- * Copyright (C) 2011 University of Washington.
- * Licensed under the Apache License, Version 2.0 (the "License"); you may not
- * use this file except in compliance with the License. You may obtain a copy of
- * the License at
- * http://www.apache.org/licenses/LICENSE-2.0
- * Unless required by applicable law or agreed to in writing, software
- * distributed under the License is distributed on an "AS IS" BASIS, WITHOUT
- * WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the
- * License for the specific language governing permissions and limitations under
- * the License.
- package org.opendatakit.briefcase.util;
- import java.io.File;
- import java.io.FileInputStream;
- import java.io.FileNotFoundException;
- import java.io.IOException;
- import java.io.InputStream;
- import java.math.BigInteger;
- import java.nio.file.Path;
- import java.security.MessageDigest;
- import java.security.NoSuchAlgorithmException;
- import java.sql.SQLException;
- import java.util.ArrayList;
- import java.util.List;
- import java.util.Objects;
- import org.opendatakit.briefcase.model.FileSystemException;
- import org.opendatakit.briefcase.model.OdkCollectFormDefinition;
- import org.slf4j.Logger;
- import org.slf4j.LoggerFactory;
- public class FileSystemUtils {
- private static final Logger log = LoggerFactory.getLogger(FileSystemUtils.class);
- public static final String FORMS_DIR = "forms";
- static final String INSTANCE_DIR = "instances";
- private static final String HSQLDB_DIR = "info.hsqldb";
- private static final String HSQLDB_DB = "info";
- private static final String SMALLSQL_DIR = "info.db";
- static final String HSQLDB_JDBC_PREFIX = "jdbc:hsqldb:file:";
- static final String SMALLSQL_JDBC_PREFIX = "jdbc:smallsql:";
- // Predicates to determine whether the folder is an ODK Device
- // ODK folder or underneath that folder.
- private static boolean isODKDevice(File pathname) {
- File fo = new File(pathname, "odk");
- File foi = new File(fo, "instances");
- File fof = new File(fo, "forms");
- return fo.exists() && foi.exists() && fof.exists();
- public static boolean isUnderODKFolder(File pathname) {
- File parent = (pathname == null ? null : pathname.getParentFile());
- File current = pathname;
- while (parent != null) {
- if (isODKDevice(parent) && current.getName().equals("odk"))
- return true;
- current = parent;
- parent = parent.getParentFile();
- return false;
- public static List<OdkCollectFormDefinition> getODKFormList(File odk) {
- List<OdkCollectFormDefinition> formsList = new ArrayList<>();
- File forms = new File(odk, "forms");
- if (forms.exists()) {
- File[] formDirs = forms.listFiles();
- for (File f : Objects.requireNonNull(formDirs)) {
- if (f.isFile() && f.getName().endsWith(".xml")) {
- try {
- formsList.add(new OdkCollectFormDefinition(f));
- } catch (BadFormDefinition e) {
- log.debug("bad form definition", e);
- return formsList;
- private static File getFormsFolder(File briefcaseFolder) {
- return new File(briefcaseFolder, FORMS_DIR);
- // TODO Ensure this is OK, as opposed to using stripIllegalChars()
- private static String asFilesystemSafeName(String formName) {
- return formName.replaceAll("[/\\\\:]", "").trim();
- public static File getFormDirectory(String formName, File briefcaseFolder)
- throws FileSystemException {
- // clean up friendly form name...
- String rootName = asFilesystemSafeName(formName);
- File formPath = new File(getFormsFolder(briefcaseFolder), rootName);
- if (!formPath.exists() && !formPath.mkdirs()) {
- throw new FileSystemException("unable to create directory: " + formPath.getAbsolutePath());
- return formPath;
- static String getFormDatabaseUrl(File formDirectory) throws FileSystemException {
- File oldDbFile = new File(formDirectory, SMALLSQL_DIR);
- File dbDir = new File(formDirectory, HSQLDB_DIR);
- File dbFile = new File(dbDir, HSQLDB_DB);
- if (!dbDir.exists()) {
- log.info("Creating database directory {}", dbDir);
- if (!dbDir.mkdirs()) {
- log.warn("failed to create database directory");
- } else if (oldDbFile.exists()) {
- migrateDatabase(oldDbFile, dbFile);
- return getJdbcUrl(dbFile);
- private static void migrateDatabase(File oldDbFile, File dbFile) throws FileSystemException {
- try {
- DatabaseUtils.migrateData(getJdbcUrl(oldDbFile), getJdbcUrl(dbFile));
- } catch (SQLException e) {
- throw new FileSystemException(String.format("failed to migrate database %s to %s", oldDbFile, dbFile), e);
- if (!oldDbFile.renameTo(getBackupFile(oldDbFile))) {
- throw new FileSystemException("failed to backup database after migration");
- private static File getBackupFile(File file) {
- return new File(file.getParent(), file.getName() + ".bak");
- private static String getJdbcUrl(File dbFile) throws FileSystemException {
- if (isHypersonicDatabase(dbFile)) {
- return HSQLDB_JDBC_PREFIX + dbFile.getAbsolutePath();
- } else if (isSmallSQLDatabase(dbFile)) {
- return SMALLSQL_JDBC_PREFIX + dbFile.getAbsolutePath() + (dbFile.exists() ? "" : "?create=true");
- } else {
- throw new FileSystemException("unknown database type for file " + dbFile);
- private static boolean isSmallSQLDatabase(File dbFile) {
- return SMALLSQL_DIR.equals(dbFile.getName());
- private static boolean isHypersonicDatabase(File dbFile) {
- File parentFile = dbFile.getParentFile();
- return HSQLDB_DB.equals(dbFile.getName()) && parentFile != null && HSQLDB_DIR.equals(parentFile.getName());
- public static File getFormDefinitionFile(File formDirectory) throws FileSystemException {
- return new File(formDirectory, formDirectory.getName() + ".xml");
- // May or may not actually exist on disk depending on whether the form definition has attached media.
- public static File getMediaDirectory(File formDirectory) throws FileSystemException {
- return new File(formDirectory, formDirectory.getName() + "-media");
- static File getFormInstancesDirectory(File formDirectory) throws FileSystemException {
- File instancesDir = new File(formDirectory, INSTANCE_DIR);
- if (!instancesDir.exists() && !instancesDir.mkdirs()) {
- throw new FileSystemException("unable to create directory: " + instancesDir.getAbsolutePath());
- return instancesDir;
- static boolean isFormRelativeInstancePath(String path) {
- return path.startsWith(INSTANCE_DIR);
- static Path makeRelative(File parent, File child) {
- Path parentPath = parent.toPath();
- Path childPath = child.toPath();
- return parentPath.relativize(childPath);
- static File getFormSubmissionDirectory(File formInstancesDir, String instanceID) {
- // construct the instance directory File...
- String instanceDirName = asFilesystemSafeName(instanceID);
- File instanceDir = new File(formInstancesDir, instanceDirName);
- if (!instanceDir.exists() || instanceDir.isDirectory()) {
- return instanceDir;
- return null;
- public static String getMd5Hash(File file) {
- try {
- // CTS (6/15/2010) : stream file through digest instead of handing
- // it the
- // byte[]
- MessageDigest md = MessageDigest.getInstance("MD5");
- int chunkSize = 256;
- byte[] chunk = new byte[chunkSize];
- // Get the size of the file
- long lLength = file.length();
- if (lLength > Integer.MAX_VALUE) {
- log.error("File is too large");
- return null;
- int length = (int) lLength;
- InputStream is;
- is = new FileInputStream(file);
- int l;
- for (l = 0; l + chunkSize < length; l += chunkSize) {
- is.read(chunk, 0, chunkSize);
- md.update(chunk, 0, chunkSize);
- int remaining = length - l;
- if (remaining > 0) {
- is.read(chunk, 0, remaining);
- md.update(chunk, 0, remaining);
- byte[] messageDigest = md.digest();
- BigInteger number = new BigInteger(1, messageDigest);
- String md5 = number.toString(16);
- while (md5.length() < 32)
- md5 = "0" + md5;
- is.close();
- return md5;
- } catch (NoSuchAlgorithmException e) {
- log.error("MD5 calculation failed", e);
- return null;
- } catch (FileNotFoundException e) {
- log.error("No File", e);
- return null;
- } catch (IOException e) {
- log.error("Problem reading from file", e);
- return null;
This file has been truncated. show original
