Dear all,
I have a question, hopefully you can help.
For a development work project in Uganda, the foundation I work for wants to use Kamunye mobile phones which run on KaiOS. These phones are relatively cheap and can hence be used by a big part of the Ugandan population, who before did not have the financial means to buy more than a simple feature phone.
Part of the project is to collect data from participants, preferably using ODK.
But does ODK run on KaiOS?
Kamunye: Partner: MTN
Regions: Africa and Middle East
Launched: Q1 2019
KaiStore: Yes
Type: Bar
CPU: Quad Core 1.3 GHz (UNISOC SC7731)
Screen size (inches): 2.40
RAM: 256MB
Internal storage: 512MB
Camera: Rear 1.3 megapixel, Front 1.3 megapixel
Battery capacity (mAh): 2,000
Standby time: 2-5 days average usage
Network: 3G
This is as much as I know about the device for now.
Thank you for the support,
Leon
