I enumerated data on a Chinese Huawei model 3 phone then moved the data to another phone by ... copying the /SurveyCTO directory to another phone replacing the /SurveyCTO directory on the destination phone.
Everything is OK so far... All the same forms appear to be loaded both in the Fill Blank Forms and Edit Saved Forms areas. Though when I try to edit the existing form on the destination phone I get the error message that the file does not exist... and it says some funny path like ... "/storage/emulated/0" that clearly is not a ODK or SurveyCTO kind of path.
It's funny that I can see the title of the Edited form but when I try to access it to edit it it can't find the file.
That bogus path is probably an artifact of the Huawei's management of internal versus external memory. Somehow OKD/SurveyCTO stored the virtual path and not the relative physical path.
Is there some file in the ODK/SurveyCTO data structure that I can do a change all to fix the path to find the file(s)to edit?
Else, I will need to find that phone again just to retrieve the data.
Thanks!
Bob
Hi Bob,
Just to cc: the community with our advocated approach: it seems like
editing paths in internal SQLite databases is dangerous. Rather, it seems
using a similarly-configured, similar-model device should use the same
directory structure and thus side-step this problem. Or, does anybody have
other ideas..?
Chris
Thanks!
Bob
"ODK Developers" group.
Agreed. This is an issue when moving across Android 4.x builds. Google
changed the full ExternalStorage path from 4.1 to 4.2 in order to support
multiple user profiles on one device.
In the face of this, the recommended solution from Google is to store only
partial paths -- e.g., when saving filepaths in the database, start the
path from the 'odk' directory, instead of from /sdcard/...
This would change a bunch of things in ODK Collect, as there are places
where we search for the form by the full pathname
To truly fix this, ODK Collect would need to increment its database
version, and, in the onUpdate() method, it would replace all the full
pathnames in the database with paths relative to the 'odk/' directory.
There would be two new methods in FileUtils:
class FileUtils {
public static String asRelativePath(File file)
// strip off all directories before 'odk'. return 'odk/...' relativePath.
public static File asFile(String relativePath) {
// prepend the ExternalStorage directory to the 'odk/...' relativePath.
I am unclear if the relative path would also need to support '../' as the
first segment to handle arbitrary file placement within the sdcard. Not
sure what external tools might require that (e.g., clinic)
If anyone wants to sleuth through and contribute the code to handle this,
I'd fold it in.
On Mon, Jun 30, 2014 at 8:57 AM, Christopher Robert crobert@surveycto.com wrote:
Hi Bob,
other ideas..?
Chris
Thanks!
Bob
Thanks, Mitch.
Do we know of any devices that allowed users to update from 4.1 to 4.2+? If
not, this becomes purely a portability issue for data moved from one device
to another; the restriction becomes: for data captured on a pre-4.2 device,
you can only use it on another pre-4.2 device, and similarly for data
captured on a 4.2+ device. That would seem like a restriction that most
people might be able to live within.
Bob, that would mean that you wouldn't need a device to perfectly match,
but one that's either pre-4.2 or 4.2+, depending on your data-collection
device.
Chris
class FileUtils {
relativePath.
I'd fold it in.
On Mon, Jun 30, 2014 at 8:57 AM, Christopher Robert <crobert@surveycto.com wrote:
Hi Bob,
other ideas..?
Chris
Thanks!
Bob
an email to opendatakit-developers+unsubscribe@googlegroups.com.
Mitch, I tried porting the /SurveyCTO directory to another device and it works with no path or missing file issue.
Here are the version levels on the three phones...
Origination device: Android 4.2 Emotion UI [Chinese brand Huawei Model Honor 3x, $217]
1st Destination device [missing file error]: Android 4.4.2 [Chinese brand Xiaomi "Showme" $200]
2nd Destination device [that does find the files!] Android 4.2.1
Does this fit your theory of why I was having a missing file error when moving my survey data from one device to another?
Thanks for your insights!
I am thankful not to lose the 30 man-hours that went into enumerating that data.
Bob Achgill
On Monday, June 30, 2014 2:46:00 PM UTC-5, Mitch wrote:
> Agreed. This is an issue when moving across Android 4.x builds. Google changed the full ExternalStorage path from 4.1 to 4.2 in order to support multiple user profiles on one device.
Painfully, yes. ASUS Nexus 7 tablets.
Stumbled upon this during ODK 2.0 development last fall.
On Mon, Jun 30, 2014 at 12:52 PM, Christopher Robert <chrislrobert@gmail.com wrote:
Thanks, Mitch.
If not, this becomes purely a portability issue for data moved from one
device to another; the restriction becomes: for data captured on a pre-4.2
device, you can only use it on another pre-4.2 device, and similarly for
data captured on a 4.2+ device. That would seem like a restriction that
most people might be able to live within.
device.
Chris
only partial paths -- e.g., when saving filepaths in the database, start
the path from the 'odk' directory, instead of from /sdcard/...
class FileUtils {
relativePath.
I'd fold it in.
On Mon, Jun 30, 2014 at 8:57 AM, Christopher Robert < crobert@surveycto.com> wrote:
Hi Bob,
other ideas..?
Chris
Thanks!
Bob
Okay, that's too bad.
We need to see everywhere these paths appear. If it's just a matter of
deleting and re-downloading form definitions, that's not too bad. But if
the paths are in the form instances themselves (even if just for media
files), then that would not be good.
Chris
On Mon, Jun 30, 2014 at 12:52 PM, Christopher Robert < chrislrobert@gmail.com> wrote:
Thanks, Mitch.
device.
Chris
class FileUtils {
relativePath.
relativePath.
the first segment to handle arbitrary file placement within the sdcard. Not
this, I'd fold it in.
Hi Bob,
other ideas..?
Chris
Thanks!
Bob
BTW...
2nd destination device [that worked] is an ASUS 7" pad Model Me173X running Android 4.2.1
CORRECTION: There were 5 people enumerating so that is 30hours x 5 = 150 hours saved!
I believe moving to relative paths also allows you to make the /odk
folder location configurable. That'd solve the issue of non-standard
Android devices which save to internal memory when external memory is
available.
On Mon, Jun 30, 2014 at 1:23 PM, Christopher Robert chrislrobert@gmail.com wrote:
deleting and re-downloading form definitions, that's not too bad. But if the
paths are in the form instances themselves (even if just for media files),
Chris
On Mon, Jun 30, 2014 at 12:52 PM, Christopher Robert chrislrobert@gmail.com wrote:
Thanks, Mitch.
data captured on a 4.2+ device. That would seem like a restriction that most
device.
Chris
only partial paths -- e.g., when saving filepaths in the database, start the
class FileUtils {
relativePath.
relativePath.
Hi Bob,
other ideas..?
Chris
Thanks!
Bob
... and relative paths sounds like it would open the door for having select-able instances of /SurveyCTO#001.
Some projects require a means to divide the forms up. With selectable instances the enumerator could just pick which project he/she is enumerating for this hour by selecting from a project list which points to the proper /SurveyCTO####. A relative path design would/could make it possible to be involved in enumerating on any global or business or hobby concern with out having to uninstall and re-install ODK and thereby wiping all the data from the other project.
Yes, that fits. The directory name changed between some version of 4.1 and
some version 4.2 (I think 4.1.2 and 4.2.1, but it has been a while).
data.
hours saved!
