Hello group:
I've been working with Collect for some years, with form download and data
storage using my own custom server.
But I've just tried to use the function for the first time, to
incorporate the answer to a previous question in the of a
subsequent question, as described here:
https://opendatakit.org/help/form-design/body/
But I can't make the tag output anything. Here's an example form,
which requests a value ("Hours?"), then should display that value in the
of a confirmation signature field.
<?xml version="1.0"?>
<h:html xmlns="http://www.w3.org/2002/xforms" xmlns:h="http://www.w3.org/1999/xhtml" xmlns:ev="http://www.w3.org/2001/xml-events" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:jr="http://openrosa.org/javarosa" xmlns:odk="http://www.opendatakit.org/xforms">
<h:head>
<h:title>My Form</h:title>
instance>
*</*instance>
Hours?
Hours: - please sign to
confirm:
In Collect, when prompted for "Hours?" I can enter a number and the form stores it correctly, but the subsequent element label appears as "Hours: - please sign to confirm". The instruction doesn't display anything.
Can anyone shed any light?
One possibility - I'm not using the very latest Collect build (I think my current fork was from 1.4.10), so is the feature only supported in recent versions?
Grateful for any thoughts!
Nik
The value="data/signoffgroup/hours" is missing a leading slash. This makes
the reference point to either
/data/siggroup/sig/data/signoffgroup/hours
or
/data/siggroup/data/signoffgroup/hours
depending upon an existing off-by-one-level error in the referencing of
To fix the issue, change it to
value="*/*data/signoffgroup/hours"
(output has been available from the beginning of time)
On Tue, Mar 14, 2017 at 6:46 AM, blitheringeejit via ODK Developers < opendatakit-developers@googlegroups.com> wrote:
Hello group:
form, which requests a value ("Hours?"), then should display that value in
the of a confirmation signature field.
<h:head>
instance>
*</*instance>
Hours?
confirm:
Nik
"ODK Developers" group.
Mitch - many thanks, and apologies for bringing a simple syntax error to
the group. My embarrassment is hopefully punishment enough. ![:slight_smile: :slight_smile:](https://getodk.b-cdn.net/images/emoji/twitter/slight_smile.png?v=12)
Kind regards
Nik
> or
> On Tue, Mar 14, 2017 at 6:46 AM, blitheringeejit via ODK Developers < opendatakit...@googlegroups.com > wrote:
>> Hello group:
>> data storage using my own custom server.
>> My Form
>> *instance>*
>> Hours?
>> > "image/*">
>> to confirm:
>> Nik
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
Not a problem. These sorts of errors are always hard for the author to
find. That's what this list is for.
On Wed, Mar 15, 2017 at 3:35 AM, blitheringeejit via ODK Developers < opendatakit-developers@googlegroups.com> wrote:
Kind regards
Nik
makes the reference point to either
or
On Tue, Mar 14, 2017 at 6:46 AM, blitheringeejit via ODK Developers < opendatakit...@googlegroups.com> wrote:
Hello group:
<h:head>
instance>
*</*instance>
Hours?
to confirm:
Nik
an email to opendatakit-developers+unsubscribe@googlegroups.com.
mitche...@gmail.com
