https://lh3.googleusercontent.com/-XBG1eFwoQI0/VyVTxqqrloI/AAAAAAAAQQk/ZnWtPTa19dwXlZA3M0Vcv8H34ZPwkD24QCLcB/s1600/Capture.PNG
Greetings!
As the title states, I got the code as expected, however, there was no pop
up to configure it and there is no way to paste it then hit something,
everything is greyed out, am I missing something?
Hi Sergio,
This happened to me a few times too but I quit and re-opened my
browsers and then it started working all of a sudden.
On your Windows machine, is there a hidden file at
C:\Users\Serge.appcfg_oauth2_tokens_java? And on Ubuntu is it there
at ~/.appcfg_oauth2_tokens_java?
-- Need ODK consultants? Nafundi provides form design, server setup, in-field training, and software development for ODK. Go to https://nafundi.com to get started.On Mon, May 2, 2016 at 5:44 AM, Sergio Del Villar sgdvas@gmail.com wrote:
Update: Ubuntu didn't work either
This can also happen if you have multiple monitors on your system -- the
pop-up dialog can be on the other screen. It can also be buried under all
of your other windows.
I have also seen this happen once on Windows 10. In that case, it occurred
when the browser needed to be started.
When I then left the browser open, and closed and restarted the installer,
then the pop-up was displayed as the tab opened within the browser to the
Google site. But this is not a solid reproduction case -- I've done this
dozens of times during development and testing and never had that happen.
For those with the technical skills, there is also a command-line interface
to the installer.
On Sun, May 1, 2016 at 11:48 PM, Yaw Anokwa wrote:Hi Sergio,
browsers and then it started working all of a sudden.On your Windows machine, is there a hidden file at
at ~/.appcfg_oauth2_tokens_java?Yaw
Greetings! Thanks guys
I managed to solve it by clicking validate instead of verify token,
however, took me a few reboots, since it was throwing some random errors
when I tried "validate" straight away.
I also updated as file:///C:/User/....File.exe in java exception list
(though I had it before with 2 slashes instead of 3).
Yaw, the file is there (not sure if it was before it started to work).
Mitch I didn't have another monitor plugged in. The error was on w10, but,
since in ubuntu didn't work either, I didn't bother to try on win 7.
