Page breaks when using grid-theme - is it possible?
I’m experimenting with grid-theme to see if it fits my needs. I have a question about page breaks.
In a separate post about grid-theme, I found this comment by @martijnr :
You can use field-list on top-level groups to get them to show on different pages.
I would like to confirm… can we break pages when using grid-theme style? My form is very very extensive and loading it all in one page is going to be overwhelming for the user, I think.
At the moment i’m using this example (google sheets) to better understand how grid-theme works, and i’ve tried adding field-list in the appearance column of some of the existing groups but the output in the webform is exactly the same as it was (no page breaks).
Here’s a screenshot, you can see I added “field-list” in E17:
Can you provide some clarity?
Thank you :folded_hands:
On your settings sheet, in the style column, add pages in addition to theme-grid, separating the two by a space. By default, each question will be on its own page. You can then put the field-list appearance on groups to make all questions within those groups appear on a single page. Documentation on the Enketo site: https://blog.enketo.org/gorgeous-grid/
Thank you @LN ,
It works!
Here’s a few screenshots for anyone out there looking into doing something similar:
With this setup, the very first note which is not grouped, appears on its own page, and then the groups also appear on their own page.
And in order to have pages with multiple groups inside each page, we can nest groups.
I ran a quick test and it seems to work well!
