Does any one use an offline xls converter ? If so, which one. I use this
one...
But can't get it to work. I drag my file into the terminal window but
nothing happens. The converted file does not appear in the output folder as
it should.
Nafundi is building an improved XLSForm converter that can be used
offline and will work on Windows, Mac and Linux. It's in beta right
now and I'm hoping we can release it soon.
If you are interested in using this tool, send me an email at yanokwa@nafundi.com and I'll let you know when it's available.
it should.
tell if someone is scheduled for the online converter XLSform back up and running?
Thank you!
Em sexta-feira, 15 de agosto de 2014 12h49min43s UTC-3, Musyoka Munyoki escreveu:
> Hello Everyone,
> Does any one use an offline xls converter ? If so, which one. I use this one...
> https://github.com/UW-ICTD/xlsform.exe/blob/master/README.md
> But can't get it to work. I drag my file into the terminal window but nothing happens. The converted file does not appear in the output folder as it should.
> I appreciate any assistance you can offer.
> Thank you.
I'm looking forward to using your XLSForm converter.
On Friday, August 15, 2014 11:58:01 AM UTC-4, Yaw Anokwa wrote:
> Hi all,
> yan...@nafundi.com and I'll let you know when it's
> available.
> Thanks,
> Yaw
> On Fri, Aug 15, 2014 at 8:49 AM, Musyoka Munyoki <mmunyok...@gmail.com > wrote:
> > Hello Everyone,
> > one...
> as
> > it should.
> > Thank you.
> Groups
> > "ODK Community" group.
> an
I would like to use/test your XLSForm converter too.
Em sexta-feira, 15 de agosto de 2014 12h58min01s UTC-3, Yaw Anokwa escreveu:
> Hi all,
> Thanks,
> Yaw
> On Fri, Aug 15, 2014 at 8:49 AM, Musyoka Munyoki wrote:
> > Hello Everyone,
> > one...
> as
> > it should.
> > Thank you.
> Groups
> an
> > email to opendatakit+unsubscribe@googlegroups.com.
Thank you.
