See Create and update Entities from repeats for the user-facing functionality and proposed XLSForm spec.
The concept
We propose adding a well-known meta block to repeats that can include an inner entity block. This would match the top-level meta/entity block described in the Entities spec.
With this addition, saveto attributes could be declared within a repeat if that repeat has a corresponding meta/entity block.
See below for an example of a form that creates one Entity for each instance of the tree repeat that matches the create condition. Entity updates could also be specified in the meta/entity block for a repeat using the update attribute and other attributes specified by the spec.
<?xml version="1.0"?>
<h:html xmlns="http://www.w3.org/2002/xforms" xmlns:entities="http://www.opendatakit.org/xforms/entities" xmlns:ev="http://www.w3.org/2001/xml-events" xmlns:h="http://www.w3.org/1999/xhtml" xmlns:jr="http://openrosa.org/javarosa" xmlns:odk="http://www.opendatakit.org/xforms" xmlns:orx="http://openrosa.org/xforms" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<h:head>
<h:title>Register many trees</h:title>
<model odk:xforms-version="1.0.0" entities:entities-version="2025.1.0">
<instance>
<data id="trees_registration" version="2025040701">
<tree>
<location />
<species />
<meta>
<entity dataset="trees" create_if="" id="">
<label />
</entity>
</meta>
</tree>
<meta>
<instanceID/>
</meta>
</data>
</instance>
<bind nodeset="/data/tree/location" type="geopoint" entities:saveto="geometry" />
<bind nodeset="/data/tree/species" type="string" entities:saveto="species" />
<bind nodeset="/data/tree/meta/entity/@id" type="string"/>
<setvalue event="odk-instance-first-load odk-new-repeat" ref="/data/tree/meta/entity/@id" value="uuid()"/>
<bind nodeset="/data/tree/meta/entity/@create_if" type="string" calculate="starts-with(../../../species, 'B')" />
<bind nodeset="/data/tree/meta/entity/label" calculate="../../../species" type="string"/>
<bind jr:preload="uid" nodeset="/data/meta/instanceID" readonly="true()" type="string"/>
</model>
</h:head>
<body>
<group ref="/data/tree">
<label>Tree</label>
<repeat nodeset="/data/tree">
<input ref="/data/tree/location">
<label>Tree location</label>
</input>
<input ref="/data/tree/species">
<label>Tree species</label>
</input>
</repeat>
</group>
</body>
</h:html>
