Hi list.
This time to ask about somebody working to make Oracle as Aggretate for ODK
data.
Thank you.
Hi list.
data.
Thank you.
The core ODK team is not working on an Oracle version as we have a
goal to keep all ODK tools free to use. Others might, hopefully they
will respond to your query if they are willing to share.
also, can i ask what use case you need oracle support for?
Good news! Waiting for that feature. Thank you.
will respond to your query if they are willing to share.On Thu, May 12, 2011 at 8:13 AM, Yesid Carrillo Vega yecarrillo@gmail.com wrote:
Hi list.
ODK
data.
Thank you.Yesid Carrillo
Hi Yaw.
IDEAM (Colombia) is using ODK to capture data and they want store it into
Oracle its corporative geodatabase. Support for Oracle would be a great
enchancement.
Hi list.
ODK
data.
yesid,
one easy way around this is to setup a connector between odk and the oracle db.
if you want to connect collect to oracle, you can send collect's http
post to oracle through some http interface. if you want to connect
aggregate to oracle, you can send json data to any web url or you can
read from the sql db if you use the local instance.
my guess is that oracle support is not coming soon, so i'd encourage
you to explore the connector option.
yaw
