Overlay2 full (Digital Ocean) - how do I clean it/move data to other volume?
I have installed ODK collect on Digital Ocean, and been using it for some months now. The disk /dev/vda1 is 50GB and is starting to fill up. However, the daily backups are onlye ~10 GB, so I went into the folders and found that overlay2 was filling up (at some point there was 66GB). I also managed to remove some temp files (how to do that) but the volume was still full.
Once it is full, I am not able to upload new entrees (or anyone else), and multiple projects start to be behind on schedule. So I added a volume of 100GB and mounted it. Now I need to move the 50GB files to the 100GB volume, but I don't know if I can just do this, or if there are more steps required so that the server stays running (queston 1).
Also, future data needs to be sent to the volume, as this is an easier place up add more data. I could not find where to do this (question 2).
Here is a similar problem on the Digital Ocean community.
ODK collect version 1.2 on Digital Ocean. Installed through the ODK walkthrough, including Swap.
Multiple things:
This last step is where I am stuck now. I know that I still need to copy the files (with mv or cp for example), but I am not sure if I can just copy the directory of 50GB tot he 100 GB and keep the server running as it should, or if I need to take additional steps.
Not sure how to reproduce, but the main disk /dev/vda1 should be full.
This person had the same problem (but different GB), here is an example copied from that post:
So after I made a snapshot in Digital Ocean (as backup), I managed to delete some temp files that were 25+GB through sudo ncdu /, navigating to large files in /tmp folders and deleting with d. I then had enough free space to update the server and hopefully prevent this from hapenning again :smiley:
