ODK Tables
And ODK Tables seems to be close to being production ready as well :slight_smile: ...
ยทยทยท On Thu, Oct 10, 2013 at 8:55 AM, Collins O. Adoyo wrote:
Hi Tumaini, did you succeed in implementing this project? How did you go
about tables? I have similar project and am just wondering how to approach
it especially on complex tables?
Collins
On Sat, Sep 21, 2013 at 9:51 AM, W. Brunette wbrunette@gmail.com wrote:
I should add that our goal is by the end of the November to have all the
betas out for 2.0 and move to release candidates in January 2014. There are
so many unknown variables that we do not provide exact timetables. You will
hopefully see betas being released starting at the beginning of November. I
do not know which order the betas will be released in so I said the end of
November.
Let me reiterate that because of the unknowns, the amount of work needed
on the 1.x tool chain, upgrades, etc the very small ODK core team does NOT
guarantee dates.
Waylon
On Fri, Sep 20, 2013 at 11:44 PM, W. Brunette wbrunette@gmail.comwrote:
While we cannot provide an accurate schedule I would guess the beta will
be the end of November (let me reiterate that is a guess), if we miss the
end of November it will likely be January.
Waylon
On Thu, Sep 19, 2013 at 2:08 PM, sbochte@gmail.com wrote:
Thanks for the update and for all the hard work. Is there any update on
a possible beta of Tables?
Thanks!
Steve
Groups "ODK Community" group.
Yes, there is rev 126 / 128 available on our site
https://opendatakit.org/use/2_0_tools/
The rev 122 and rev 126/ 128 required different versions of ODK Aggregate.
We do not support seamless upgrading from the rev 122 tools to the 126/128
tools.
You must completely purge all data from ODK Aggregate when upgrading.
On your devices, you might be able to export the data to CSV via ODK
Tables' export functionality, then upgrade and import that data (and then
push it to your new ODK Aggregate server), but there may be other manual
steps involved (we have not tried to migrate an existing project across
versions, but work on new projects with each new release).
The XLSX file format is retained between the two versions, but you should
run it through the XLSXConverter to generate new formDef.json files.
ยทยทยท On Tue, Jul 21, 2015 at 8:19 AM, wrote:
Thanks for all the hard work. A question-is there a newer version than rev
122 of ODK tables?
Thank you!
Steve
November.
guarantee dates.
Waylon
Waylon
Thanks!
Steve
Aha.. this is wonderful Tumaini.
Is it OK with you to inbox me the access code to see how it works?
Collins
ยทยทยท On Thu, Oct 10, 2013 at 3:04 PM, Tumaini Kilimba wrote:
Hello Collins,
I, as well as some other developers in Switzerland and Tanzania created a
tool which is a hybrid of a Native Android/ODK Collect tool (
https://code.google.com/p/ihi-openhds/) and this is what we used instead
to collect longitudinal household data.
Hope this helps,
Tumaini
On Thu, Oct 10, 2013 at 8:55 AM, Collins O. Adoyo <collins.adoyo@gmail.com wrote:
Collins
November.
guarantee dates.
Waylon
will be the end of November (let me reiterate that is a guess), if we miss
the end of November it will likely be January.
Waylon
on a possible beta of Tables?
Thanks!
Steve
Have you tried out the link I sent?
Collins
On Thu, Oct 10, 2013 at 3:04 PM, Tumaini Kilimba tkilimba@ihi.or.tzwrote:
Hello Collins,
Hope this helps,
Tumaini
On Thu, Oct 10, 2013 at 8:55 AM, Collins O. Adoyo < collins.adoyo@gmail.com> wrote:
Collins
the betas out for 2.0 and move to release candidates in January 2014. There
are so many unknown variables that we do not provide exact timetables. You
will hopefully see betas being released starting at the beginning of
November. I do not know which order the betas will be released in so I said
the end of November.
needed on the 1.x tool chain, upgrades, etc the very small ODK core team
does NOT guarantee dates.
Waylon
Waylon
Thanks!
Steve
send an email to opendatakit+unsubscribe@googlegroups.com.
yes tumaini, its asking for username and password
collins
Collins
Hello Collins,
a tool which is a hybrid of a Native Android/ODK Collect tool (
https://code.google.com/p/ihi-openhds/) and this is what we used instead to
Hope this helps,
Tumaini
go about tables? I have similar project and am just wondering how to
approach it especially on complex tables?
Collins
Waylon
Waylon
update on a possible beta of Tables?
Thanks!
Steve
ยทยทยท On Oct 10, 2013 3:53 PM, "Tumaini Kilimba" wrote: > On Thu, Oct 10, 2013 at 3:18 PM, Collins O. Adoyo wrote: >> On Thu, Oct 10, 2013 at 3:04 PM, Tumaini Kilimba wrote: >>> On Thu, Oct 10, 2013 at 8:55 AM, Collins O. Adoyo < collins.adoyo@gmail.com> wrote: >>>> On Sat, Sep 21, 2013 at 9:51 AM, W. Brunette wrote: >>>>> On Fri, Sep 20, 2013 at 11:44 PM, W. Brunette wrote: >>>>>> On Thu, Sep 19, 2013 at 2:08 PM, wrote: > For more options, visit https://groups.google.com/groups/opt_out.
Oh ok, sorry. Let me see what I can do from my side and will let you know
:slight_smile:
collins
On Thu, Oct 10, 2013 at 3:18 PM, Collins O. Adoyo < collins.adoyo@gmail.com> wrote:
Collins
On Thu, Oct 10, 2013 at 3:04 PM, Tumaini Kilimba tkilimba@ihi.or.tz wrote:
Hello Collins,
created a tool which is a hybrid of a Native Android/ODK Collect tool (
Hope this helps,
Tumaini
Collins
Waylon
Waylon
Thanks!
Steve
