I would like to ask on how are we able to connect odk collect to
PostGIS+Geoserver+leaflets? I am new to this and I know I can get a lot of
ideas from you guys.
thanks,
thanks,
I am unfamiliar with those systems. If you have someone knowledgeable in
setting up servers, you could set up ODK Aggregate on that same server,
using PostgreSQL as the database, then they could either set up database
triggers to copy data from the ODK Aggregate tables into your PostGIS
tables or perhaps configure PostGIS to directly access the ODK Aggregate
tables (I'd recommend setting up a trigger).
ideas from you guys.thanks,
We are doing this very thing for several of our projects.
As Mitch has said above, you install ODK Aggregate on a postgres+PostGIS
database. Using Geoserver's SQL Viewshttp://docs.geoserver.org/stable/en/user/data/database/sqlview.html,
we serve out the required data as a WMS service.
We consume this WMS service in out OpenLayers based WebGIS
Bryan McBride has a demo of ODK + PostGIS + GeoServer + Leaflet at
http://geoserving.net/odk_geoserver. Contact him at
mcbride.bryan@gmail.com if you want to find out how he did it.
triggers to copy data from the ODK Aggregate tables into your PostGIS tables
or perhaps configure PostGIS to directly access the ODK Aggregate tables
(I'd recommend setting up a trigger).On Thu, Jun 20, 2013 at 6:53 PM, dionde android00dionde@gmail.com wrote:
mitchellsundt@gmail.com--
Hi there, have you taken a look at smap?
http://code.google.com/p/smap-suite/
Mark
tables (I'd recommend setting up a trigger).On Thu, Jun 20, 2013 at 6:53 PM, dionde android00dionde@gmail.com wrote:
hi sir..
I am very new to geoserver and postgis. I've got this sql script view using
Geoserver like this one:
Select *, ST_AsEWKB(ST_GeomFromText('POINT ('||latitude||'
'||longitude||')',4326)) as geom FROM mytable
where latitude and longitude are columns from mytable
I got this kind of error..
ERROR: relation "mytable" does not exist Position: 128
I would like to hear any idea from you. I've been searching in some other
solutions but I got stuck in this error..thanks in advance
We are doing this very thing for several of our projects.As Mitch has said above, you install ODK Aggregate on a postgres+PostGIS
we serve out the required data as a WMS service.We consume this WMS service in out OpenLayers based WebGIS
https://groups.google.com/d/topic/opendatakit/ACL683YUCao/unsubscribe.
'mytable' would be the name of the table containing the submission data.
You should Read up on PostgreSQL and SQL language to understand what this
text means.
http://www.postgresql.org/docs/9.2/static/sql.html
There are likely other more easily accessible tutorials on the web.
Different vendors have different flavors of SQL, so once you understand the
general syntax, you will want to use the reference manuals for the specific
software you are using.
hi sir..
using Geoserver like this one:Select *, ST_AsEWKB(ST_GeomFromText('POINT ('||latitude||'
'||longitude||')',4326)) as geom FROM mytablewhere latitude and longitude are columns from mytable
solutions but I got stuck in this error..thanks in advanceOn Wed, Jun 26, 2013 at 6:24 PM, Devdatta Tengshe dev3is@gmail.comwrote:
opendatakit+unsubscribe@googlegroups.com.For more options, visit https://groups.google.com/groups/opt_out.
