I want to display all wards of the multiple selected districts using choice_filter, but this does not seem to work. I tried a lot of different things, but the most used formula in the choice_filter for this purpose seems to be of the type "selected(${name}, name)", but in my case this does not seem to work. I tried it both with KoBo Toolbox as with ODK Collect. Their is no problem on the choices tab, as it works perfectly with select_one followed by a choice_filter.
As a new user I cannot attach files so I'll try to show it clearly below:
select_multiple district   trade_district   Select the Districts where you usually do business
select_multiple ward      trade_ward     Select all the Wards where you have bought cassava or beans before    selected(${trade_district}, trade_district)
Thank you for your support!
Regards,
Anthony
