What is the best software for analysis of data exported from ODK
I think best is relative. What do you want to accomplish? I use R. I think you need to understand how to quickly clean up you variables names, subset your data to answer specific questions and if you export an xlsx file depending on your server- learn how to join the repeats to with the main file
Hey Shylock, how best can I join the repeats data... Am using the kobo server where the repeats are store in a separate tab of the exported worksheet
Note: If you are using the KoBo server, you should probably ask this on a
KoBo help list -- the answers here would probably only apply to ODK
Aggregate.
On Sat, Apr 16, 2016 at 5:37 AM, wrote:Hey Shylock, how best can I join the repeats data... Am using the kobo
worksheet--
