I have tried to do something like (....)("select * from geo.states where place={{data.origin}}" and place=data('origin') and some variations of that but I get an error every time.
I also tried to add a separate term at the end, like + encodeURIComponent(data('origin')) and a few variations on this but again didn't work.
The errors comes on fetching the data during the query, not on conversion.
Lastly I thought about fetching all states from geo.states, but apparently Yahoo queries won't do that. It will accept select * from geo.countries for example, for but states it needs states of a specific country.
My only idea right now as to how to do that would be to create my own table (community table) with a list of all states (in the world), and then use choice_filter on choice_item like like what is done with a CSV query for cascading select.
Another option would be to find a CSV that has a list of all states of all countries and filter on that using CSV queries instead.
But as a general idea I feel being able to make Ajax queries with terms dependant on form data would be very interesting.
Oh just to specify: Createing my own table means creating a table on Yahoo that would contain that information and then call the query on that homemade table. I haven't tried it yet but apparently you can make your own table and call queries on them.
Aaaaaaaah I was missing the quotations on this. I thought it unlikely that {{data.variable}} would work but because the usual JS substitution didn't work I decided to give it a try.
That's the kind of things I would for sure add to the docs.
I'll be a bit busy for the next little while, but since I've been coding for a while on Survey by now I'd be down to add that kind of info to the documentations, if you guys want the help. Would likely be at some point in december I think.
Note the single quotes near the double quotes in the above expression.
And, of course, you should cleanse the value of data('origin') so that any
single quotes are properly escaped (to prevent SQL injection attacks).
