Hi everyone,
Is ODK Collect supported by iPhone? I've tried doing a google search on it
and there seems to have been a discussion about that last July, but I
couldn't find any other information.
Laura
Hi everyone,
Laura
Laura,
http://www.viewworld.dk/ has an iPhone client that is similar to ODK
Collect. You can download it from App Store. I believe it only works
with their server. They also support ODK Collect sending data to that
server.
https://github.com/mikewillekes/ocRosa is work-in-progress (~90%
complete) Javarosa library for iOS. You have to be a developer to use
it. Once that library is finished, it should be easier for others to
build ODK Collect like apps.
Hi Yaw,
I was asking because one of the Principal Investigators on this project
wants to test our questionnaire, but only has an iPhone, not an Android
phone. She would need to download the form from the server, fill out a mock
survey and then upload it to check what the data looks like. If I
understand your email correctly, this is not possible. Please correct me if
I'm wrong.
Laura
Laura,
server.https://github.com/mikewillekes/ocRosa is work-in-progress (~90%
build ODK Collect like apps.Yaw
On Mon, Feb 6, 2012 at 02:41, Laura Costica laura.costica@gmail.com wrote:
Hi everyone,
it
couldn't find any other information.Thanks,
Laura--
Hi Yaw,
Is this anywhere near complete ?
You are correct. Your options...
No and it will likely be no for a long time. Search the list for
discussions on this topic.
On Wed, Jul 29, 2015 at 9:44 PM, Dudley Butt dudleygb@gmail.com wrote:
Hi Yaw,
On Tuesday, February 7, 2012 at 1:57:37 AM UTC+10, Yaw Anokwa wrote:
Laura,
On Mon, Feb 6, 2012 at 02:41, Laura Costica laura....@gmail.com wrote:
Hi everyone,
it
Laura--
