIS DUVERGE [208]</xf:label>
xf:value208</xf:value>
</xf:item>
<xf:item id="209">
xf:label15112 - TI BOIS DUVERGER [209]</xf:label>
xf:value209</xf:value>
</xf:item>
<xf:item id="210">
xf:label15113 - CA BOUILLY [210]</xf:label>
xf:value210</xf:value>
</xf:item>
<xf:item id="211">
xf:label15114 - DUVERGER [211]</xf:label>
xf:value211</xf:value>
</xf:item>
<xf:item id="212">
xf:label15120 - SALASSE II [212]</xf:label>
xf:value212</xf:value>
</xf:item>
<xf:item id="213">
xf:label15121 - HILAIRE [213]</xf:label>
xf:value213</xf:value>
</xf:item>
<xf:item id="214">
xf:label15122 - RAY AU POSTE [214]</xf:label>
xf:value214</xf:value>
</xf:item>
<xf:item id="215">
xf:label15123 - SALASSE I [215]</xf:label>
xf:value215</xf:value>
</xf:item>
<xf:item id="216">
xf:label15124 - NAN DALLE [216]</xf:label>
xf:value216</xf:value>
</xf:item>
<xf:item id="217">
xf:label15125 - TITON [217]</xf:label>
xf:value217</xf:value>
</xf:item>
<xf:item id="218">
xf:label15130 - DAUPHINE [218]</xf:label>
xf:value218</xf:value>
</xf:item>
<xf:item id="219">
xf:label15131 - PIED MOU [219]</xf:label>
xf:value219</xf:value>
</xf:item>
<xf:item id="220">
xf:label15132 - JN DREAU [220]</xf:label>
xf:value220</xf:value>
</xf:item>
<xf:item id="221">
xf:label15133 - FOND MAUGE [221]</xf:label>
xf:value221</xf:value>
</xf:item>
<xf:item id="222">
xf:label15135 - CHEVREAU [222]</xf:label>
xf:value222</xf:value>
</xf:item>
<xf:item id="223">
xf:label15136 - CHAMPION I [223]</xf:label>
xf:value223</xf:value>
</xf:item>
<xf:item id="224">
xf:label15137 - BOIS NEUF [224]</xf:label>
xf:value224</xf:value>
</xf:item>
<xf:item id="225">
xf:label15138 - BARREAU [225]</xf:label>
xf:value225</xf:value>
</xf:item>
<xf:item id="226">
xf:label15139 - HAUT CAMP [226]</xf:label>
xf:value226</xf:value>
</xf:item>
<xf:item id="227">
xf:label15140 - PEROTTE [227]</xf:label>
xf:value227</xf:value>
</xf:item>
<xf:item id="228">
xf:label15141 - CHAMPION II [228]</xf:label>
xf:value228</xf:value>
</xf:item>
<xf:item id="229">
xf:label15142 - DAMIER GESSE I [229]</xf:label>
xf:value229</xf:value>
</xf:item>
<xf:item id="230">
xf:label15143 - DAMIER GESSE II [230]</xf:label>
xf:value230</xf:value>
</xf:item>
<xf:item id="231">
xf:label15151 - LACROIX GESSE [231]</xf:label>
xf:value231</xf:value>
</xf:item>
<xf:item id="232">
xf:label15152 - ZEPELIN [232]</xf:label>
xf:value232</xf:value>
</xf:item>
<xf:item id="233">
xf:label15153 - SOUS MORNE [233]</xf:label>
xf:value233</xf:value>
</xf:item>
<xf:item id="234">
xf:label15154 - SOUS CAMP [234]</xf:label>
xf:value234</xf:value>
</xf:item>
<xf:item id="235">
xf:label15155 - NAN CAFE [235]</xf:label>
xf:value235</xf:value>
</xf:item>
<xf:item id="236">
xf:label15156 - LUBIN [236]</xf:label>
xf:value236</xf:value>
</xf:item>
<xf:item id="237">
xf:label15157 - JN BERTHO [237]</xf:label>
xf:value237</xf:value>
</xf:item>
<xf:item id="238">
xf:label15158 - FERAIL [238]</xf:label>
xf:value238</xf:value>
</xf:item>
<xf:item id="239">
xf:label15159 - FOND LACOU [239]</xf:label>
xf:value239</xf:value>
</xf:item>
<xf:item id="240">
xf:label15160 - CHAMPION III [240]</xf:label>
xf:value240</xf:value>
</xf:item>
<xf:item id="241">
xf:label15161 - MARINO [241]</xf:label>
xf:value241</xf:value>
</xf:item>
<xf:item id="242">
xf:label15162 - LAVERNE [242]</xf:label>
xf:value242</xf:value>
</xf:item>
<xf:item id="243">
xf:label15163 - BERNARD [243]</xf:label>
xf:value243</xf:value>
</xf:item>
<xf:item id="244">
xf:label15165 - GEORGETTE [244]</xf:label>
xf:value244</xf:value>
</xf:item>
<xf:item id="245">
xf:label15166 - CAZEAU [245]</xf:label>
xf:value245</xf:value>
</xf:item>
<xf:item id="15">
xf:labelHOSPITAL - HAS [15]</xf:label>
xf:value15</xf:value>
</xf:item>
<xf:item id="1">
xf:labelUF1 - LIANCOURT [1]</xf:label>
xf:value1</xf:value>
</xf:item>
<xf:item id="2">
xf:labelUF2 - DESCHAPELLES [2]</xf:label>
xf:value2</xf:value>
</xf:item>
<xf:item id="4">
xf:labelUF4 - TIENNE [4]</xf:label>
xf:value4</xf:value>
</xf:item>
<xf:item id="5">
xf:labelUF5 - BASTIEN [5]</xf:label>
xf:value5</xf:value>
</xf:item>
<xf:item id="8">
xf:labelUF8 - PLASSAC [8]</xf:label>
xf:value8</xf:value>
</xf:item>
<xf:item id="9">
xf:labelUF9 - DESLANDES [9]</xf:label>
xf:value9</xf:value>
</xf:item>
</xf:select1>
<xf:select1 bind="encounter.provider_id">
xf:labelPROVIDER ID</xf:label>
<xf:item id="146552">
xf:labelFRESNEL ARISTILDE [146552]</xf:label>
xf:value146552</xf:value>
</xf:item>
<xf:item id="703082">
xf:labelNacha Betty Benoit [703082]</xf:label>
xf:value703082</xf:value>
</xf:item>
<xf:item id="740954">
xf:labelCHOLERA CLINIC [740954]</xf:label>
xf:value740954</xf:value>
</xf:item>
<xf:item id="39">
xf:labelDENTAL CLINIC [39]</xf:label>
</xf:item>
<xf:item id="41">
xf:labelEYE CLINIC [41]</xf:label>
</xf:item>
<xf:item id="37">
xf:labelFAMILY PLANNING CLINIC [37]</xf:label>
</xf:item>
<xf:item id="42">
xf:labelMATERNITE CLINIC [42]</xf:label>
</xf:item>
<xf:item id="43">
xf:labelMEDICINE CLINIC [43]</xf:label>
</xf:item>
<xf:item id="741548">
xf:labelN-ICU CLINIC [741548]</xf:label>
xf:value741548</xf:value>
</xf:item>
<xf:item id="702665">
xf:labelNUTRITION CLINIC [702665]</xf:label>
xf:value702665</xf:value>
</xf:item>
<xf:item id="45">
xf:labelOB/GYN CLINIC [45]</xf:label>
</xf:item>
<xf:item id="48">
xf:labelPANSMAN CLINIC [48]</xf:label>
</xf:item>
<xf:item id="51">
xf:labelPEDIATRIC SURGERY CLINIC [51]</xf:label>
</xf:item>
<xf:item id="47">
xf:labelPEDIATRICS CLINIC [47]</xf:label>
</xf:item>
<xf:item id="50">
xf:labelPHYSICAL THERAPY CLINIC [50]</xf:label>
</xf:item>
<xf:item id="53">
xf:labelSURGERY CLINIC [53]</xf:label>
</xf:item>
<xf:item id="64">
xf:labelTB CONTACT CLINIC [64]</xf:label>
</xf:item>
<xf:item id="726067">
xf:labelAlnave Chalumeaux [726067]</xf:label>
xf:value726067</xf:value>
</xf:item>
<xf:item id="726092">
xf:labelEronie Desilus [726092]</xf:label>
xf:value726092</xf:value>
</xf:item>
<xf:item id="726077">
xf:labelDieudonne Dorsainvil [726077]</xf:label>
xf:value726077</xf:value>
</xf:item>
<xf:item id="729369">
xf:labelDuane Dowell [729369]</xf:label>
xf:value729369</xf:value>
</xf:item>
<xf:item id="726085">
xf:labelVioline Examor [726085]</xf:label>
xf:value726085</xf:value>
</xf:item>
<xf:item id="705322">
xf:labelHoward Gilmore [705322]</xf:label>
xf:value705322</xf:value>
</xf:item>
<xf:item id="737268">
xf:labelDavid Jacob [737268]</xf:label>
xf:value737268</xf:value>
</xf:item>
<xf:item id="725601">
xf:labelPhilip Lerner [725601]</xf:label>
xf:value725601</xf:value>
</xf:item>
<xf:item id="18">
xf:labelJoseph Louis-Aimé [18]</xf:label>
</xf:item>
<xf:item id="739255">
xf:labelPhara Mc Donald [739255]</xf:label>
xf:value739255</xf:value>
</xf:item>
<xf:item id="726088">
xf:labelJeanne Menard [726088]</xf:label>
xf:value726088</xf:value>
</xf:item>
<xf:item id="726090">
xf:labelCeant Marie Nognane [726090]</xf:label>
xf:value726090</xf:value>
</xf:item>
<xf:item id="726082">
xf:labelMarie Michelle Occean [726082]</xf:label>
xf:value726082</xf:value>
</xf:item>
<xf:item id="701550">
xf:labelRonine Occenac [701550]</xf:label>
xf:value701550</xf:value>
</xf:item>
<xf:item id="704686">
xf:labelReynold Paul [704686]</xf:label>
xf:value704686</xf:value>
</xf:item>
<xf:item id="704844">
xf:labelJean Gary Remy [704844]</xf:label>
xf:value704844</xf:value>
</xf:item>
<xf:item id="726096">
xf:labelEtna Senatus [726096]</xf:label>
xf:value726096</xf:value>
</xf:item>
<xf:item id="705434">
xf:labelROSA PAUL THELIUS [705434]</xf:label>
xf:value705434</xf:value>
</xf:item>
<xf:item id="725600">
xf:labelYen-Len Tang [725600]</xf:label>
xf:value725600</xf:value>
</xf:item>
<xf:item id="723699">
xf:labelLab Technician [723699]</xf:label>
xf:value723699</xf:value>
</xf:item>
<xf:item id="705289">
xf:labelJeannine Zeindler [705289]</xf:label>
xf:value705289</xf:value>
</xf:item>
</xf:select1>
<xf:group id="obs/dispensary_medication">
xf:labelDISPENSARY MEDICATION</xf:label>
<xf:repeat bind="dispensary_medication">
<xf:select1 appearance="minimal" bind="patient_stage"
concept_id="3092">
xf:labelPATIENT STAGE</xf:label>
<xf:item concept_id="3089" id="3089^A (ADULT)^99DCT">
xf:labelA (ADULT)</xf:label>
xf:value3089^A (ADULT)^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3091" id="3091^I-P (YOUNG)^99DCT">
xf:labelI-P (YOUNG)</xf:label>
xf:value3091^I-P (YOUNG)^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3090" id="3090^M (A BIT YOUNG)^99DCT">
xf:labelM (A BIT YOUNG)</xf:label>
xf:value3090^M (A BIT YOUNG)^99DCT</xf:value>
</xf:item>
</xf:select1>
<xf:select1 appearance="minimal" bind="medication_code"
concept_id="3093">
xf:labelMEDICATION CODE</xf:label>
<xf:item concept_id="2398" id="2398^TETRACYCLINE OPHT
5G^99DCT">
xf:labelTETRACYCLINE OPHT 5G</xf:label>
xf:value2398^TETRACYCLINE OPHT 5G^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2779" id="2779^OXYGEN 3%^99DCT">
xf:labelOXYGEN 3%</xf:label>
xf:value2779^OXYGEN 3%^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2340" id="2340^CHLOROQUINE 40MG/ML/
5ML^99DCT">
xf:labelCHLOROQUINE 40MG/ML/5ML</xf:label>
xf:value2340^CHLOROQUINE 40MG/ML/5ML^99DCT</xf:value>
</xf:item>
<xf:item concept_id="323" id="323^GENTIAN VIOLET 1%^99DCT">
xf:labelGENTIAN VIOLET 1%</xf:label>
xf:value323^GENTIAN VIOLET 1%^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3117" id="3117^PARACETAMOL 120
MG^99DCT">
xf:labelPARACETAMOL 120 MG</xf:label>
xf:value3117^PARACETAMOL 120 MG^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2368" id="2368^NEOMYCIN 0.5%
CREAM^99DCT">
xf:labelNEOMYCIN 0.5% CREAM</xf:label>
xf:value2368^NEOMYCIN 0.5% CREAM^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3120" id="3120^SET SUTURE^99DCT">
xf:labelSET SUTURE</xf:label>
xf:value3120^SET SUTURE^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2114" id="2114^CHLORAMPHENICOL 250MG
CAP^99DCT">
xf:labelCHLORAMPHENICOL 250MG CAP</xf:label>
xf:value2114^CHLORAMPHENICOL 250MG CAP^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2440" id="2440^METRONIDAZOLE 250MG
TAB^99DCT">
xf:labelMETRONIDAZOLE 250MG TAB</xf:label>
xf:value2440^METRONIDAZOLE 250MG TAB^99DCT</xf:value>
</xf:item>
<xf:item concept_id="446" id="446^ALUMINUM HYDROXIDE^99DCT">
xf:labelALUMINUM HYDROXIDE</xf:label>
xf:value446^ALUMINUM HYDROXIDE^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3114" id="3114^LOFEMINAL CYCLES^99DCT">
xf:labelLOFEMINAL CYCLES</xf:label>
xf:value3114^LOFEMINAL CYCLES^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2415" id="2415^OVERETTE CYCLES^99DCT">
xf:labelOVERETTE CYCLES</xf:label>
xf:value2415^OVERETTE CYCLES^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2358" id="2358^DESENEX CREAM^99DCT">
xf:labelDESENEX CREAM</xf:label>
xf:value2358^DESENEX CREAM^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3113" id="3113^LIDOCAINE 2% 10
ML^99DCT">
xf:labelLIDOCAINE 2% 10 ML</xf:label>
xf:value3113^LIDOCAINE 2% 10 ML^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2416" id="2416^NORPLANT INSERTS^99DCT">
xf:labelNORPLANT INSERTS</xf:label>
xf:value2416^NORPLANT INSERTS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2312" id="2312^ALBENDAZOLE 200MG
TAB^99DCT">
xf:labelALBENDAZOLE 200MG TAB</xf:label>
xf:value2312^ALBENDAZOLE 200MG TAB^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2117" id="2117^CIPROFLOXACIN 500MG
TAB^99DCT">
xf:labelCIPROFLOXACIN 500MG TAB</xf:label>
xf:value2117^CIPROFLOXACIN 500MG TAB^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2303" id="2303^NYSTATIN VAG, 100.000 IU
TAB^99DCT">
xf:labelNYSTATIN VAG, 100.000 IU TAB</xf:label>
xf:value2303^NYSTATIN VAG, 100.000 IU TAB^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="2078" id="2078^ASPIRIN (ACTYLSLI.ACID)
500MG^99DCT">
xf:labelASPIRIN (ACTYLSLI.ACID) 500MG</xf:label>
xf:value2078^ASPIRIN (ACTYLSLI.ACID) 500MG^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="246" id="246^PIPERAZINE SYRUP^99DCT">
xf:labelPIPERAZINE SYRUP</xf:label>
xf:value246^PIPERAZINE SYRUP^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2362" id="2362^EMUL-O-BALM^99DCT">
xf:labelEMUL-O-BALM</xf:label>
xf:value2362^EMUL-O-BALM^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3066" id="3066^BICILLINE 2.4 ML
UNIT^99DCT">
xf:labelBICILLINE 2.4 ML UNIT</xf:label>
xf:value3066^BICILLINE 2.4 ML UNIT^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2425" id="2425^FESO4+FOLIC ACID PREPACK
#30^99DCT">
xf:labelFESO4+FOLIC ACID PREPACK #30</xf:label>
xf:value2425^FESO4+FOLIC ACID PREPACK #30^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="2442" id="2442^BETADINE IODE SOLN, 10%
200ML^99DCT">
xf:labelBETADINE IODE SOLN, 10% 200ML</xf:label>
xf:value2442^BETADINE IODE SOLN, 10% 200ML^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="3119" id="3119^BANDAGE SET^99DCT">
xf:labelBANDAGE SET</xf:label>
xf:value3119^BANDAGE SET^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3122" id="3122^TYLENOL SYRUP^99DCT">
xf:labelTYLENOL SYRUP</xf:label>
xf:value3122^TYLENOL SYRUP^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3121" id="3121^SULFADIAZINE 500
MG^99DCT">
xf:labelSULFADIAZINE 500 MG</xf:label>
xf:value3121^SULFADIAZINE 500 MG^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2486" id="2486^FOLIC ACID 5MG
TAB^99DCT">
xf:labelFOLIC ACID 5MG TAB</xf:label>
xf:value2486^FOLIC ACID 5MG TAB^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3115" id="3115^NORMAL SALINE^99DCT">
xf:labelNORMAL SALINE</xf:label>
xf:value3115^NORMAL SALINE^99DCT</xf:value>
</xf:item>
<xf:item concept_id="944" id="944^ANTACID^99DCT">
xf:labelANTACID</xf:label>
xf:value944^ANTACID^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2130" id="2130^PROCAINE PENCILLIN 3
MIU^99DCT">
xf:labelPROCAINE PENCILLIN 3 MIU</xf:label>
xf:value2130^PROCAINE PENCILLIN 3 MIU^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2543" id="2543^CONCEPTROL TAB^99DCT">
xf:labelCONCEPTROL TAB</xf:label>
xf:value2543^CONCEPTROL TAB^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2128" id="2128^PENICILLIN PEN VK 250MG
TAB^99DCT">
xf:labelPENICILLIN PEN VK 250MG TAB</xf:label>
xf:value2128^PENICILLIN PEN VK 250MG TAB^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="2444" id="2444^CHLORHEXIDINE SOLUTION
20%^99DCT">
xf:labelCHLORHEXIDINE SOLUTION 20%</xf:label>
xf:value2444^CHLORHEXIDINE SOLUTION 20%^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2495" id="2495^MULTI-VITAMIN
ADULT^99DCT">
xf:labelMULTI-VITAMIN ADULT</xf:label>
xf:value2495^MULTI-VITAMIN ADULT^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2512" id="2512^AMOXICILLIN 500MG
TAB^99DCT">
xf:labelAMOXICILLIN 500MG TAB</xf:label>
xf:value2512^AMOXICILLIN 500MG TAB^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2085" id="2085^PARACETAMOL 100MG
TAB^99DCT">
xf:labelPARACETAMOL 100MG TAB</xf:label>
xf:value2085^PARACETAMOL 100MG TAB^99DCT</xf:value>
</xf:item>
<xf:item concept_id="351" id="351^ORAL REHYDRATION SALTS
PACKETS^99DCT">
xf:labelORAL REHYDRATION SALTS PACKETS</xf:label>
xf:value351^ORAL REHYDRATION SALTS PACKETS^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="2521" id="2521^HCTZ 50MG #30^99DCT">
xf:labelHCTZ 50MG #30</xf:label>
xf:value2521^HCTZ 50MG #30^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2125" id="2125^PENICILLIN PEN VK 125MG
TAB^99DCT">
xf:labelPENICILLIN PEN VK 125MG TAB</xf:label>
xf:value2125^PENICILLIN PEN VK 125MG TAB^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="3123" id="3123^WATER FOR INJ
10ML^99DCT">
xf:labelWATER FOR INJ 10ML</xf:label>
xf:value3123^WATER FOR INJ 10ML^99DCT</xf:value>
</xf:item>
<xf:item concept_id="88" id="88^ASPIRIN 75MG^99DCT">
xf:labelASPIRIN 75MG</xf:label>
xf:value88^ASPIRIN 75MG^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3124" id="3124^WATER FOR INJ
5ML^99DCT">
xf:labelWATER FOR INJ 5ML</xf:label>
xf:value3124^WATER FOR INJ 5ML^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3056" id="3056^BACTRIM 20/100^99DCT">
xf:labelBACTRIM 20/100</xf:label>
xf:value3056^BACTRIM 20/100^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2757" id="2757^AMINOPHYLLINE 200
MG^99DCT">
xf:labelAMINOPHYLLINE 200 MG</xf:label>
xf:value2757^AMINOPHYLLINE 200 MG^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2306" id="2306^CHLORPHENIRAMINE 4MG
TAB^99DCT">
xf:labelCHLORPHENIRAMINE 4MG TAB</xf:label>
xf:value2306^CHLORPHENIRAMINE 4MG TAB^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2341" id="2341^CHLOROQUINE 250MG
TAB^99DCT">
xf:labelCHLOROQUINE 250MG TAB</xf:label>
xf:value2341^CHLOROQUINE 250MG TAB^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2327" id="2327^PHENOBARBITAL 50/60MG
TAB^99DCT">
xf:labelPHENOBARBITAL 50/60MG TAB</xf:label>
xf:value2327^PHENOBARBITAL 50/60MG TAB^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3118" id="3118^RESPERPINE 0.25^99DCT">
xf:labelRESPERPINE 0.25</xf:label>
xf:value3118^RESPERPINE 0.25^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3108" id="3108^COUGH SYRUP^99DCT">
xf:labelCOUGH SYRUP</xf:label>
xf:value3108^COUGH SYRUP^99DCT</xf:value>
</xf:item>
<xf:item concept_id="907" id="907^MEDROXYPROGESTERONE
ACETATE^99DCT">
xf:labelMEDROXYPROGESTERONE ACETATE</xf:label>
xf:value907^MEDROXYPROGESTERONE ACETATE^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2406" id="2406^PROPANTHELINE 15MG
TAB^99DCT">
xf:labelPROPANTHELINE 15MG TAB</xf:label>
xf:value2406^PROPANTHELINE 15MG TAB^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2490" id="2490^VITAMIN SIROP^99DCT">
xf:labelVITAMIN SIROP</xf:label>
xf:value2490^VITAMIN SIROP^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2339" id="2339^CHLOROQUINE 100MG
TAB^99DCT">
xf:labelCHLOROQUINE 100MG TAB</xf:label>
xf:value2339^CHLOROQUINE 100MG TAB^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2427" id="2427^PARACETAMOL 500MG
TAB^99DCT">
xf:labelPARACETAMOL 500MG TAB</xf:label>
xf:value2427^PARACETAMOL 500MG TAB^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2321" id="2321^METHYLDOPA 250MG
TAB^99DCT">
xf:labelMETHYLDOPA 250MG TAB</xf:label>
xf:value2321^METHYLDOPA 250MG TAB^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3111" id="3111^BACTRIM 80/400^99DCT">
xf:labelBACTRIM 80/400</xf:label>
xf:value3111^BACTRIM 80/400^99DCT</xf:value>
</xf:item>
<xf:item concept_id="409" id="409^BENZYL BENZOATE 25%
^99DCT">
xf:labelBENZYL BENZOATE 25%</xf:label>
xf:value409^BENZYL BENZOATE 25% ^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2121" id="2121^DOXYCYCLINE 100MG
TAB^99DCT">
xf:labelDOXYCYCLINE 100MG TAB</xf:label>
xf:value2121^DOXYCYCLINE 100MG TAB^99DCT</xf:value>
</xf:item>
<xf:item concept_id="190" id="190^CONDOMS/KAPOT/144/
BX^99DCT">
xf:labelCONDOMS/KAPOT/144/BX</xf:label>
xf:value190^CONDOMS/KAPOT/144/BX^99DCT</xf:value>
</xf:item>
<xf:item concept_id="6101" id="6101^VITAMIN A,
SUPPLEMENT^99DCT">
xf:labelVITAMIN A, SUPPLEMENT</xf:label>
xf:value6101^VITAMIN A, SUPPLEMENT^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2122" id="2122^ERYTHROMYCIN 250MG
TAB^99DCT">
xf:labelERYTHROMYCIN 250MG TAB</xf:label>
xf:value2122^ERYTHROMYCIN 250MG TAB^99DCT</xf:value>
</xf:item>
</xf:select1>
</xf:repeat>
</xf:group>
<xf:group id="obs/diagnosis">
xf:labelDIAGNOSIS</xf:label>
xf:hintA medical diagnosis.</xf:hint>
<xf:repeat bind="diagnosis">
<xf:select1 appearance="minimal" bind="encounter_type"
concept_id="3100">
xf:labelENCOUNTER TYPE</xf:label>
<xf:item concept_id="6100" id="6100^RETURN VISIT^99DCT">
xf:labelRETURN VISIT</xf:label>
xf:value6100^RETURN VISIT^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3099" id="3099^NEW VISIT^99DCT">
xf:labelNEW VISIT</xf:label>
xf:value3099^NEW VISIT^99DCT</xf:value>
</xf:item>
</xf:select1>
<xf:select1 appearance="minimal" bind="diagnosis_type"
concept_id="3104">
xf:labelDIAGNOSIS TYPE</xf:label>
<xf:item concept_id="3102" id="3102^DIAGNOSIS 2(S)^99DCT">
xf:labelDIAGNOSIS 2(S)</xf:label>
xf:value3102^DIAGNOSIS 2(S)^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3103" id="3103^DIAGNOSIS 3(S)^99DCT">
xf:labelDIAGNOSIS 3(S)</xf:label>
xf:value3103^DIAGNOSIS 3(S)^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3101" id="3101^DIAGNOSIS 1(P)^99DCT">
xf:labelDIAGNOSIS 1(P)</xf:label>
xf:value3101^DIAGNOSIS 1(P)^99DCT</xf:value>
</xf:item>
</xf:select1>
<xf:select1 appearance="minimal" bind="diagnosis_id"
concept_id="2879">
xf:labelDIAGNOSIS SET</xf:label>
<xf:item concept_id="1797" id="1797^GIARDIASIS^99DCT">
xf:labelGIARDIASIS</xf:label>
xf:value1797^GIARDIASIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3039" id="3039^RESPIRATORY PROBLEMS
AFTER BIRTH^99DCT">
xf:labelRESPIRATORY PROBLEMS AFTER BIRTH</xf:label>
xf:value3039^RESPIRATORY PROBLEMS AFTER BIRTH^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="3156" id="3156^HERNIA OF OTHER
SPECIFIED SITES WITHOUT MENTION OF OBSTRUCTION ORGANGRENE^99DCT">
xf:labelHERNIA OF OTHER SPECIFIED SITES WITHOUT MENTION
OF OBSTRUCTION ORGANGRENE</xf:label>
xf:value3156^HERNIA OF OTHER SPECIFIED SITES WITHOUT
MENTION OF OBSTRUCTION ORGANGRENE^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3128" id="3128^UNSPECIFIED
ABORTION^99DCT">
xf:labelUNSPECIFIED ABORTION</xf:label>
xf:value3128^UNSPECIFIED ABORTION^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3141" id="3141^UNSPECIFIED PULMONARY
TUBERCULOSIS IN TREATMENT^99DCT">
xf:labelUNSPECIFIED PULMONARY TUBERCULOSIS IN
TREATMENT</xf:label>
xf:value3141^UNSPECIFIED PULMONARY TUBERCULOSIS IN
TREATMENT^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3140" id="3140^UNSPECIFIED PULMONARY
TUBERCULOSIS,SUSPICION,TUBERCULOSIS^99DCT">
TUBERCULOSIS,SUSPICION,TUBERCULOSIS</xf:label>
xf:value3140^UNSPECIFIED PULMONARY
TUBERCULOSIS,SUSPICION,TUBERCULOSIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3131" id="3131^UNSPECIFIED DISORDERS OF
MENSTRUSTION^99DCT">
xf:labelUNSPECIFIED DISORDERS OF MENSTRUSTION</xf:label>
xf:value3131^UNSPECIFIED DISORDERS OF
MENSTRUSTION^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3164" id="3164^ULCER OF LOWER LIMBS
EXCEPT DECUBITUS ULCER^99DCT">
xf:labelULCER OF LOWER LIMBS EXCEPT DECUBITUS ULCER</
xf:label>
xf:value3164^ULCER OF LOWER LIMBS EXCEPT DECUBITUS
ULCER^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3125" id="3125^INFECTIVE OTITIS
EXTERNA, UNSPECIFIED^99DCT">
xf:labelINFECTIVE OTITIS EXTERNA, UNSPECIFIED</xf:label>
xf:value3125^INFECTIVE OTITIS EXTERNA,
UNSPECIFIED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1996" id="1996^PREGNANCY
(COMPLICATED)^99DCT">
xf:labelPREGNANCY (COMPLICATED)</xf:label>
xf:value1996^PREGNANCY (COMPLICATED)^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2016" id="2016^ANTEPARTUM
MALARIA^99DCT">
xf:labelANTEPARTUM MALARIA</xf:label>
xf:value2016^ANTEPARTUM MALARIA^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1969" id="1969^DERMATITIS/
ECZEMA^99DCT">
xf:labelDERMATITIS/ECZEMA</xf:label>
xf:value1969^DERMATITIS/ECZEMA^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1953" id="1953^NEURALGIA^99DCT">
xf:labelNEURALGIA</xf:label>
xf:value1953^NEURALGIA^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3161" id="3161^TOXOCARIASIS^99DCT">
xf:labelTOXOCARIASIS</xf:label>
xf:value3161^TOXOCARIASIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1884" id="1884^CONGENITAL HEART
DIS^99DCT">
xf:labelCONGENITAL HEART DIS</xf:label>
xf:value1884^CONGENITAL HEART DIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1926" id="1926^CYSTIC RENAL DIS^99DCT">
xf:labelCYSTIC RENAL DIS</xf:label>
xf:value1926^CYSTIC RENAL DIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1992" id="1992^PREMATURE BIRTH^99DCT">
xf:labelPREMATURE BIRTH</xf:label>
xf:value1992^PREMATURE BIRTH^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3159" id="3159^ACUTE
NASOPHARYNGITIS^99DCT">
xf:labelACUTE NASOPHARYNGITIS</xf:label>
xf:value3159^ACUTE NASOPHARYNGITIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1801" id="1801^VOLUME DEPLETION
DISORDER, DEGREE C^99DCT">
xf:labelVOLUME DEPLETION DISORDER, DEGREE C</xf:label>
xf:value1801^VOLUME DEPLETION DISORDER, DEGREE C^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="3162" id="3162^OTHER AND UNSPECIFIED
MYCOSES^99DCT">
xf:labelOTHER AND UNSPECIFIED MYCOSES</xf:label>
xf:value3162^OTHER AND UNSPECIFIED MYCOSES^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="3151" id="3151^SHIGELLOSIS, UNSPECIFIED
^99DCT">
xf:labelSHIGELLOSIS, UNSPECIFIED</xf:label>
xf:value3151^SHIGELLOSIS, UNSPECIFIED ^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3160" id="3160^URTICARIA, UNSPECIFIED
^99DCT">
xf:labelURTICARIA, UNSPECIFIED</xf:label>
xf:value3160^URTICARIA, UNSPECIFIED ^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1799" id="1799^DIPHTHERIA
UNSPECIFIED^99DCT">
xf:labelDIPHTHERIA UNSPECIFIED</xf:label>
xf:value1799^DIPHTHERIA UNSPECIFIED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3155" id="3155^HEMORRHOIDS^99DCT">
xf:labelHEMORRHOIDS</xf:label>
xf:value3155^HEMORRHOIDS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1989" id="1989^VAGINAL BLEEDING^99DCT">
xf:labelVAGINAL BLEEDING</xf:label>
xf:value1989^VAGINAL BLEEDING^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1970" id="1970^PRURIGO^99DCT">
xf:labelPRURIGO</xf:label>
xf:value1970^PRURIGO^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1965" id="1965^IMPETIGO^99DCT">
xf:labelIMPETIGO</xf:label>
xf:value1965^IMPETIGO^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3154" id="3154^VOLUME DEPLETION
DISORDER, DEGREE B ^99DCT">
xf:labelVOLUME DEPLETION DISORDER, DEGREE B</xf:label>
xf:value3154^VOLUME DEPLETION DISORDER, DEGREE B ^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="114" id="114^OTITIS MEDIA^99DCT">
xf:labelOTITIS MEDIA</xf:label>
xf:value114^OTITIS MEDIA^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3127" id="3127^LATENT SYPHILIS
UNSPECIFIED, SEXUALLY TRANSMITTED^99DCT">
xf:labelLATENT SYPHILIS UNSPECIFIED, SEXUALLY
TRANSMITTED</xf:label>
xf:value3127^LATENT SYPHILIS UNSPECIFIED, SEXUALLY
TRANSMITTED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="46" id="46^PREGNANCY, ECTOPIC^99DCT">
xf:labelPREGNANCY, ECTOPIC</xf:label>
xf:value46^PREGNANCY, ECTOPIC^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3152" id="3152^AMEBIASIS
UNSPECIFIED^99DCT">
xf:labelAMEBIASIS UNSPECIFIED</xf:label>
xf:value3152^AMEBIASIS UNSPECIFIED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1928" id="1928^HYDROCOELE^99DCT">
xf:labelHYDROCOELE</xf:label>
xf:value1928^HYDROCOELE^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3157" id="3157^INTESTINAL PARASITISM,
UNSPECIFIED^99DCT">
xf:labelINTESTINAL PARASITISM, UNSPECIFIED</xf:label>
xf:value3157^INTESTINAL PARASITISM, UNSPECIFIED^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="3142" id="3142^OTHER DISEASES OF LUNG
NOT ELSEWHERE CLASSIFIED^99DCT">
xf:labelOTHER DISEASES OF LUNG NOT ELSEWHERE CLASSIFIED</
xf:label>
xf:value3142^OTHER DISEASES OF LUNG NOT ELSEWHERE
CLASSIFIED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1976" id="1976^INTERNAL INJURY^99DCT">
xf:labelINTERNAL INJURY</xf:label>
xf:value1976^INTERNAL INJURY^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1987" id="1987^GUNSHOT
UNSPECIFIED^99DCT">
xf:labelGUNSHOT UNSPECIFIED</xf:label>
xf:value1987^GUNSHOT UNSPECIFIED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1978" id="1978^INJURY TO NERVE^99DCT">
xf:labelINJURY TO NERVE</xf:label>
xf:value1978^INJURY TO NERVE^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1974" id="1974^TRAUMA, CHEST^99DCT">
xf:labelTRAUMA, CHEST</xf:label>
xf:value1974^TRAUMA, CHEST^99DCT</xf:value>
</xf:item>
<xf:item concept_id="135" id="135^BURN^99DCT">
xf:labelBURN</xf:label>
xf:value135^BURN^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1979" id="1979^TRAUMA, SPINAL
CORD^99DCT">
xf:labelTRAUMA, SPINAL CORD</xf:label>
xf:value1979^TRAUMA, SPINAL CORD^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1983" id="1983^FX LOWER LIMB NEC-
CLOSED^99DCT">
xf:labelFX LOWER LIMB NEC-CLOSED</xf:label>
xf:value1983^FX LOWER LIMB NEC-CLOSED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1981" id="1981^FRACTURE OF UNSPECIFIED
BONE (CLOSED)^99DCT">
xf:labelFRACTURE OF UNSPECIFIED BONE (CLOSED)</xf:label>
xf:value1981^FRACTURE OF UNSPECIFIED BONE
(CLOSED)^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1917" id="1917^ASCITES^99DCT">
xf:labelASCITES</xf:label>
xf:value1917^ASCITES^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1936" id="1936^ADENOPATHY^99DCT">
xf:labelADENOPATHY</xf:label>
xf:value1936^ADENOPATHY^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1893" id="1893^SEPTIC SHOCK^99DCT">
xf:labelSEPTIC SHOCK</xf:label>
xf:value1893^SEPTIC SHOCK^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1984" id="1984^TIBIA FRACTURE
(CLOSED)^99DCT">
xf:labelTIBIA FRACTURE (CLOSED)</xf:label>
xf:value1984^TIBIA FRACTURE (CLOSED)^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1982" id="1982^ARM FRACTURE
(CLOSED)^99DCT">
xf:labelARM FRACTURE (CLOSED)</xf:label>
xf:value1982^ARM FRACTURE (CLOSED)^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1985" id="1985^FRACTURE RIB NOS-
CLOSED^99DCT">
xf:labelFRACTURE RIB NOS-CLOSED</xf:label>
xf:value1985^FRACTURE RIB NOS-CLOSED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1973" id="1973^WASTING SYND/
CACHEXIA^99DCT">
xf:labelWASTING SYND/CACHEXIA</xf:label>
xf:value1973^WASTING SYND/CACHEXIA^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1890" id="1890^EDMA^99DCT">
xf:labelEDMA</xf:label>
xf:value1890^EDMA^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1997" id="1997^FEVER^99DCT">
xf:labelFEVER</xf:label>
xf:value1997^FEVER^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2017" id="2017^NEWBORN
INFECTION^99DCT">
xf:labelNEWBORN INFECTION</xf:label>
xf:value2017^NEWBORN INFECTION^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1889" id="1889^CARDIAC MURMUR^99DCT">
xf:labelCARDIAC MURMUR</xf:label>
xf:value1889^CARDIAC MURMUR^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1894" id="1894^PALPITATION^99DCT">
xf:labelPALPITATION</xf:label>
xf:value1894^PALPITATION^99DCT</xf:value>
</xf:item>
<xf:item concept_id="620" id="620^HEADACHE^99DCT">
xf:labelHEADACHE</xf:label>
xf:value620^HEADACHE^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1915" id="1915^JAUNDICE^99DCT">
xf:labelJAUNDICE</xf:label>
xf:value1915^JAUNDICE^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1977" id="1977^INJURY,
UNSPECIFIED^99DCT">
xf:labelINJURY, UNSPECIFIED</xf:label>
xf:value1977^INJURY, UNSPECIFIED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2000" id="2000^VIRAL
INFECTIONS^99DCT">
xf:labelVIRAL INFECTIONS</xf:label>
xf:value2000^VIRAL INFECTIONS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2020" id="2020^VARICELLA/ZOSTER^99DCT">
xf:labelVARICELLA/ZOSTER</xf:label>
xf:value2020^VARICELLA/ZOSTER^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2021" id="2021^SYPHILIS POSITIVE
(RPR)^99DCT">
xf:labelSYPHILIS POSITIVE (RPR)</xf:label>
xf:value2021^SYPHILIS POSITIVE (RPR)^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2010" id="2010^GRANULOMA
INGUINALE^99DCT">
xf:labelGRANULOMA INGUINALE</xf:label>
xf:value2010^GRANULOMA INGUINALE^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2001" id="2001^GONOCOCCAL
INFECTION^99DCT">
xf:labelGONOCOCCAL INFECTION</xf:label>
xf:value2001^GONOCOCCAL INFECTION^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1967" id="1967^DERMATOPHYTOSIS^99DCT">
xf:labelDERMATOPHYTOSIS</xf:label>
xf:value1967^DERMATOPHYTOSIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2018" id="2018^LEPTOSPIROSIS,
UNSPECIFIED^99DCT">
xf:labelLEPTOSPIROSIS, UNSPECIFIED</xf:label>
xf:value2018^LEPTOSPIROSIS, UNSPECIFIED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2005" id="2005^TOXOPLASMOSIS,
UNSPECIFIED^99DCT">
xf:labelTOXOPLASMOSIS, UNSPECIFIED</xf:label>
xf:value2005^TOXOPLASMOSIS, UNSPECIFIED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2003" id="2003^CANDIDIASIS,
UNSPECIFIED^99DCT">
xf:labelCANDIDIASIS, UNSPECIFIED</xf:label>
xf:value2003^CANDIDIASIS, UNSPECIFIED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1807" id="1807^PHTHIRUS PUBIS [PUBIC
LOUSE]^99DCT">
xf:labelPHTHIRUS PUBIS [PUBIC LOUSE]</xf:label>
xf:value1807^PHTHIRUS PUBIS [PUBIC LOUSE]^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="1988" id="1988^VAGINITIS^99DCT">
xf:labelVAGINITIS</xf:label>
xf:value1988^VAGINITIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="42" id="42^PULMONARY TB^99DCT">
xf:labelPULMONARY TB</xf:label>
xf:value42^PULMONARY TB^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1899" id="1899^ASTHMA
UNSPECIFIED^99DCT">
xf:labelASTHMA UNSPECIFIED</xf:label>
xf:value1899^ASTHMA UNSPECIFIED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2011" id="2011^PLEURAL
xf:labelPLEURAL TUBERCULOSIS</xf:label>
xf:value2011^PLEURAL TUBERCULOSIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2022" id="2022^MILIARY TUBERCULOSIS,
UNSPECIFIED^99DCT">
xf:labelMILIARY TUBERCULOSIS, UNSPECIFIED</xf:label>
xf:value2022^MILIARY TUBERCULOSIS, UNSPECIFIED^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="2007" id="2007^TETANUS^99DCT">
xf:labelTETANUS</xf:label>
xf:value2007^TETANUS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2008" id="2008^SEPSIS^99DCT">
xf:labelSEPSIS</xf:label>
xf:value2008^SEPSIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1999" id="1999^BACT:INFECTION^99DCT">
xf:labelBACT:INFECTION</xf:label>
xf:value1999^BACT:INFECTION^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2013" id="2013^AIDS^99DCT">
xf:labelAIDS</xf:label>
xf:value2013^AIDS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1950" id="1950^UNSPECIFIED NON-
ARTHROPOD-BORNE VIRAL DISEASES OF CENTRAL NERVOUS SYSTEM^99DCT">
xf:labelUNSPECIFIED NON-ARTHROPOD-BORNE VIRAL DISEASES
OF CENTRAL NERVOUS SYSTEM</xf:label>
xf:value1950^UNSPECIFIED NON-ARTHROPOD-BORNE VIRAL
DISEASES OF CENTRAL NERVOUS SYSTEM^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3177" id="3177^URINARY RETENTION
^99DCT">
xf:labelURINARY RETENTION</xf:label>
xf:value3177^URINARY RETENTION ^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1949" id="1949^MENINGITIS,
UNSPECIFIED^99DCT">
xf:labelMENINGITIS, UNSPECIFIED</xf:label>
xf:value1949^MENINGITIS, UNSPECIFIED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3180" id="3180^NEPHRPTIC SYNDROME WITH
UNSPECIFIED PATHOLOGICAL LESION IN KIDNEY^99DCT">
xf:labelNEPHRPTIC SYNDROME WITH UNSPECIFIED PATHOLOGICAL
LESION IN KIDNEY</xf:label>
xf:value3180^NEPHRPTIC SYNDROME WITH UNSPECIFIED
PATHOLOGICAL LESION IN KIDNEY^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1938" id="1938^UNSPECIFIED DISORDER OF
THYROID^99DCT">
xf:labelUNSPECIFIED DISORDER OF THYROID</xf:label>
xf:value1938^UNSPECIFIED DISORDER OF THYROID^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="3183" id="3183^ACUTE
PYELONEPHRITIS^99DCT">
xf:labelACUTE PYELONEPHRITIS</xf:label>
xf:value3183^ACUTE PYELONEPHRITIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1919" id="1919^CANCER, DIGESTIVE
SYSTEM^99DCT">
xf:labelCANCER, DIGESTIVE SYSTEM</xf:label>
xf:value1919^CANCER, DIGESTIVE SYSTEM^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3191" id="3191^MILD OR UNSPECIFIED PRE-
ECLAMPSIA^99DCT">
xf:labelMILD OR UNSPECIFIED PRE-ECLAMPSIA</xf:label>
xf:value3191^MILD OR UNSPECIFIED PRE-ECLAMPSIA^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="3174" id="3174^PREGNANCY EXAMINATION OR
TEST PREGNANCY UNCONFIRMED,PRENATAL III^99DCT">
xf:labelPREGNANCY EXAMINATION OR TEST PREGNANCY
UNCONFIRMED,PRENATAL III</xf:label>
xf:value3174^PREGNANCY EXAMINATION OR TEST PREGNANCY
UNCONFIRMED,PRENATAL III^99DCT</xf:value>
</xf:item>
<xf:item concept_id="141" id="141^TYPHOID FEVER^99DCT">
xf:labelTYPHOID FEVER</xf:label>
xf:value141^TYPHOID FEVER^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1930" id="1930^IRON DEFICIENCY ANEMIA,
UNSPECIFIED^99DCT">
xf:labelIRON DEFICIENCY ANEMIA, UNSPECIFIED</xf:label>
xf:value1930^IRON DEFICIENCY ANEMIA, UNSPECIFIED^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="3173" id="3173^PREGNANCY EXAMINATION OR
TEST PREGNANCY UNCONFIRMED,PRENATAL II^99DCT">
UNCONFIRMED,PRENATAL II</xf:label>
xf:value3173^PREGNANCY EXAMINATION OR TEST PREGNANCY
UNCONFIRMED,PRENATAL II^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1972" id="1972^NUTRITIONAL
MARASMUS^99DCT">
xf:labelNUTRITIONAL MARASMUS</xf:label>
xf:value1972^NUTRITIONAL MARASMUS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3" id="3^ANEMIA UNSPECIFIED^99DCT">
xf:labelANEMIA UNSPECIFIED</xf:label>
xf:value3^ANEMIA UNSPECIFIED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1963" id="1963^OTHER BACKGROUND
RETINOPATHY AND RETINAL VASCULAR CHANGES^99DCT">
xf:labelOTHER BACKGROUND RETINOPATHY AND RETINAL
VASCULAR CHANGES</xf:label>
xf:value1963^OTHER BACKGROUND RETINOPATHY AND RETINAL
VASCULAR CHANGES^99DCT</xf:value>
</xf:item>
<xf:item concept_id="903" id="903^HYPERTENSION^99DCT">
xf:labelHYPERTENSION</xf:label>
xf:value903^HYPERTENSION^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1951" id="1951^PARALYSIS,
UNSPECIFIED^99DCT">
xf:labelPARALYSIS, UNSPECIFIED</xf:label>
xf:value1951^PARALYSIS, UNSPECIFIED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3171" id="3171^CONCUSSION,
UNSPECIFIED^99DCT">
xf:labelCONCUSSION, UNSPECIFIED</xf:label>
xf:value3171^CONCUSSION, UNSPECIFIED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1947" id="1947^PARALYSIS
AGITANS^99DCT">
xf:labelPARALYSIS AGITANS</xf:label>
xf:value1947^PARALYSIS AGITANS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1800" id="1800^COMA^99DCT">
xf:labelCOMA</xf:label>
xf:value1800^COMA^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1943" id="1943^CONFUSION/
ENCEPHALOPATHY^99DCT">
xf:labelCONFUSION/ENCEPHALOPATHY</xf:label>
xf:value1943^CONFUSION/ENCEPHALOPATHY^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3192" id="3192^ECLAMPSIA COMPLICATING
PREGNANCY CHILDBIRTH OR THE PUERPERIUM COMPLICATION OF PREGNANCY
DELIVERY AND PUERPERIUM^99DCT">
xf:labelECLAMPSIA COMPLICATING PREGNANCY CHILDBIRTH OR
THE PUERPERIUM COMPLICATION OF PREGNANCY DELIVERY AND PUERPERIUM</
xf:label>
xf:value3192^ECLAMPSIA COMPLICATING PREGNANCY CHILDBIRTH
OR THE PUERPERIUM COMPLICATION OF PREGNANCY DELIVERY AND
PUERPERIUM^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3172" id="3172^PREGNANCY EXAMINATION OR
TEST PREGNANCY UNCONFIRMED,PRENATAL I^99DCT">
UNCONFIRMED,PRENATAL I</xf:label>
xf:value3172^PREGNANCY EXAMINATION OR TEST PREGNANCY
UNCONFIRMED,PRENATAL I^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3069" id="3069^ASTIGMATIS^99DCT">
xf:labelASTIGMATIS</xf:label>
xf:value3069^ASTIGMATIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1942" id="1942^HYSTERIA,
UNSPECIFIED^99DCT">
xf:labelHYSTERIA, UNSPECIFIED</xf:label>
xf:value1942^HYSTERIA, UNSPECIFIED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1961" id="1961^UNSPECIFIED
CATARACT^99DCT">
xf:labelUNSPECIFIED CATARACT</xf:label>
xf:value1961^UNSPECIFIED CATARACT^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1796" id="1796^KWASHIORKOR^99DCT">
xf:labelKWASHIORKOR</xf:label>
xf:value1796^KWASHIORKOR^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1962" id="1962^UNSPECIFIED
GLAUCOMA^99DCT">
xf:labelUNSPECIFIED GLAUCOMA</xf:label>
xf:value1962^UNSPECIFIED GLAUCOMA^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3190" id="3190^AQUIRED IMMUNODEFICIENCY
SYNDROME UNSPECIFIED^99DCT">
xf:labelAQUIRED IMMUNODEFICIENCY SYNDROME UNSPECIFIED</
xf:label>
xf:value3190^AQUIRED IMMUNODEFICIENCY SYNDROME
</xf:item>
<xf:item concept_id="1945" id="1945^EPILEPSY,
UNSPECIFIED^99DCT">
xf:labelEPILEPSY, UNSPECIFIED</xf:label>
xf:value1945^EPILEPSY, UNSPECIFIED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="2012" id="2012^PNEUMOCYSTOSIS^99DCT">
xf:labelPNEUMOCYSTOSIS</xf:label>
xf:value2012^PNEUMOCYSTOSIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3185" id="3185^OTHER DISEASES OF UPPER
RESPIRATORY TRACT^99DCT">
xf:labelOTHER DISEASES OF UPPER RESPIRATORY TRACT</
xf:label>
xf:value3185^OTHER DISEASES OF UPPER RESPIRATORY
TRACT^99DCT</xf:value>
</xf:item>
<xf:item concept_id="10" id="10^BRONCHITIS, ACUTE^99DCT">
xf:labelBRONCHITIS, ACUTE</xf:label>
xf:value10^BRONCHITIS, ACUTE^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1934" id="1934^CHRONIC LEUKEMIA^99DCT">
xf:labelCHRONIC LEUKEMIA</xf:label>
xf:value1934^CHRONIC LEUKEMIA^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1991" id="1991^UTERINE FIBROID^99DCT">
xf:labelUTERINE FIBROID</xf:label>
xf:value1991^UTERINE FIBROID^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3210" id="3210^PREGNANCY EXAMINATION OR
TEST PREGNANCY UNCONFIRMED, PRENATAL IV + ^99DCT">
UNCONFIRMED, PRENATAL IV +</xf:label>
xf:value3210^PREGNANCY EXAMINATION OR TEST PREGNANCY
UNCONFIRMED, PRENATAL IV + ^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1935" id="1935^OTHER LYMPOMA^99DCT">
xf:labelOTHER LYMPOMA</xf:label>
xf:value1935^OTHER LYMPOMA^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1933" id="1933^LEUKEMIA ACUTE^99DCT">
xf:labelLEUKEMIA ACUTE</xf:label>
xf:value1933^LEUKEMIA ACUTE^99DCT</xf:value>
</xf:item>
<xf:item concept_id="5334" id="5334^CANDIDIASIS OF MOUTH
^99DCT">
xf:labelCANDIDIASIS OF MOUTH</xf:label>
xf:value5334^CANDIDIASIS OF MOUTH ^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3144" id="3144^HEART FAILURE
UNSPECIFIED^99DCT">
xf:labelHEART FAILURE UNSPECIFIED</xf:label>
xf:value3144^HEART FAILURE UNSPECIFIED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="117" id="117^OTHER AND UNSPECIFIED
CONJUNCTIVITIS^99DCT">
xf:labelOTHER AND UNSPECIFIED CONJUNCTIVITIS</xf:label>
xf:value117^OTHER AND UNSPECIFIED CONJUNCTIVITIS^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="43" id="43^PNEUMONIA
UNSPECIFIED^99DCT">
xf:labelPNEUMONIA UNSPECIFIED</xf:label>
xf:value43^PNEUMONIA UNSPECIFIED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="5995" id="5995^URETHRAL
DISCHARGE^99DCT">
xf:labelURETHRAL DISCHARGE</xf:label>
xf:value5995^URETHRAL DISCHARGE^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3068" id="3068^BLEPHARITIS,
UNSPECIFIED^99DCT">
xf:labelBLEPHARITIS, UNSPECIFIED</xf:label>
xf:value3068^BLEPHARITIS, UNSPECIFIED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="891" id="891^PERTUSSIS^99DCT">
xf:labelPERTUSSIS</xf:label>
xf:value891^PERTUSSIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="16" id="16^DIARRHEA OF PRESUMED
INFECTIOUS ORIGIN^99DCT">
xf:labelDIARRHEA OF PRESUMED INFECTIOUS ORIGIN</
xf:label>
xf:value16^DIARRHEA OF PRESUMED INFECTIOUS ORIGIN^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="3165" id="3165^ACUTE LARYNGITIS^99DCT">
xf:labelACUTE LARYNGITIS</xf:label>
xf:value3165^ACUTE LARYNGITIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1883" id="1883^CORONARY
ATHEROSCLEROSIS^99DCT">
xf:labelCORONARY ATHEROSCLEROSIS</xf:label>
xf:value1883^CORONARY ATHEROSCLEROSIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3168" id="3168^UNSPECIFIED
ARTHROPATHY^99DCT">
xf:labelUNSPECIFIED ARTHROPATHY</xf:label>
xf:value3168^UNSPECIFIED ARTHROPATHY^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1885" id="1885^RHEUMATIC DISEASES OF
ENDOCARDIUM, VALVE UNSPECIFIED^99DCT">
xf:labelRHEUMATIC DISEASES OF ENDOCARDIUM, VALVE
xf:value1885^RHEUMATIC DISEASES OF ENDOCARDIUM, VALVE
</xf:item>
<xf:item concept_id="1136" id="1136^PULMONARY
EFFUSION^99DCT">
xf:labelPULMONARY EFFUSION</xf:label>
xf:value1136^PULMONARY EFFUSION^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1886" id="1886^OTHER PRIMARY
CARDIOMYOPATHIES^99DCT">
xf:labelOTHER PRIMARY CARDIOMYOPATHIES</xf:label>
xf:value1886^OTHER PRIMARY CARDIOMYOPATHIES^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="1998" id="1998^ANTHRAX
UNSPECIFIED^99DCT">
xf:labelANTHRAX UNSPECIFIED</xf:label>
xf:value1998^ANTHRAX UNSPECIFIED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="151" id="151^ABDOMINAL PAIN^99DCT">
xf:labelABDOMINAL PAIN</xf:label>
xf:value151^ABDOMINAL PAIN^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3126" id="3126^UNSPECIFIED CHRONIC
BRONCHITIS,BRONCHITIS^99DCT">
xf:labelUNSPECIFIED CHRONIC BRONCHITIS,BRONCHITIS</
xf:label>
xf:value3126^UNSPECIFIED CHRONIC
BRONCHITIS,BRONCHITIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3138" id="3138^BRONCHOPNEUMONIA
ORGANISM UNSPECIFIED, VERY BAD^99DCT">
xf:labelBRONCHOPNEUMONIA ORGANISM UNSPECIFIED, VERY BAD</
xf:label>
xf:value3138^BRONCHOPNEUMONIA ORGANISM UNSPECIFIED, VERY
BAD^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1958" id="1958^UNSPECIFIED HEARING
LOSS^99DCT">
xf:labelUNSPECIFIED HEARING LOSS</xf:label>
xf:value1958^UNSPECIFIED HEARING LOSS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3134" id="3134^UNATTENDED DEATH^99DCT">
xf:labelUNATTENDED DEATH</xf:label>
xf:value3134^UNATTENDED DEATH^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1964" id="1964^PAPILLEDEMA^99DCT">
xf:labelPAPILLEDEMA</xf:label>
xf:value1964^PAPILLEDEMA^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3189" id="3189^OTHER SEVERE PROTEIN-
CALORIE MALNUTRITION^99DCT">
xf:labelOTHER SEVERE PROTEIN-CALORIE MALNUTRITION</
xf:label>
xf:value3189^OTHER SEVERE PROTEIN-CALORIE
MALNUTRITION^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3176" id="3176^RELAPSING FEVER^99DCT">
xf:labelRELAPSING FEVER</xf:label>
xf:value3176^RELAPSING FEVER^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3188" id="3188^MALNUTRITION WITH
MODERATE DEGREE^99DCT">
xf:labelMALNUTRITION WITH MODERATE DEGREE</xf:label>
xf:value3188^MALNUTRITION WITH MODERATE DEGREE^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="123" id="123^MALARIA
UNSPECIFIED^99DCT">
xf:labelMALARIA UNSPECIFIED</xf:label>
xf:value123^MALARIA UNSPECIFIED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1959" id="1959^UNQUALIFIED VISUAL LOSS,
BOTH EYES^99DCT">
xf:labelUNQUALIFIED VISUAL LOSS, BOTH EYES</xf:label>
xf:value1959^UNQUALIFIED VISUAL LOSS, BOTH EYES^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="3133" id="3133^UNSPECIFIED SYMPTOM
ASSSOCIATED WITH FEMALE GENITAL ORGANS^99DCT">
xf:labelUNSPECIFIED SYMPTOM ASSSOCIATED WITH FEMALE
GENITAL ORGANS</xf:label>
xf:value3133^UNSPECIFIED SYMPTOM ASSSOCIATED WITH FEMALE
GENITAL ORGANS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="134" id="134^CELLULITIS AND ABCESS OF
UNSPECIFIED SITES^99DCT">
xf:labelCELLULITIS AND ABCESS OF UNSPECIFIED SITES</
xf:label>
xf:value134^CELLULITIS AND ABCESS OF UNSPECIFIED
SITES^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1905" id="1905^ESOPHAGITIS^99DCT">
xf:labelESOPHAGITIS</xf:label>
xf:value1905^ESOPHAGITIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3150" id="3150^TOOTH ABCESS^99DCT">
xf:labelTOOTH ABCESS</xf:label>
xf:value3150^TOOTH ABCESS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3184" id="3184^SICKEL CELL DISEASE:
VASO-OCCLUSIVE CRISIS^99DCT">
xf:labelSICKEL CELL DISEASE: VASO-OCCLUSIVE CRISIS</
xf:label>
xf:value3184^SICKEL CELL DISEASE: VASO-OCCLUSIVE
CRISIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3186" id="3186^SICKLE-CELL
ANEMIA^99DCT">
xf:labelSICKLE-CELL ANEMIA</xf:label>
xf:value3186^SICKLE-CELL ANEMIA^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3187" id="3187^MALNUTRITION WITH MILD
DEGREE^99DCT">
xf:labelMALNUTRITION WITH MILD DEGREE</xf:label>
xf:value3187^MALNUTRITION WITH MILD DEGREE^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="3179" id="3179^LUMBAGO^99DCT">
xf:labelLUMBAGO</xf:label>
xf:value3179^LUMBAGO^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3181" id="3181^CYSTITIS^99DCT">
xf:labelCYSTITIS</xf:label>
xf:value3181^CYSTITIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3178" id="3178^ACUTE SINUSITIS^99DCT">
xf:labelACUTE SINUSITIS</xf:label>
xf:value3178^ACUTE SINUSITIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3175" id="3175^OTHERS
(CANCER,HYPERTHYROID,ETC.)^99DCT">
xf:labelOTHERS (CANCER,HYPERTHYROID,ETC.)</xf:label>
xf:value3175^OTHERS (CANCER,HYPERTHYROID,ETC.)^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="3182" id="3182^URINARY CALCULUS,
UNSPECIFIED^99DCT">
xf:labelURINARY CALCULUS, UNSPECIFIED</xf:label>
xf:value3182^URINARY CALCULUS, UNSPECIFIED^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="2014" id="2014^CHANCROID^99DCT">
xf:labelCHANCROID</xf:label>
xf:value2014^CHANCROID^99DCT</xf:value>
</xf:item>
<xf:item concept_id="128" id="128^WOUND, DEEP^99DCT">
xf:labelWOUND, DEEP</xf:label>
xf:value128^WOUND, DEEP^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3143" id="3143^ACUTE PERICARDITIS
UNSPECIFIED^99DCT">
xf:labelACUTE PERICARDITIS UNSPECIFIED</xf:label>
xf:value3143^ACUTE PERICARDITIS UNSPECIFIED^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="140" id="140^SCABIES^99DCT">
xf:labelSCABIES</xf:label>
xf:value140^SCABIES^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3158" id="3158^OTHER DISORDERS OF
INTESTINE^99DCT">
xf:labelOTHER DISORDERS OF INTESTINE</xf:label>
xf:value3158^OTHER DISORDERS OF INTESTINE^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="3043" id="3043^EXCESSIVE OR FREQUENT
MENSTRUATION^99DCT">
xf:labelEXCESSIVE OR FREQUENT MENSTRUATION</xf:label>
xf:value3043^EXCESSIVE OR FREQUENT MENSTRUATION^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="212" id="212^GASTRIC ULCER^99DCT">
xf:labelGASTRIC ULCER</xf:label>
xf:value212^GASTRIC ULCER^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1986" id="1986^WOUND/LACERATION^99DCT">
xf:labelWOUND/LACERATION</xf:label>
xf:value1986^WOUND/LACERATION^99DCT</xf:value>
</xf:item>
<xf:item concept_id="29" id="29^HEPATITIS^99DCT">
xf:labelHEPATITIS</xf:label>
xf:value29^HEPATITIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1921" id="1921^HYPERPLASIA OF THE
PROSTATE^99DCT">
xf:labelHYPERPLASIA OF THE PROSTATE</xf:label>
xf:value1921^HYPERPLASIA OF THE PROSTATE^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="1913" id="1913^UNSPECIFIED
PERITONITIS^99DCT">
xf:labelUNSPECIFIED PERITONITIS</xf:label>
xf:value1913^UNSPECIFIED PERITONITIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="210" id="210^PEPTIC ULCER
DISEASE^99DCT">
xf:labelPEPTIC ULCER DISEASE</xf:label>
xf:value210^PEPTIC ULCER DISEASE^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3145" id="3145^DEEP VEIN
THROMBOSIS^99DCT">
xf:labelDEEP VEIN THROMBOSIS</xf:label>
xf:value3145^DEEP VEIN THROMBOSIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="63" id="63^MEASLES WITHOUT MENTION OF
COMPLICATION^99DCT">
xf:labelMEASLES WITHOUT MENTION OF COMPLICATION</
xf:label>
xf:value63^MEASLES WITHOUT MENTION OF
COMPLICATION^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3044" id="3044^PERIMENOPAUSAL
SYNDROME(HEMORAGIE) ^99DCT">
xf:labelPERIMENOPAUSAL SYNDROME(HEMORAGIE)</xf:label>
xf:value3044^PERIMENOPAUSAL SYNDROME(HEMORAGIE)
^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3146" id="3146^VENOUS (PERIPHERAL)
INSUFFICIENCY, UNSPECIFIED^99DCT">
xf:labelVENOUS (PERIPHERAL) INSUFFICIENCY, UNSPECIFIED</
xf:label>
xf:value3146^VENOUS (PERIPHERAL) INSUFFICIENCY,
</xf:item>
<xf:item concept_id="3129" id="3129^EPIDIDYMITIS/
ORCHITIS^99DCT">
xf:labelEPIDIDYMITIS/ORCHITIS</xf:label>
xf:value3129^EPIDIDYMITIS/ORCHITIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3147" id="3147^CONJUNCTIVAL
XEROSIS^99DCT">
xf:labelCONJUNCTIVAL XEROSIS</xf:label>
xf:value3147^CONJUNCTIVAL XEROSIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3130" id="3130^OTHER VENERAL
DISEASES,SEXUALLY TRANSMITTED^99DCT">
xf:labelOTHER VENERAL DISEASES,SEXUALLY TRANSMITTED</
xf:label>
xf:value3130^OTHER VENERAL DISEASES,SEXUALLY
</xf:item>
<xf:item concept_id="1897" id="1897^BRONCHITIS,
UNSPECIFIED^99DCT">
xf:labelBRONCHITIS, UNSPECIFIED</xf:label>
xf:value1897^BRONCHITIS, UNSPECIFIED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3148" id="3148^UNSPECIFIED DISORDER OF
EYE AND ADNEXA^99DCT">
xf:labelUNSPECIFIED DISORDER OF EYE AND ADNEXA</
xf:label>
xf:value3148^UNSPECIFIED DISORDER OF EYE AND
ADNEXA^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1903" id="1903^UNSPECIFIED PLEURAL
EFFUSION^99DCT">
xf:labelUNSPECIFIED PLEURAL EFFUSION</xf:label>
xf:value1903^UNSPECIFIED PLEURAL EFFUSION^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="3149" id="3149^ACUTE
TONSILLITIS^99DCT">
xf:labelACUTE TONSILLITIS</xf:label>
xf:value3149^ACUTE TONSILLITIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1895" id="1895^OTHER DISEASES OF
PHARYNX^99DCT">
xf:labelOTHER DISEASES OF PHARYNX</xf:label>
xf:value1895^OTHER DISEASES OF PHARYNX^99DCT</xf:value>
</xf:item>
<xf:item concept_id="127" id="127^DYSMENORRHEA^99DCT">
xf:labelDYSMENORRHEA</xf:label>
xf:value127^DYSMENORRHEA^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3169" id="3169^OSTOARTHROSIS
UNSPECIFIED WHETHER GENERALIZED OR LOCALIZED^99DCT">
xf:labelOSTOARTHROSIS UNSPECIFIED WHETHER GENERALIZED OR
LOCALIZED</xf:label>
xf:value3169^OSTOARTHROSIS UNSPECIFIED WHETHER
GENERALIZED OR LOCALIZED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1891" id="1891^PERIPHERAL VASCULAR
DISEASE, UNSPECIFIED^99DCT">
xf:labelPERIPHERAL VASCULAR DISEASE, UNSPECIFIED</
xf:label>
xf:value1891^PERIPHERAL VASCULAR DISEASE,
</xf:item>
<xf:item concept_id="3163" id="3163^PITYRIASIS
VERSICOLOR^99DCT">
xf:labelPITYRIASIS VERSICOLOR</xf:label>
xf:value3163^PITYRIASIS VERSICOLOR^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1892" id="1892^PHLEBITIS AND
THROMBOPHLEBITIS OF LOWER EXTREMITIES, UNSPECIFIE^99DCT">
xf:labelPHLEBITIS AND THROMBOPHLEBITIS OF LOWER
EXTREMITIES, UNSPECIFIE</xf:label>
xf:value1892^PHLEBITIS AND THROMBOPHLEBITIS OF LOWER
EXTREMITIES, UNSPECIFIE^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3139" id="3139^SEVERE ASTHMA
CRISIS^99DCT">
xf:labelSEVERE ASTHMA CRISIS</xf:label>
xf:value3139^SEVERE ASTHMA CRISIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1888" id="1888^CONGESTIVE HEART
FAILURE, UNSPECIFIED^99DCT">
xf:labelCONGESTIVE HEART FAILURE, UNSPECIFIED</xf:label>
xf:value1888^CONGESTIVE HEART FAILURE,
</xf:item>
<xf:item concept_id="3166" id="3166^UNSPECIFIED SITE OF
SPRAIN AND STRAIN^99DCT">
xf:labelUNSPECIFIED SITE OF SPRAIN AND STRAIN</xf:label>
xf:value3166^UNSPECIFIED SITE OF SPRAIN AND
STRAIN^99DCT</xf:value>
</xf:item>
<xf:item concept_id="892" id="892^VARICELLA WITHOUT MENTION
OF COMPLICATION^99DCT">
xf:labelVARICELLA WITHOUT MENTION OF COMPLICATION</
xf:label>
xf:value892^VARICELLA WITHOUT MENTION OF
</xf:item>
<xf:item concept_id="1920" id="1920^CYSTITIS,
UNSPECIFIED^99DCT">
xf:labelCYSTITIS, UNSPECIFIED</xf:label>
xf:value1920^CYSTITIS, UNSPECIFIED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3132" id="3132^HYDROCELE
UNSPECIFIED^99DCT">
xf:labelHYDROCELE UNSPECIFIED</xf:label>
xf:value3132^HYDROCELE UNSPECIFIED^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1922" id="1922^URETHRAL STRICTURE,
UNSPECIFIED^99DCT">
xf:labelURETHRAL STRICTURE, UNSPECIFIED</xf:label>
xf:value1922^URETHRAL STRICTURE, UNSPECIFIED^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="3153" id="3153^VOLUME DEPLETION
DISORDER, DEGREE A^99DCT">
xf:labelVOLUME DEPLETION DISORDER, DEGREE A</xf:label>
xf:value3153^VOLUME DEPLETION DISORDER, DEGREE A^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="2025" id="2025^GALLBLADDER
DISEASE^99DCT">
xf:labelGALLBLADDER DISEASE</xf:label>
xf:value2025^GALLBLADDER DISEASE^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1925" id="1925^NEPHROLITHIASIS^99DCT">
xf:labelNEPHROLITHIASIS</xf:label>
xf:value1925^NEPHROLITHIASIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3137" id="3137^BRONCHOPNEUMONIA
ORGANISM UNSPECIFIED,BAD,PNEUMONIA^99DCT">
UNSPECIFIED,BAD,PNEUMONIA</xf:label>
xf:value3137^BRONCHOPNEUMONIA ORGANISM
UNSPECIFIED,BAD,PNEUMONIA^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1909" id="1909^BOWEL
OBSTRUCTION^99DCT">
xf:labelBOWEL OBSTRUCTION</xf:label>
xf:value1909^BOWEL OBSTRUCTION^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3170" id="3170^SCIATICA^99DCT">
xf:labelSCIATICA</xf:label>
xf:value3170^SCIATICA^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1916" id="1916^LIVER CIRRHOSIS^99DCT">
xf:labelLIVER CIRRHOSIS</xf:label>
xf:value1916^LIVER CIRRHOSIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="3167" id="3167^PYOGENIC ARTHRITIS
^99DCT">
xf:labelPYOGENIC ARTHRITIS</xf:label>
xf:value3167^PYOGENIC ARTHRITIS ^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1902" id="1902^OTHER SPONTANEOUS
PNEUMOTHORAX^99DCT">
xf:labelOTHER SPONTANEOUS PNEUMOTHORAX</xf:label>
xf:value1902^OTHER SPONTANEOUS PNEUMOTHORAX^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="166" id="166^DOG BITE^99DCT">
xf:labelDOG BITE</xf:label>
xf:value166^DOG BITE^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1918" id="1918^HERNIA INGUINAL^99DCT">
xf:labelHERNIA INGUINAL</xf:label>
xf:value1918^HERNIA INGUINAL^99DCT</xf:value>
</xf:item>
<xf:item concept_id="6103" id="6103^OSTEOARTHROSIS,
xf:labelOSTEOARTHROSIS, UNSPECIFIED WHETHER GENERALIZED
OR LOCALIZED</xf:label>
xf:value6103^OSTEOARTHROSIS, UNSPECIFIED WHETHER
</xf:item>
<xf:item concept_id="1910" id="1910^UNSPECIFIED GASTRITIS
AND GASTRODUODENITIS^99DCT">
xf:labelUNSPECIFIED GASTRITIS AND GASTRODUODENITIS</
xf:label>
xf:value1910^UNSPECIFIED GASTRITIS AND
GASTRODUODENITIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1957" id="1957^UNSPECIFIED OTITIS
MEDIA^99DCT">
xf:labelUNSPECIFIED OTITIS MEDIA</xf:label>
xf:value1957^UNSPECIFIED OTITIS MEDIA^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1923"
id="1923^GLOMERULONEPHRITIS^99DCT">
xf:labelGLOMERULONEPHRITIS</xf:label>
xf:value1923^GLOMERULONEPHRITIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1924" id="1924^UNSPECIFIED DISORDER OF
URETHRA AND URINARY TRACT^99DCT">
xf:labelUNSPECIFIED DISORDER OF URETHRA AND URINARY
TRACT</xf:label>
xf:value1924^UNSPECIFIED DISORDER OF URETHRA AND URINARY
</xf:item>
<xf:item concept_id="3045" id="3045^ACUTE UPPER RESPIRATORY
INFECTIONS OF UNSPECIFIED SITE^99DCT">
xf:labelACUTE UPPER RESPIRATORY INFECTIONS OF
UNSPECIFIED SITE</xf:label>
xf:value3045^ACUTE UPPER RESPIRATORY INFECTIONS OF
UNSPECIFIED SITE^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1900" id="1900^EMPHYSEMA^99DCT">
xf:labelEMPHYSEMA</xf:label>
xf:value1900^EMPHYSEMA^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1954" id="1954^ARTHRITIS^99DCT">
xf:labelARTHRITIS</xf:label>
xf:value1954^ARTHRITIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1911" id="1911^GASTROENTERITIS/
DIARRHEA^99DCT">
xf:labelGASTROENTERITIS/DIARRHEA</xf:label>
xf:value1911^GASTROENTERITIS/DIARRHEA^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1901" id="1901^INTERSTITIAL LUNG DIS/
LUNG DIS^99DCT">
xf:labelINTERSTITIAL LUNG DIS/ LUNG DIS</xf:label>
xf:value1901^INTERSTITIAL LUNG DIS/ LUNG DIS^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="1932" id="1932^HEREDITARY HEMOLYTIC
ANEMIA, UNSPECIFIED^99DCT">
xf:labelHEREDITARY HEMOLYTIC ANEMIA, UNSPECIFIED</
xf:label>
xf:value1932^HEREDITARY HEMOLYTIC ANEMIA,
</xf:item>
<xf:item concept_id="219" id="219^PSYCHOSIS^99DCT">
xf:labelPSYCHOSIS</xf:label>
xf:value219^PSYCHOSIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1940" id="1940^NEUROSIS^99DCT">
xf:labelNEUROSIS</xf:label>
xf:value1940^NEUROSIS^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1975" id="1975^BRAIN INJURY NEC^99DCT">
xf:labelBRAIN INJURY NEC</xf:label>
xf:value1975^BRAIN INJURY NEC^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1952" id="1952^MONONEUROPATHY,
UNSPECIFIED^99DCT">
xf:labelMONONEUROPATHY, UNSPECIFIED</xf:label>
xf:value1952^MONONEUROPATHY, UNSPECIFIED^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="1956" id="1956^PYOGEN ARTHRITIS-
UNSPEC^99DCT">
xf:labelPYOGEN ARTHRITIS-UNSPEC</xf:label>
xf:value1956^PYOGEN ARTHRITIS-UNSPEC^99DCT</xf:value>
</xf:item>
<xf:item concept_id="1798" id="1798^CONTUSION OF UNSPECIFIED
SITE^99DCT">
xf:labelCONTUSION OF UNSPECIFIED SITE</xf:label>
xf:value1798^CONTUSION OF UNSPECIFIED SITE^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="6107" id="6107^UNSPECIFIED ENDOCRINE
DISORDER^99DCT">
xf:labelUNSPECIFIED ENDOCRINE DISORDER</xf:label>
xf:value6107^UNSPECIFIED ENDOCRINE DISORDER^99DCT</
xf:value>
</xf:item>
<xf:item concept_id="1927" id="1927^NEPHROTIC SYNDROME WITH
xf:labelNEPHROTIC SYNDROME WITH UNSPECIFIED PATHOLOGICAL
xf:value1927^NEPHROTIC SYNDROME WITH UNSPECIFIED
</xf:item>
</xf:select1>
</xf:repeat>
</xf:group>
<xf:input bind="money_paid">
xf:labelMONEY PAID</xf:label>
xf:hintMoney a patient pays at the dispensary.</xf:hint>
</xf:input>
<xf:input bind="temperature_c">
xf:labelTEMPERATURE (C)</xf:label>
xf:hintPatient's temperature in degrees centigrade.</xf:hint>
</xf:input>
<xf:input bind="systolic_blood_pressure">
xf:labelSYSTOLIC BLOOD PRESSURE</xf:label>
xf:hintA patient's systolic blood pressure measurement (taken
with a manual cuff in either a sitting or standing position)</xf:hint>
</xf:input>
<xf:input bind="diastolic_blood_pressure">
xf:labelDIASTOLIC BLOOD PRESSURE</xf:label>
xf:hintA patient's diastolic blood pressure measurement (taken
</xf:input>
<xf:input bind="weight_kg">
xf:labelWEIGHT (KG)</xf:label>
xf:hintPatient's weight in kilograms.</xf:hint>
</xf:input>
<xf:input bind="return_visit_date">
xf:labelRETURN VISIT DATE</xf:label>
xf:hintPatient is to return on this date</xf:hint>
</xf:input>
<xf:input bind="has_referral_date">
xf:labelHAS REFERRAL DATE</xf:label>
</xf:input>
<xf:input bind="unit_out">
xf:labelUNIT OUT</xf:label>
</xf:input>
<xf:input bind="unit_in">
xf:labelUNIT IN</xf:label>
</xf:input>
</xf:group>
</xf:xforms>
