Hello everyone, I have been trying to deploy ODK Aggregate for over a week now, getting all types of errors, tried everything to make it work and still nothing, I have reinstalled multiple times following different guides and haven't get it to work, now I'm getting a 404 error, here is my log, can you guys help me please?
Mar 27, 2016 3:30:45 AM org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: /usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib
Mar 27, 2016 3:30:45 AM org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on http-8080
Mar 27, 2016 3:30:45 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1047 ms
Mar 27, 2016 3:30:46 AM org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
Mar 27, 2016 3:30:46 AM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.44
Mar 27, 2016 3:30:46 AM org.apache.coyote.http11.Http11Protocol start
INFO: Starting Coyote HTTP/1.1 on http-8080
Mar 27, 2016 3:30:46 AM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
Mar 27, 2016 3:30:46 AM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/30 config=null
Mar 27, 2016 3:30:46 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 199 ms
Mar 27, 2016 3:31:16 AM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory docs
INFO: Deploying web application directory host-manager
INFO: Deploying web application directory examples
Mar 27, 2016 3:31:17 AM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory ROOT
INFO: Deploying web application directory sample
INFO: Deploying web application directory manager
Mar 27, 2016 5:13:58 AM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive ODKAggregate.war
Mar 27, 2016 5:14:02 AM org.apache.catalina.core.StandardContext start
SEVERE: Error listenerStart
SEVERE: Context [/ODKAggregate] startup failed due to previous errors
Mar 27, 2016 5:48:06 AM org.apache.coyote.http11.Http11Protocol pause
INFO: Pausing Coyote HTTP/1.1 on http-8080
Mar 27, 2016 5:48:07 AM org.apache.catalina.core.StandardService stop
INFO: Stopping service Catalina
Mar 27, 2016 5:48:07 AM org.apache.coyote.http11.Http11Protocol destroy
INFO: Stopping Coyote HTTP/1.1 on http-8080
Mar 27, 2016 5:48:09 AM org.apache.catalina.core.AprLifecycleListener init
Mar 27, 2016 5:48:09 AM org.apache.coyote.http11.Http11Protocol init
Mar 27, 2016 5:48:09 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 797 ms
Mar 27, 2016 5:48:09 AM org.apache.catalina.core.StandardService start
Mar 27, 2016 5:48:09 AM org.apache.catalina.core.StandardEngine start
Mar 27, 2016 5:48:09 AM org.apache.catalina.startup.HostConfig deployDescriptor
INFO: Deploying configuration descriptor manager.xml
Mar 27, 2016 5:48:10 AM org.apache.catalina.startup.HostConfig deployDescriptor
INFO: Deploying configuration descriptor host-manager.xml
Mar 27, 2016 5:48:10 AM org.apache.catalina.startup.HostConfig deployWAR
Mar 27, 2016 5:48:16 AM org.apache.catalina.startup.HostConfig deployDirectory
Mar 27, 2016 5:48:16 AM org.apache.coyote.http11.Http11Protocol start
Mar 27, 2016 5:48:16 AM org.apache.jk.common.ChannelSocket init
Mar 27, 2016 5:48:16 AM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/57 config=null
Mar 27, 2016 5:48:16 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 7261 ms
