- When I used odkmeta to create data for stata from the attachedPNG_Syndromic_Surveillance_Report_2019_survey.csv , the .do file was created without any message of error. however, when i run the .do file, it said
. * forward
. char forward[Odk_name] forward
variable forward not found
r(111); - When I used odkmeta to create data for stata from the attachedPNG_Syndromic_Surveillance_Report_2019_surveyold.csv , the .do file was created without any message of error. however, when i run the .do file, it said
- SET-OF-casereport-immediately-casebriefrepeat
. char SETOFcasereportimmediatelycasebr[Odk_name] SET-OF-casereport-immediately-casebriefrepeat
variable SETOFcasereportimmediatelycasebr not found
r(111);
I run odkmeta example and encountered not problem. but found there is no repeat in the survey form of the example.
So my question is if odkmeta can be used to create data from ODK repeat? if yes, how to fix the problem?
I used Ona.oi to store an downloaded ODK dataset and used Stata/SE 15/.0 to run the odkmeta.
i tried to delete SET-OF- and SETOF in the .do file and run but it did not work.
use the attached file to run to reproduce the first problem
odkmeta using ss.do, csv(PNG_Syndromic_Surveillance_Report_2019_data.csv) survey(PNG_Syndromic_Surveillance_Report_2019_survey.csv) cho(PNG_Syndromic_Surveillance_Report_2019_choices.csv)
then
do ss.do -
use the attached file to run to reproduce the second problem
odkmeta using ssold.do, csv(PNG_Syndromic_Surveillance_Report_2019_data.csv) survey(PNG_Syndromic_Surveillance_Report_2019_surveyold.csv) cho(PNG_Syndromic_Surveillance_Report_2019_choices.csv)
then
do ssold.do
I attached the csv file i used.
PNG_Syndromic_Surveillance_Report_2019_choices.csv (561.9 KB) PNG_Syndromic_Surveillance_Report_2019_data.csv (45.2 KB) PNG_Syndromic_Surveillance_Report_2019_survey.csv (5.6 KB)
PNG_Syndromic_Surveillance_Report_2019_surveyold.csv (5.4 KB)
