ODK Web Forms Beta - integer question shows 999999999 after attempting to type 10 digits
First of all, what is the official process/where should we report bugs in the new ODK Web Forms? Also, will there be a tag added to the forum soon to include Web Forms? Perhaps after beta testing is done?
With an integer question in ODK Web Forms beta, if a user enters a large quantity of digits and fills the box/enters a number longer than 9 digits, the integer turns to 999999999. Even if you delete the 10th character, it displays 9 repeating 9s.
Make a integer question, load it in the new Web Forms, and type a number longer than 9 digits
After typing a 0 after the 9 it turns to this:
Thanks for trying the beta and giving feedback! Support posts just like this are perfect. You can use the odk-webforms tag.
In general, we strongly encourage using the text question type with numbers appearance when capturing a long string of numbers that's not going to be treated numerically (docs).
That said, I agree the behavior you encountered is not ideal and we'll revise it. We'll likely match Collect which simply prevents entering in a 10th digit. Web Forms is currently going to the highest number that can be represented with 9 digits.
I've also noticed unexpected behavior with the number text question type where the 17th digit and subsequent ones are turned to 0s. We'll look at fixing this as well!
